    Changing icons of the modules Current Weather and Weather Forecast
    301 Posts 30 Posters 1.7m Views 33 Watching
      sdetweil @Manu85
      @Manu85 i meant the html view item
      we need to make a selector clause in the custom.css to select JUST the icon images, right
      .weather img ???? {
      the stuff from the tip right box, pasted in here
      you don’t want EVERY img in weather…
        Manu85 @sdetweil
        @sdetweil I just want to enlarge these images, tell me what elements you need because I cannot select the entire line of icons I can only select one in the console with ctrl shift i
          sdetweil @Manu85
          @Manu85 it has a class weather-icon
          so you want the img under weather-icon under the weather module (I think)
          .weather .weather-icon img {
          your stuff
            sdetweil @Manu85
            @Manu85 so you put that into custom.css and hit refresh(f5) on the dev window to see the results
              Manu85 @sdetweil
              @sdetweil I hope I expressed myself well, I want to enlarge the weather icons for each day of the week
                sdetweil @Manu85
                @Manu85 yes each icon uses the same weather-icon class. not just one
                try it
                  Manu85 @sdetweil
                  @sdetweil I put this in custom.css?
                    sdetweil @Manu85
                    @Manu85 AND the sizing stuff u created n the developer console upper right window inside the braces, copy/paste
                    swipe them with the mouse, copy
                      Manu85 @sdetweil
                      @sdetweil I copied this line because it’s the one that enlarges the icon in the console, I put that in css.custom and it’s still the same
                         max-width: 64px;
                      default is 44px
                      when I refresh the console page and I select the icon I don’t have any additional css.custom lines, I don’t know if my explanation is clear
                        sdetweil @Manu85
                        @Manu85 should be a strike thru on the 44px
                        did u save the custom.css?
                          Manu85 @sdetweil
                          @sdetweil yes, I saved the custom and when I type 64px instead of 44px I see the icon growing, but that doesn’t change anything and in the console window it’s always the same data
                            sdetweil @Manu85
                            @Manu85 ok hang on. I’ll get my laptop …
                              Manu85 @sdetweil
                              @sdetweil OK thanks
                                sdetweil @Manu85
                                @Manu85 ok, i think this is what you want
                                1. add
                                classes:"forecast",
                                the the weather forecast , after the module:“weather”, line
                                1. then add this to custom.css
                                .forecast .weathericon {
                                    font-size: 125%;
                                you can change the font-size bigger too
                                refresh the mm page
                                M M 2 Replies Last reply Reply Quote 0
                                  manu85340 @sdetweil
                                  @sdetweil ok thanks I’ll try that when I get home
                                    Manu85 @sdetweil
                                    @sdetweil I added in js.config
                                    classes:"forecast",
                                    after the line:
                                    module: "MMM-OneCallWeather",
                                    then in custom css:
                                    .forecast .weather-icon {
                                         font-size: 125%;
                                    I refreshed but it doesn’t change anything…
                                      sdetweil @Manu85
                                      @Manu85 sorry, darn using the default calendar again… hang on
                                      this TOPIC is about default calendar and weather
                                        sdetweil @Manu85
                                        @Manu85 in custom.css
                                        .MMM-OneCallWeather .weather-icon  img {
                                            max-width: 64px !important;
                                          Manu85 @sdetweil
                                          @sdetweil I’m sorry, it’s my fault, I mixed up the topics…but I didn’t know how to make another topic and let it be you who answers me!
                                          I modified the custom and it works, thanks again for that
                                            Manu85 @sdetweil
                                            @sdetweil I still need you, in the weather module there are “bubbles” with the wind speed inside, but the numbers are not centered, I made screenshots of the console and I saw where I can change the position however I am unable to put this in my custom css, can you help me please?
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 14 / 16
