    Changing icons of the modules Current Weather and Weather Forecast
    301 Posts 30 Posters 1.7m Views 33 Watching
      sdetweil @Manu85
      @Manu85 thanks. might help others
      M 1 Reply Last reply
        Manu85 @sdetweil
        @sdetweil do you thank me? I dream it’s you who teaches me hundreds of things…
        on the other hand I can’t understand the temperature in config.js I added
        tempUnits: "C",
        but that doesn’t change anything it’s still 282°
          sdetweil @Manu85
          @Manu85 I think that is supposed to be
           "metric"
          this is the doc for the default settings
          M 2 Replies Last reply
            Manu85 @sdetweil
            @sdetweil my config.js is already like this!
            language: "fr",
            	timeFormat: 24,
            	units: "metric",
            	units: "kmh",
            	tempUnit: "C",
              sdetweil @Manu85
              @Manu85 the doc says
              tempUnits What units to use for temperature. If not specified, the module uses the units value from config.js.
              Possible values: config.units = Specified by config.js, metric = Celsius, imperial = Fahrenheit
              Default value: config.units
              same choices… metric or imperial (not C)
                Manu85 @sdetweil
                you are right (as usual) I put units:
                "metric",
                in config.js of the module and it works, you are the best
                  sdetweil @Manu85
                  @Manu85 if you don’t specify in the module config it uses the settings at the top of config.js
                    Manu85 @sdetweil
                    @sdetweil I still have some advice to ask you but I’m going to bed, because in France it’s already Sunday and it’s 00:03 AM ;-)
                    thank you again for your help
                      sdetweil @Manu85
                      @Manu85 ok, good night. I am driving til after 3 pm us mountain time. I think your time +8
                      M 4 Replies Last reply
                        Manu85 @sdetweil
                        @sdetweil good luck and thank you for your help
                          Manu85 @sdetweil
                          @sdetweil yes indeed, we do not have the same night area…
                            Manu85 @sdetweil
                            @sdetweil Hello, I didn’t succeed in feeling like, but it doesn’t matter, I’ll leave it like that…
                            if I understood correctly I need to keep my MM up to date, do I need to run your script every 3 months or is there a solution to do it automatically and is it also possible for the mirror modules?
                              Manu85 @sdetweil
                              @sdetweil I got a weather module update alert, I tried to update, but I got this error message, did I do something wrong?
                              pi@MagicMirror:~/MagicMirror/modules/MMM-OneCallWeather $ git pull
                              Depuis https://github.com/KristjanESPERANTO/MMM-OneCallWeather
                                 f7f964d..0069540  main       -> origin/main
                              Mise ▒ jour f7f964d..0069540
                              error: Vos modifications locales aux fichiers suivants seraient ▒cras▒es par la fusion▒:
                                      MMM-OneCallWeather.js
                                      package-lock.json
                              Veuillez valider ou remiser vos modifications avant la fusion.
                              Abandon
                                sdetweil @Manu85
                                @Manu85 said in Changing icons of the modules Current Weather and Weather Forecast:
                                because you changed it.
                                git checkout MMM-OneCallWeather.js
                                remember, never change module code, all config goes in config.js
                                tempUnits: "metric"
                                NOT “C”
                                package-lock.json, erase it then git pull
                                  Manu85 @sdetweil
                                  @sdetweil If I understood correctly it is that I changed something in ```
                                  I understand that you are saying that I changed the value from ```
                                  tempUnits: "metric"
                                  ``` to ```
                                  tempUnits: "c"
                                  ```? I didn't touch it, it's like that in the file (I gave you a screenshot from github) and I promise you that I understand that nothing should be changed in these folders.
                                  so now I have to pass the line: ```
                                  and then I delete: package-lock.json and then I do git pull, should I put: ```
                                  tempUnits: "metric"
                                  ``` so different from what is in the ```
                                    Manu85 @sdetweil
                                      sdetweil @Manu85
                                      @Manu85 ok, got confused with default weather module using same property
                                      “C” is correct
                                        Manu85 @sdetweil
                                        @sdetweil it’s ok, I did as you told me and everything is in order, when you have a moment can you answer my previous question about updates if you can like it?
                                          Manu85 @sdetweil
                                          @sdetweil I have AGAIN one question I would like to change the size of the weather forecat icons, by opening the console (crtl+shift+i) I see that if I change the number (highlighted in yellow) it changes the size of the icon, for example against I don’t know how to put this in the custom css
                                            sdetweil @Manu85
                                            @Manu85 yes, I think you correct.on updated. I see he fixed the colored property and you updated the module.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 13 / 16
