    New installation but even default is displayed
    23 Posts 2 Posters 9.1k Views 2 Watching
    • K
      kupperma
      Yes I have_
      Ok this does not work.
      So it seems to be raspianOS failure.
        sdetweil @kupperma
        @kupperma I ONLY use SSH to install MM… never use the actual display.
        have pi 0w, 02w, 3, 4,5 odroid, jetson nano, chromebox, chromebook,
        and multiple virtual machines under vmware
        NEVER seen npm run start say successful but not see it on screen…
        also, on the screen if u can,
        ctrl-c to stop the in ssh version
        on screen
        cd ~/Magicmirror
        npm start
          sdetweil @kupperma
          @kupperma said in New installation but even default is displayed:
          what does not work?
          • K
            kupperma
            The display does not react to ctrl-alt-t and there is no terminal visible.
              sdetweil @kupperma
              @kupperma ok, on the menu bar there is a terminal window, click that
              • K
                kupperma
                I know what you mean:
                in an earlier installation I could move the mouse and the menubar got visible or I could press F11 and the menubar got visible. But now nothing works.
                So should I reinstall raspian and start from the beginning or is there a work a round?
                  sdetweil @kupperma
                  @kupperma can u reboot? does anything change? again weird…
                  did you have MM running before? what would you lose starting over?
                  IF you start over,
                  new flash
                  boot, skip updates,
                  reboot turn on ssh
                  then run my install script… it will update system, install node, then mm…
                  • K
                    kupperma
                    I start over!
                    Thanks for the checklist.
                    I wont loose much for my custom.css , config.js I have the code copied in a textfile. The modules I would have to reinstall but thats ok.
                    Thank you for your time.
                    Manfred
                      sdetweil @kupperma
                      @kupperma run my backup/restore script… it saves all that and can be loaded up to github and versioned and restored from there
                      https://github.com/sdetweil/MagicMirror-backup-restore
                      it saves links to all the modules and restores from the links
                      • K
                        kupperma @sdetweil
                        Thank you again.
                        MM2 is up and running.
                          sdetweil @kupperma
                          @kupperma awesome… thanks for the feedback
