    Changing icons of the modules Current Weather and Weather Forecast
    301 Posts 30 Posters 1.7m Views 33 Watching
      sdetweil @Manu85
      @Manu85 see this post where someone needed a custom css class setting
      https://forum.magicmirror.builders/post/114837
      and your custom.css would have been
      .calendar .fa-trash-o {
      right?
      M 1 Reply Last reply
        Manu85 @sdetweil
        @sdetweil I just did like that but still nothing I have the impression that the symbol in my js.config is not known
        symbol: 'trash-o',
        url: 'webcal://p59-caldav.icloud.com/published/2/Mjc4MDY5NzE3Mjc4MDY5N_JWXRaX8nNLZE61rkC12xxxxxxxxxxxxxxxxxx'
        and all other symbols are ok
          sdetweil @Manu85
          @Manu85 use
           "fa-trash-o"
            Manu85 @sdetweil
            @sdetweil does not work
              sdetweil @Manu85
              @Manu85 in the developers window what do you see in the html and console tab view , 401, 404
              in console tab, put weath in the filter field
                Manu85 @sdetweil
                @sdetweil is this what is needed?
                  sdetweil @Manu85
                  @Manu85 no… you are looking at weather, not calendar for the trash icon
                  need the line in calendar where it SHOULD BE
                  sorry, in console should be calen for filter… oops
                    Manu85 @sdetweil
                    @sdetweil ok, like this I selected the line where the icon should appear, is it ok? for the selection that you asked me I was surprised to select the calendar, but you are the professional :-)
                      Manu85 @Manu85
                      @Manu85 said in Changing icons of the modules Current Weather and Weather Forecast:
                      @sdetweil ok, like this I selected the line where the icon should appear, is it ok? for the selection that you asked me I was surprised to select the weather, but you are the professional :-)
                      S 2 Replies Last reply
                        sdetweil @Manu85
                        @Manu85 fa-trash-o is wrong, added fa- again
                        and you did not put
                        calen
                        in the console tab filter field to get just messages from calendar module
                          sdetweil @Manu85
                          @Manu85 they have renamed it to trash-can in fa 6 which we ship now
                          also it is in the fa-solid connection
                          so you may need
                          "fa-solid trash-can"
                          and maybe
                          "fa-solid fa-trash-can"
                            Manu85 @sdetweil
                            @sdetweil you are too strong!!! now I will try to understand the weather temperature
                              sdetweil @Manu85
                              @Manu85 which symbol string did you use?
                                Manu85 @sdetweil
                                @sdetweil in config.js
                                symbol: 'trash-can',
                                in custom css
                                .fas.fa-trash-can
                                  sdetweil @Manu85
                                  @Manu85 thanks. might help others
                                    Manu85 @sdetweil
                                    @sdetweil do you thank me? I dream it’s you who teaches me hundreds of things…
                                    on the other hand I can’t understand the temperature in config.js I added
                                    tempUnits: "C",
                                    but that doesn’t change anything it’s still 282°
                                      sdetweil @Manu85
                                      @Manu85 I think that is supposed to be
                                       "metric"
                                      this is the doc for the default settings
                                      M 2 Replies Last reply
                                        Manu85 @sdetweil
                                        @sdetweil my config.js is already like this!
                                        language: "fr",
                                        	timeFormat: 24,
                                        	units: "metric",
                                        	units: "kmh",
                                        	tempUnit: "C",
                                          sdetweil @Manu85
                                          @Manu85 the doc says
                                          tempUnits What units to use for temperature. If not specified, the module uses the units value from config.js.
                                          Possible values: config.units = Specified by config.js, metric = Celsius, imperial = Fahrenheit
                                          Default value: config.units
                                          same choices… metric or imperial (not C)
                                            Manu85 @sdetweil
                                            you are right (as usual) I put units:
                                            "metric",
                                            in config.js of the module and it works, you are the best
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 13 / 16
