    Changing icons of the modules Current Weather and Weather Forecast
    301 Posts 30 Posters 1.7m Views 33 Watching
      sdetweil @Manu85
      @Manu85 said in Changing icons of the modules Current Weather and Weather Forecast:
          MMM-OneCallWeather.js
      because you changed it.
      git checkout MMM-OneCallWeather.js
      remember, never change module code, all config goes in config.js
      tempUnits: "metric"
      NOT “C”
      package-lock.json, erase it then git pull
        Manu85 @sdetweil
        @sdetweil If I understood correctly it is that I changed something in ```
        I understand that you are saying that I changed the value from ```
        tempUnits: "metric"
        ``` to ```
        tempUnits: "c"
        ```? I didn't touch it, it's like that in the file (I gave you a screenshot from github) and I promise you that I understand that nothing should be changed in these folders.
        so now I have to pass the line: ```
        and then I delete: package-lock.json and then I do git pull, should I put: ```
        tempUnits: "metric"
        ``` so different from what is in the ```
          Manu85 @sdetweil
            sdetweil @Manu85
            @Manu85 ok, got confused with default weather module using same property
            “C” is correct
              Manu85 @sdetweil
              @sdetweil it’s ok, I did as you told me and everything is in order, when you have a moment can you answer my previous question about updates if you can like it?
                Manu85 @sdetweil
                @sdetweil I have AGAIN one question I would like to change the size of the weather forecat icons, by opening the console (crtl+shift+i) I see that if I change the number (highlighted in yellow) it changes the size of the icon, for example against I don’t know how to put this in the custom css
                  sdetweil @Manu85
                  @Manu85 yes, I think you correct.on updated. I see he fixed the colored property and you updated the module.
                    sdetweil @Manu85
                    @Manu85 icon size swipe to mark that stuff in the upper right box, ctrl-c to copy
                    in your editor open on
                    custom.css at the bottom
                    paste it in
                    and put the proper selector around it
                    maybe
                    .weather .icon {
                    what was the stuff on the line you selected. hard to see here on my phone (img?)
                      Manu85 @sdetweil
                      @sdetweil the selected content is as follows, if I put for example 64 instead of 44 the icon is enlarged
                        sdetweil @Manu85
                        @Manu85 i meant the html view item
                        we need to make a selector clause in the custom.css to select JUST the icon images, right
                        .weather img ???? {
                        the stuff from the tip right box, pasted in here
                        you don’t want EVERY img in weather…
                          Manu85 @sdetweil
                          @sdetweil I just want to enlarge these images, tell me what elements you need because I cannot select the entire line of icons I can only select one in the console with ctrl shift i
                            sdetweil @Manu85
                            @Manu85 it has a class weather-icon
                            so you want the img under weather-icon under the weather module (I think)
                            .weather .weather-icon img {
                            your stuff
                              sdetweil @Manu85
                              @Manu85 so you put that into custom.css and hit refresh(f5) on the dev window to see the results
                                Manu85 @sdetweil
                                @sdetweil I hope I expressed myself well, I want to enlarge the weather icons for each day of the week
                                  sdetweil @Manu85
                                  @Manu85 yes each icon uses the same weather-icon class. not just one
                                  try it
                                    Manu85 @sdetweil
                                    @sdetweil I put this in custom.css?
                                      sdetweil @Manu85
                                      @Manu85 AND the sizing stuff u created n the developer console upper right window inside the braces, copy/paste
                                      swipe them with the mouse, copy
                                        Manu85 @sdetweil
                                        @sdetweil I copied this line because it’s the one that enlarges the icon in the console, I put that in css.custom and it’s still the same
                                           max-width: 64px;
                                        default is 44px
                                        when I refresh the console page and I select the icon I don’t have any additional css.custom lines, I don’t know if my explanation is clear
                                          sdetweil @Manu85
                                          @Manu85 should be a strike thru on the 44px
                                          did u save the custom.css?
                                            Manu85 @sdetweil
                                            @sdetweil yes, I saved the custom and when I type 64px instead of 44px I see the icon growing, but that doesn’t change anything and in the console window it’s always the same data
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 14 / 16
