    Changing icons of the modules Current Weather and Weather Forecast
    301 Posts 30 Posters 1.7m Views 33 Watching
      Manu85 @sdetweil
      @sdetweil I still have some advice to ask you but I’m going to bed, because in France it’s already Sunday and it’s 00:03 AM ;-)
      thank you again for your help
        sdetweil @Manu85
        @Manu85 ok, good night. I am driving til after 3 pm us mountain time. I think your time +8
        M 4 Replies Last reply Reply Quote 0
          Manu85 @sdetweil
          @sdetweil good luck and thank you for your help
            Manu85 @sdetweil
            @sdetweil yes indeed, we do not have the same night area…
              Manu85 @sdetweil
              @sdetweil Hello, I didn’t succeed in feeling like, but it doesn’t matter, I’ll leave it like that…
              if I understood correctly I need to keep my MM up to date, do I need to run your script every 3 months or is there a solution to do it automatically and is it also possible for the mirror modules?
                Manu85 @sdetweil
                @sdetweil I got a weather module update alert, I tried to update, but I got this error message, did I do something wrong?
                pi@MagicMirror:~/MagicMirror/modules/MMM-OneCallWeather $ git pull
                Depuis https://github.com/KristjanESPERANTO/MMM-OneCallWeather
                   f7f964d..0069540  main       -> origin/main
                Mise ▒ jour f7f964d..0069540
                error: Vos modifications locales aux fichiers suivants seraient ▒cras▒es par la fusion▒:
                        MMM-OneCallWeather.js
                        package-lock.json
                Veuillez valider ou remiser vos modifications avant la fusion.
                Abandon
                  sdetweil @Manu85
                  @Manu85 said in Changing icons of the modules Current Weather and Weather Forecast:
                  because you changed it.
                  git checkout MMM-OneCallWeather.js
                  remember, never change module code, all config goes in config.js
                  tempUnits: "metric"
                  NOT “C”
                  package-lock.json, erase it then git pull
                    Manu85 @sdetweil
                    @sdetweil If I understood correctly it is that I changed something in ```
                    I understand that you are saying that I changed the value from ```
                    tempUnits: "metric"
                    ``` to ```
                    tempUnits: "c"
                    ```? I didn't touch it, it's like that in the file (I gave you a screenshot from github) and I promise you that I understand that nothing should be changed in these folders.
                    so now I have to pass the line: ```
                    and then I delete: package-lock.json and then I do git pull, should I put: ```
                    tempUnits: "metric"
                    ``` so different from what is in the ```
                      Manu85 @sdetweil
                        sdetweil @Manu85
                        @Manu85 ok, got confused with default weather module using same property
                        “C” is correct
                          Manu85 @sdetweil
                          @sdetweil it’s ok, I did as you told me and everything is in order, when you have a moment can you answer my previous question about updates if you can like it?
                            Manu85 @sdetweil
                            @sdetweil I have AGAIN one question I would like to change the size of the weather forecat icons, by opening the console (crtl+shift+i) I see that if I change the number (highlighted in yellow) it changes the size of the icon, for example against I don’t know how to put this in the custom css
                              sdetweil @Manu85
                              @Manu85 yes, I think you correct.on updated. I see he fixed the colored property and you updated the module.
                                sdetweil @Manu85
                                @Manu85 icon size swipe to mark that stuff in the upper right box, ctrl-c to copy
                                in your editor open on
                                custom.css at the bottom
                                paste it in
                                and put the proper selector around it
                                maybe
                                .weather .icon {
                                what was the stuff on the line you selected. hard to see here on my phone (img?)
                                  Manu85 @sdetweil
                                  @sdetweil the selected content is as follows, if I put for example 64 instead of 44 the icon is enlarged
                                    sdetweil @Manu85
                                    @Manu85 i meant the html view item
                                    we need to make a selector clause in the custom.css to select JUST the icon images, right
                                    .weather img ???? {
                                    the stuff from the tip right box, pasted in here
                                    you don’t want EVERY img in weather…
                                      Manu85 @sdetweil
                                      @sdetweil I just want to enlarge these images, tell me what elements you need because I cannot select the entire line of icons I can only select one in the console with ctrl shift i
                                        sdetweil @Manu85
                                        @Manu85 it has a class weather-icon
                                        so you want the img under weather-icon under the weather module (I think)
                                        .weather .weather-icon img {
                                        your stuff
                                          sdetweil @Manu85
                                          @Manu85 so you put that into custom.css and hit refresh(f5) on the dev window to see the results
                                            Manu85 @sdetweil
                                            @sdetweil I hope I expressed myself well, I want to enlarge the weather icons for each day of the week
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 14 / 16
