    Changing icons of the modules Current Weather and Weather Forecast
    301 Posts 30 Posters 1.7m Views 33 Watching
      sdetweil @Manu85
      @Manu85 ok, good night. I am driving til after 3 pm us mountain time. I think your time +8
      M 4 Replies Last reply Reply Quote 0
        Manu85 @sdetweil
        @sdetweil good luck and thank you for your help
          Manu85 @sdetweil
          @sdetweil yes indeed, we do not have the same night area…
            Manu85 @sdetweil
            @sdetweil Hello, I didn’t succeed in feeling like, but it doesn’t matter, I’ll leave it like that…
            if I understood correctly I need to keep my MM up to date, do I need to run your script every 3 months or is there a solution to do it automatically and is it also possible for the mirror modules?
              Manu85 @sdetweil
              @sdetweil I got a weather module update alert, I tried to update, but I got this error message, did I do something wrong?
              pi@MagicMirror:~/MagicMirror/modules/MMM-OneCallWeather $ git pull
              Depuis https://github.com/KristjanESPERANTO/MMM-OneCallWeather
                 f7f964d..0069540  main       -> origin/main
              Mise ▒ jour f7f964d..0069540
              error: Vos modifications locales aux fichiers suivants seraient ▒cras▒es par la fusion▒:
                      MMM-OneCallWeather.js
                      package-lock.json
              Veuillez valider ou remiser vos modifications avant la fusion.
              Abandon
                sdetweil @Manu85
                @Manu85 said in Changing icons of the modules Current Weather and Weather Forecast:
                because you changed it.
                git checkout MMM-OneCallWeather.js
                remember, never change module code, all config goes in config.js
                tempUnits: "metric"
                NOT “C”
                package-lock.json, erase it then git pull
                  Manu85 @sdetweil
                  @sdetweil If I understood correctly it is that I changed something in ```
                  I understand that you are saying that I changed the value from ```
                  tempUnits: "metric"
                  ``` to ```
                  tempUnits: "c"
                  ```? I didn't touch it, it's like that in the file (I gave you a screenshot from github) and I promise you that I understand that nothing should be changed in these folders.
                  so now I have to pass the line: ```
                  and then I delete: package-lock.json and then I do git pull, should I put: ```
                  tempUnits: "metric"
                  ``` so different from what is in the ```
                    Manu85 @sdetweil
                      sdetweil @Manu85
                      @Manu85 ok, got confused with default weather module using same property
                      “C” is correct
                        Manu85 @sdetweil
                        @sdetweil it’s ok, I did as you told me and everything is in order, when you have a moment can you answer my previous question about updates if you can like it?
                          Manu85 @sdetweil
                          @sdetweil I have AGAIN one question I would like to change the size of the weather forecat icons, by opening the console (crtl+shift+i) I see that if I change the number (highlighted in yellow) it changes the size of the icon, for example against I don’t know how to put this in the custom css
                            sdetweil @Manu85
                            @Manu85 yes, I think you correct.on updated. I see he fixed the colored property and you updated the module.
                              sdetweil @Manu85
                              @Manu85 icon size swipe to mark that stuff in the upper right box, ctrl-c to copy
                              in your editor open on
                              custom.css at the bottom
                              paste it in
                              and put the proper selector around it
                              maybe
                              .weather .icon {
                              what was the stuff on the line you selected. hard to see here on my phone (img?)
                                Manu85 @sdetweil
                                @sdetweil the selected content is as follows, if I put for example 64 instead of 44 the icon is enlarged
                                  sdetweil @Manu85
                                  @Manu85 i meant the html view item
                                  we need to make a selector clause in the custom.css to select JUST the icon images, right
                                  .weather img ???? {
                                  the stuff from the tip right box, pasted in here
                                  you don’t want EVERY img in weather…
                                    Manu85 @sdetweil
                                    @sdetweil I just want to enlarge these images, tell me what elements you need because I cannot select the entire line of icons I can only select one in the console with ctrl shift i
                                      sdetweil @Manu85
                                      @Manu85 it has a class weather-icon
                                      so you want the img under weather-icon under the weather module (I think)
                                      .weather .weather-icon img {
                                      your stuff
                                        sdetweil @Manu85
                                        @Manu85 so you put that into custom.css and hit refresh(f5) on the dev window to see the results
                                          Manu85 @sdetweil
                                          @sdetweil I hope I expressed myself well, I want to enlarge the weather icons for each day of the week
                                            sdetweil @Manu85
                                            @Manu85 yes each icon uses the same weather-icon class. not just one
                                            try it
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 14 / 16
