    Google Calendar issues
    17 Posts 3 Posters 5.3k Views 3 Watching
      sdetweil @1lolo94
      @1lolo94 ok that’s not the default calendar, so I don’t know.
        @1lolo94 if you use the url in a browser does it download the ICS file?
        1 1 Reply Last reply Reply Quote 0
        • 1 Offline
          1lolo94 @sdetweil
          @sdetweil Yes it does.
            sdetweil @1lolo94
            @1lolo94 can u show the messages were you start mm, npm start .
            if you use pm2, then
            pm2 logs --lines=50
            1 2 Replies Last reply Reply Quote 0
            • 1 Offline
              1lolo94 @sdetweil
              @sdetweil - can you explain more on what you’re requesting? Sorry!! I just started all this last night
                sdetweil @1lolo94
                @1lolo94 when MagicMirror starts, using the command npm start, the components that run on the server side output message to the terminal window.
                if you used my script to install, and said yes to use pm2 to autostart,
                then the pm2 command launches a little script, which issues the npm start command, and captures that output for display or review later.
                then you can use the command
                pm2 logs --lines=nnn
                where nnn is a number of lines to display. default 15
                one thing to know about Linux.
                by convention, each command outputs it’s command parms when executed with --help
                so
                pm2 --help
                • 1 Offline
                  1lolo94 @sdetweil
                  @sdetweil tried it and this is what i see
                  [28.01.2024 19:05.36.543] [INFO] updatenotification: You are not using pm2
                    sdetweil @1lolo94
                    @1lolo94 need more lines
                    • 1 Offline
                      1lolo94 @sdetweil
                      magicmirror@2.26.0 start
                      [28.01.2024 19:05.32.973] [LOG] Starting MagicMirror: v2.26.0
                      [28.01.2024 19:05.32.981] [LOG] Loading config …
                      [28.01.2024 19:05.32.986] [DEBUG] config template file not exists, no envsubst
                      [28.01.2024 19:05.32.993] [LOG] Loading module helpers …
                      [28.01.2024 19:05.32.996] [LOG] No helper found for module: alert.
                      [28.01.2024 19:05.33.066] [LOG] Initializing new module helper …
                      [28.01.2024 19:05.33.067] [LOG] Module helper loaded: updatenotification
                      [28.01.2024 19:05.33.069] [LOG] No helper found for module: clock.
                      [28.01.2024 19:05.33.070] [LOG] No helper found for module: MMM-MonthlyCalendar.
                      [28.01.2024 19:05.33.073] [LOG] No helper found for module: weather.
                      [28.01.2024 19:05.33.074] [LOG] All module helpers loaded.
                      [28.01.2024 19:05.33.091] [LOG] Starting server on port 8080 …
                      [28.01.2024 19:05.33.494] [LOG] Server started …
                      [28.01.2024 19:05.33.496] [LOG] Connecting socket for: updatenotification
                      [28.01.2024 19:05.33.498] [LOG] Starting module helper: updatenotification
                      [28.01.2024 19:05.33.499] [LOG] Sockets connected & modules started …
                      [28.01.2024 19:05.33.535] [LOG] Launching application.
                      [28.01.2024 19:05.36.493] [INFO] updatenotification: Updater Class Loaded!
                      [28.01.2024 19:05.36.494] [INFO] updatenotification: Checking PM2 using…
                      [28.01.2024 19:05.36.681] [INFO] Checking git for module: MMM-MonthlyCalendar
                      [28.01.2024 19:05.36.718] [INFO] Checking git for module: MagicMirror
                      [28.01.2024 19:05.40.617] [LOG] Shutting down server…
                      [28.01.2024 19:05.40.618] [LOG] Stopping module helper: updatenotification
                      [28.01.2024 19:05.40.619] [LOG] Node_helpers stopped …
                        sdetweil @1lolo94
                        @1lolo94 said in Google Calendar issues:
                        MMM-MonthlyCalendar
                        ok, that is an add on calendar module
                        which appears to do all its operations in the browser side.
                        so on the running mm screen, press ctrl-shift-i ,
                        to open the developers window, and the select the console tab, and enter a unique part of the module name in the filter field, to show just the messages from that module , so month
