v2.26.0 - default calendar rrule / event.recurrences issue
4 Posts 3 Posters 751 Views 4 Watching
  • E Offline
    evroom
    This event:
    BEGIN:VEVENT
    DTSTART;TZID=Europe/Berlin:20240104T180000
    DTEND;TZID=Europe/Berlin:20240104T200000
    RRULE:FREQ=WEEKLY;WKST=MO;COUNT=10;BYDAY=TH
    DTSTAMP:20240102T212443Z
    UID:63c23cpe0h356vgjl0o4tsnjbi@google.com
    CREATED:20240102T212139Z
    LAST-MODIFIED:20240102T212139Z
    SEQUENCE:0
    STATUS:CONFIRMED
    SUMMARY:#:SingleEventRepeating
    TRANSP:OPAQUE
    END:VEVENT
    Leads to this:
    0|MagicMirror  | [02.01.2024 22:22.25.197] [DEBUG] Title: #:SingleEventRepeating, with dates: ["2024-01-04T17:00:00.000Z","2024-01-11T17:00:00.000Z",null,null,"2024-02-01T17:00:00.000Z","2024-02-08T17:00:00.000Z",null,null,null,"2024-03-07T17:00:00.000Z"]
    0|MagicMirror  | [02.01.2024 22:22.25.197] [DEBUG] event.recurrences: undefined
    So:
        null,
        null,
        null,
        null,
        null,
    Resulting in MM showing only 5 of the 10 events.
    I would like to know where to look for the RRULE processing; cannot find anything in the calendar code.
    As there are some other issues that I found, I could perhaps learn something from it.
    Otherwise I will open an issue for it.
    MagicMirror version: 2.30.0
    Test environment:
    MagicMirror version: v2.30.0
    S 1 Reply Last reply Jan 2, 2024, 10:08 PM Reply Quote 1
      sdetweil @evroom
      @evroom we don’t do the RRULE processing ourselves,… we call the RRULE library function between
        rrule.between(now and 1 year from now)
      calendarfetcherutils.js
      Log.debug(`Search for recurring events between: ${pastLocal} and ${futureLocal}`);
      					let dates = rule.between(pastLocal, futureLocal, true, limitFunction);
      					Log.debug(`Title: ${event.summary}, with dates: ${JSON.stringify(dates)}`);
      					dates = dates.filter((d) => {
      						if (JSON.stringify(d) === "null") return false;
      						else return true;
      the we process the dates returned… note the filter I added this release, cause the null values returned killed the calendar
      • K Offline
        kitlaan
        FYI: I think this is related to the latest rrule release (2.7.0), which was updated when node-ical was upgraded to 0.17.1 (from 0.16.1). It looks like rrule removed luxon with its own self-built replacement… and the behavior changed.
        If you sift through issues filed in node-ical and rrule, there seems to be folks also seeing new recurrence behavior. As to why, /shrug…
        On my install, I rolled-back to the older version (npm install node-ical@0.16.1) and it seems now to be behaving.
        S 1 Reply Last reply Jan 11, 2024, 4:26 AM Reply Quote 1
          sdetweil @kitlaan
          @kitlaan yes it’s the new rrule.
          the old one is broken too…
          but, thanks for the feedback
