    MagicMirror cannot start (UnhandledPromiseRejectionWarning)
    6 Posts 3 Posters 1.4k Views 3 Watching
      sdetweil @Klinge
      @Klinge please do
      npm install
      K 1 Reply Last reply Reply Quote -1
      • K Offline
        Klinge @sdetweil
        @sdetweil Hi Sam, now it works. Thank you for your advice :-)
          sdetweil @Klinge
          @Klinge thanks… did you do the two part command originally
          git pull && npm run install-mm
          trying to see if the expression failed
          • SteffS Offline
            Steff
            Encountering the same problem, however npm install throws an error message:
            npm ERR! code EBADENGINE
            npm ERR! engine Unsupported engine
            npm ERR! engine Not compatible with your version of node/npm: magicmirror@2.26.0
            npm ERR! notsup Not compatible with your version of node/npm: magicmirror@2.26.0
            npm ERR! notsup Required: {"node":">=18"}
            npm ERR! notsup Actual:   {"npm":"8.19.4","node":"v16.20.2"}
            The “normal” update of my raspi via sudo apt- update & upgrade did not bring any changes, I had to update the node version manually:
            Update node version
            Please do not forget to log-off / log-on after nvm installation
            This helped now the npm install did run through and my magic mirror start again.
            Hope this is helpful for others who are encountering the same problem…
              sdetweil @Steff
              @Steff use my install/upgrade scripts. they do all this work
