    Changing icons of the modules Current Weather and Weather Forecast
    301 Posts 30 Posters 1.7m Views 33 Watching
      Manu85 @sdetweil
      @sdetweil it’s ok, I did as you told me and everything is in order, when you have a moment can you answer my previous question about updates if you can like it?
        Manu85 @sdetweil
        @sdetweil I have AGAIN one question I would like to change the size of the weather forecat icons, by opening the console (crtl+shift+i) I see that if I change the number (highlighted in yellow) it changes the size of the icon, for example against I don’t know how to put this in the custom css
          sdetweil @Manu85
          @Manu85 yes, I think you correct.on updated. I see he fixed the colored property and you updated the module.
            sdetweil @Manu85
            @Manu85 icon size swipe to mark that stuff in the upper right box, ctrl-c to copy
            in your editor open on
            custom.css at the bottom
            paste it in
            and put the proper selector around it
            maybe
            .weather .icon {
            what was the stuff on the line you selected. hard to see here on my phone (img?)
              Manu85 @sdetweil
              @sdetweil the selected content is as follows, if I put for example 64 instead of 44 the icon is enlarged
                sdetweil @Manu85
                @Manu85 i meant the html view item
                we need to make a selector clause in the custom.css to select JUST the icon images, right
                .weather img ???? {
                the stuff from the tip right box, pasted in here
                you don’t want EVERY img in weather…
                  Manu85 @sdetweil
                  @sdetweil I just want to enlarge these images, tell me what elements you need because I cannot select the entire line of icons I can only select one in the console with ctrl shift i
                    sdetweil @Manu85
                    @Manu85 it has a class weather-icon
                    so you want the img under weather-icon under the weather module (I think)
                    .weather .weather-icon img {
                    your stuff
                      sdetweil @Manu85
                      @Manu85 so you put that into custom.css and hit refresh(f5) on the dev window to see the results
                        Manu85 @sdetweil
                        @sdetweil I hope I expressed myself well, I want to enlarge the weather icons for each day of the week
                          sdetweil @Manu85
                          @Manu85 yes each icon uses the same weather-icon class. not just one
                          try it
                            Manu85 @sdetweil
                            @sdetweil I put this in custom.css?
                              sdetweil @Manu85
                              @Manu85 AND the sizing stuff u created n the developer console upper right window inside the braces, copy/paste
                              swipe them with the mouse, copy
                                Manu85 @sdetweil
                                @sdetweil I copied this line because it’s the one that enlarges the icon in the console, I put that in css.custom and it’s still the same
                                   max-width: 64px;
                                default is 44px
                                when I refresh the console page and I select the icon I don’t have any additional css.custom lines, I don’t know if my explanation is clear
                                  sdetweil @Manu85
                                  @Manu85 should be a strike thru on the 44px
                                  did u save the custom.css?
                                    Manu85 @sdetweil
                                    @sdetweil yes, I saved the custom and when I type 64px instead of 44px I see the icon growing, but that doesn’t change anything and in the console window it’s always the same data
                                      sdetweil @Manu85
                                      @Manu85 ok hang on. I’ll get my laptop …
                                        Manu85 @sdetweil
                                        @sdetweil OK thanks
                                          sdetweil @Manu85
                                          @Manu85 ok, i think this is what you want
                                          1. add
                                          classes:"forecast",
                                          the the weather forecast , after the module:“weather”, line
                                          1. then add this to custom.css
                                          .forecast .weathericon {
                                              font-size: 125%;
                                          you can change the font-size bigger too
                                          refresh the mm page
                                          M M 2 Replies Last reply Reply Quote 0
                                            manu85340 @sdetweil
                                            @sdetweil ok thanks I’ll try that when I get home
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 14 / 16
