    Changing icons of the modules Current Weather and Weather Forecast
    301 Posts 30 Posters 1.7m Views 33 Watching
      Manu85 @sdetweil
      @sdetweil Hello, I didn’t succeed in feeling like, but it doesn’t matter, I’ll leave it like that…
      if I understood correctly I need to keep my MM up to date, do I need to run your script every 3 months or is there a solution to do it automatically and is it also possible for the mirror modules?
        Manu85 @sdetweil
        @sdetweil I got a weather module update alert, I tried to update, but I got this error message, did I do something wrong?
        pi@MagicMirror:~/MagicMirror/modules/MMM-OneCallWeather $ git pull
        Depuis https://github.com/KristjanESPERANTO/MMM-OneCallWeather
           f7f964d..0069540  main       -> origin/main
        Mise ▒ jour f7f964d..0069540
        error: Vos modifications locales aux fichiers suivants seraient ▒cras▒es par la fusion▒:
                MMM-OneCallWeather.js
                package-lock.json
        Veuillez valider ou remiser vos modifications avant la fusion.
        Abandon
          sdetweil @Manu85
          @Manu85 said in Changing icons of the modules Current Weather and Weather Forecast:
          because you changed it.
          git checkout MMM-OneCallWeather.js
          remember, never change module code, all config goes in config.js
          tempUnits: "metric"
          NOT “C”
          package-lock.json, erase it then git pull
          M 2 Replies Last reply
            Manu85 @sdetweil
            @sdetweil If I understood correctly it is that I changed something in ```
            I understand that you are saying that I changed the value from ```
            tempUnits: "metric"
            ``` to ```
            tempUnits: "c"
            ```? I didn't touch it, it's like that in the file (I gave you a screenshot from github) and I promise you that I understand that nothing should be changed in these folders.
            so now I have to pass the line: ```
            and then I delete: package-lock.json and then I do git pull, should I put: ```
            tempUnits: "metric"
            ``` so different from what is in the ```
              Manu85 @sdetweil
                sdetweil @Manu85
                @Manu85 ok, got confused with default weather module using same property
                “C” is correct
                  Manu85 @sdetweil
                  @sdetweil it’s ok, I did as you told me and everything is in order, when you have a moment can you answer my previous question about updates if you can like it?
                    Manu85 @sdetweil
                    @sdetweil I have AGAIN one question I would like to change the size of the weather forecat icons, by opening the console (crtl+shift+i) I see that if I change the number (highlighted in yellow) it changes the size of the icon, for example against I don’t know how to put this in the custom css
                      sdetweil @Manu85
                      @Manu85 yes, I think you correct.on updated. I see he fixed the colored property and you updated the module.
                        sdetweil @Manu85
                        @Manu85 icon size swipe to mark that stuff in the upper right box, ctrl-c to copy
                        in your editor open on
                        custom.css at the bottom
                        paste it in
                        and put the proper selector around it
                        maybe
                        .weather .icon {
                        what was the stuff on the line you selected. hard to see here on my phone (img?)
                        M 1 Reply Last reply
                          Manu85 @sdetweil
                          @sdetweil the selected content is as follows, if I put for example 64 instead of 44 the icon is enlarged
                            sdetweil @Manu85
                            @Manu85 i meant the html view item
                            we need to make a selector clause in the custom.css to select JUST the icon images, right
                            .weather img ???? {
                            the stuff from the tip right box, pasted in here
                            you don’t want EVERY img in weather…
                              Manu85 @sdetweil
                              @sdetweil I just want to enlarge these images, tell me what elements you need because I cannot select the entire line of icons I can only select one in the console with ctrl shift i
                              S 2 Replies Last reply
                                sdetweil @Manu85
                                @Manu85 it has a class weather-icon
                                so you want the img under weather-icon under the weather module (I think)
                                .weather .weather-icon img {
                                your stuff
                                  sdetweil @Manu85
                                  @Manu85 so you put that into custom.css and hit refresh(f5) on the dev window to see the results
                                    Manu85 @sdetweil
                                    @sdetweil I hope I expressed myself well, I want to enlarge the weather icons for each day of the week
                                      sdetweil @Manu85
                                      @Manu85 yes each icon uses the same weather-icon class. not just one
                                      try it
                                        Manu85 @sdetweil
                                        @sdetweil I put this in custom.css?
                                          sdetweil @Manu85
                                          @Manu85 AND the sizing stuff u created n the developer console upper right window inside the braces, copy/paste
                                          swipe them with the mouse, copy
                                            Manu85 @sdetweil
                                            @sdetweil I copied this line because it’s the one that enlarges the icon in the console, I put that in css.custom and it’s still the same
                                               max-width: 64px;
                                            default is 44px
                                            when I refresh the console page and I select the icon I don’t have any additional css.custom lines, I don’t know if my explanation is clear
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 14 / 16
