    Changing icons of the modules Current Weather and Weather Forecast
    301 Posts 30 Posters 1.7m Views 33 Watching
      sdetweil @Manu85
      @Manu85 I think that is supposed to be
       "metric"
      this is the doc for the default settings
        Manu85 @sdetweil
        @sdetweil my config.js is already like this!
        language: "fr",
        	timeFormat: 24,
        	units: "metric",
        	units: "kmh",
        	tempUnit: "C",
          sdetweil @Manu85
          @Manu85 the doc says
          tempUnits What units to use for temperature. If not specified, the module uses the units value from config.js.
          Possible values: config.units = Specified by config.js, metric = Celsius, imperial = Fahrenheit
          Default value: config.units
          same choices… metric or imperial (not C)
            Manu85 @sdetweil
            you are right (as usual) I put units:
            "metric",
            in config.js of the module and it works, you are the best
              sdetweil @Manu85
              @Manu85 if you don’t specify in the module config it uses the settings at the top of config.js
                Manu85 @sdetweil
                @sdetweil I still have some advice to ask you but I’m going to bed, because in France it’s already Sunday and it’s 00:03 AM ;-)
                thank you again for your help
                  sdetweil @Manu85
                  @Manu85 ok, good night. I am driving til after 3 pm us mountain time. I think your time +8
                  M 4 Replies Last reply Reply Quote 0
                    Manu85 @sdetweil
                    @sdetweil good luck and thank you for your help
                      Manu85 @sdetweil
                      @sdetweil yes indeed, we do not have the same night area…
                        Manu85 @sdetweil
                        @sdetweil Hello, I didn’t succeed in feeling like, but it doesn’t matter, I’ll leave it like that…
                        if I understood correctly I need to keep my MM up to date, do I need to run your script every 3 months or is there a solution to do it automatically and is it also possible for the mirror modules?
                          Manu85 @sdetweil
                          @sdetweil I got a weather module update alert, I tried to update, but I got this error message, did I do something wrong?
                          pi@MagicMirror:~/MagicMirror/modules/MMM-OneCallWeather $ git pull
                          Depuis https://github.com/KristjanESPERANTO/MMM-OneCallWeather
                             f7f964d..0069540  main       -> origin/main
                          Mise ▒ jour f7f964d..0069540
                          error: Vos modifications locales aux fichiers suivants seraient ▒cras▒es par la fusion▒:
                                  MMM-OneCallWeather.js
                                  package-lock.json
                          Veuillez valider ou remiser vos modifications avant la fusion.
                          Abandon
                            sdetweil @Manu85
                            @Manu85 said in Changing icons of the modules Current Weather and Weather Forecast:
                            because you changed it.
                            git checkout MMM-OneCallWeather.js
                            remember, never change module code, all config goes in config.js
                            tempUnits: "metric"
                            NOT “C”
                            package-lock.json, erase it then git pull
                              Manu85 @sdetweil
                              @sdetweil If I understood correctly it is that I changed something in ```
                              I understand that you are saying that I changed the value from ```
                              tempUnits: "metric"
                              ``` to ```
                              tempUnits: "c"
                              ```? I didn't touch it, it's like that in the file (I gave you a screenshot from github) and I promise you that I understand that nothing should be changed in these folders.
                              so now I have to pass the line: ```
                              and then I delete: package-lock.json and then I do git pull, should I put: ```
                              tempUnits: "metric"
                              ``` so different from what is in the ```
                                Manu85 @sdetweil
                                  sdetweil @Manu85
                                  @Manu85 ok, got confused with default weather module using same property
                                  “C” is correct
                                    Manu85 @sdetweil
                                    @sdetweil it’s ok, I did as you told me and everything is in order, when you have a moment can you answer my previous question about updates if you can like it?
                                      Manu85 @sdetweil
                                      @sdetweil I have AGAIN one question I would like to change the size of the weather forecat icons, by opening the console (crtl+shift+i) I see that if I change the number (highlighted in yellow) it changes the size of the icon, for example against I don’t know how to put this in the custom css
                                        sdetweil @Manu85
                                        @Manu85 yes, I think you correct.on updated. I see he fixed the colored property and you updated the module.
                                          sdetweil @Manu85
                                          @Manu85 icon size swipe to mark that stuff in the upper right box, ctrl-c to copy
                                          in your editor open on
                                          custom.css at the bottom
                                          paste it in
                                          and put the proper selector around it
                                          maybe
                                          .weather .icon {
                                          what was the stuff on the line you selected. hard to see here on my phone (img?)
                                            Manu85 @sdetweil
                                            @sdetweil the selected content is as follows, if I put for example 64 instead of 44 the icon is enlarged
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 13 / 16
