    Problem after MM-upgrade
    5 Posts 2 Posters 1.1k Views 2 Watching
      CLLA1972
      I just did an upgrade and got the following message:
      magicmirror@2.26.0 start
      [16.01.2024 19:51.34.090] [LOG] Starting MagicMirror: v2.26.0
      [16.01.2024 19:51.34.111] [LOG] Loading config …
      [16.01.2024 19:51.34.120] [DEBUG] config template file not exists, no envsubst
      [16.01.2024 19:51.34.133] [LOG] Loading module helpers …
      [16.01.2024 19:51.34.145] [LOG] No helper found for module: alert.
      [16.01.2024 19:51.34.204] [ERROR] (node:29116) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘command-exists’
      Require stack:
      • /home/pi/MagicMirror/modules/default/updatenotification/update_helper.js
      • /home/pi/MagicMirror/modules/default/updatenotification/node_helper.js
      • at Module._resolveFilename (node:internal/modules/cjs/loader:1082:15)
        at n._resolveFilename (node:electron/js2c/browser_init:2:117457)
        at Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
        at Module._load (node:internal/modules/cjs/loader:927:27)
        at f._load (node:electron/js2c/asar_bundle:2:13330)
        at Module.require (node:internal/modules/cjs/loader:1148:19)
        at require (node:internal/modules/cjs/helpers:110:18)
        at Object. (/home/pi/MagicMirror/modules/default/updatenotification/update_helper.js:3:23)
        at Module._compile (node:internal/modules/cjs/loader:1269:14)
        at Module._extensions…js (node:internal/modules/cjs/loader:1324:10)
        at Module.load (node:internal/modules/cjs/loader:1124:32)
        at Module._load (node:internal/modules/cjs/loader:965:12)
        at Object. (/home/pi/MagicMirror/modules/default/updatenotification/node_helper.js:4:22)
        (Use electron --trace-warnings ... to show where the warning was created)
        [16.01.2024 19:51.34.206] [ERROR] (node:29116) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
        ^C/home/pi/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
      I appreciate all help. THANKS !!!
        sdetweil @CLLA1972
        @CLLA1972 said in Problem after MM-upgrade:
        the
        npm run install_mm
        did not run
        I hate the pull && npm … if one fails the other doesn’t run, and you have no idea what is supposed to happen anyhow…
        please show the output of git status
        thats why I made the upgrade script
        see
        C 1 Reply Last reply
          CLLA1972 @sdetweil
          @sdetweil This?
          pi@raspberrypi:~/MagicMirror $ git status
          På grenen master
          Din gren är à jour med “origin/master”.
          Ospårade filer:
          (använd “git add …” för att ta med i det som ska checkas in)
          custom.css
          nohup.out
          inget köat för incheckning, men ospårade filer finns (spåra med “git add”)
            CLLA1972 @CLLA1972
            @CLLA1972 (I am not an expert on this)
              sdetweil @CLLA1972
              no problem… do this
              stop mm
              npm run install-mm
              then restart MM
