    Changing icons of the modules Current Weather and Weather Forecast
    301 Posts 30 Posters 1.7m Views 33 Watching
      Manu85 @sdetweil
      @sdetweil ok, like this I selected the line where the icon should appear, is it ok? for the selection that you asked me I was surprised to select the calendar, but you are the professional :-)
      M 1 Reply Last reply
        Manu85 @Manu85
        @Manu85 said in Changing icons of the modules Current Weather and Weather Forecast:
        @sdetweil ok, like this I selected the line where the icon should appear, is it ok? for the selection that you asked me I was surprised to select the weather, but you are the professional :-)
        S 2 Replies Last reply
          sdetweil @Manu85
          @Manu85 fa-trash-o is wrong, added fa- again
          and you did not put
          calen
          in the console tab filter field to get just messages from calendar module
            sdetweil @Manu85
            @Manu85 they have renamed it to trash-can in fa 6 which we ship now
            also it is in the fa-solid connection
            so you may need
            "fa-solid trash-can"
            and maybe
            "fa-solid fa-trash-can"
              Manu85 @sdetweil
              @sdetweil you are too strong!!! now I will try to understand the weather temperature
                sdetweil @Manu85
                @Manu85 which symbol string did you use?
                  Manu85 @sdetweil
                  @sdetweil in config.js
                  symbol: 'trash-can',
                  in custom css
                  .fas.fa-trash-can
                    sdetweil @Manu85
                    @Manu85 thanks. might help others
                      Manu85 @sdetweil
                      @sdetweil do you thank me? I dream it’s you who teaches me hundreds of things…
                      on the other hand I can’t understand the temperature in config.js I added
                      tempUnits: "C",
                      but that doesn’t change anything it’s still 282°
                        sdetweil @Manu85
                        @Manu85 I think that is supposed to be
                         "metric"
                        this is the doc for the default settings
                        M 2 Replies Last reply
                          Manu85 @sdetweil
                          @sdetweil my config.js is already like this!
                          language: "fr",
                          	timeFormat: 24,
                          	units: "metric",
                          	units: "kmh",
                          	tempUnit: "C",
                            sdetweil @Manu85
                            @Manu85 the doc says
                            tempUnits What units to use for temperature. If not specified, the module uses the units value from config.js.
                            Possible values: config.units = Specified by config.js, metric = Celsius, imperial = Fahrenheit
                            Default value: config.units
                            same choices… metric or imperial (not C)
                              Manu85 @sdetweil
                              you are right (as usual) I put units:
                              "metric",
                              in config.js of the module and it works, you are the best
                                sdetweil @Manu85
                                @Manu85 if you don’t specify in the module config it uses the settings at the top of config.js
                                  Manu85 @sdetweil
                                  @sdetweil I still have some advice to ask you but I’m going to bed, because in France it’s already Sunday and it’s 00:03 AM ;-)
                                  thank you again for your help
                                    sdetweil @Manu85
                                    @Manu85 ok, good night. I am driving til after 3 pm us mountain time. I think your time +8
                                    M 4 Replies Last reply
                                      Manu85 @sdetweil
                                      @sdetweil good luck and thank you for your help
                                        Manu85 @sdetweil
                                        @sdetweil yes indeed, we do not have the same night area…
                                          Manu85 @sdetweil
                                          @sdetweil Hello, I didn’t succeed in feeling like, but it doesn’t matter, I’ll leave it like that…
                                          if I understood correctly I need to keep my MM up to date, do I need to run your script every 3 months or is there a solution to do it automatically and is it also possible for the mirror modules?
                                            Manu85 @sdetweil
                                            @sdetweil I got a weather module update alert, I tried to update, but I got this error message, did I do something wrong?
                                            pi@MagicMirror:~/MagicMirror/modules/MMM-OneCallWeather $ git pull
                                            Depuis https://github.com/KristjanESPERANTO/MMM-OneCallWeather
                                               f7f964d..0069540  main       -> origin/main
                                            Mise ▒ jour f7f964d..0069540
                                            error: Vos modifications locales aux fichiers suivants seraient ▒cras▒es par la fusion▒:
                                                    MMM-OneCallWeather.js
                                                    package-lock.json
                                            Veuillez valider ou remiser vos modifications avant la fusion.
                                            Abandon
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 13 / 16
