    MMM-Pir Issue
    4 Posts 3 Posters 1.0k Views 3 Watching
    • Feedy88F Offline
      Feedy88
      Hi all,
      I have issues with the MMM-Pir module. I recently finished my mirror and put it onto the wall which all worked fine but it randomly shutdown. I have no idea why that happend but I found out it happend when I manage the start of Magic Mirror with pm2, but not when manually starting with “npm run” in a screen or with nohup, so I decided to move away from pm2 and created a systemd unit instad. So far, so good.
      As I didn’t need pm2 I removed it from the raspi. Starting the Mirror with the Unit work fine but on Startup I see an Error Message from the PIR module that 1 needed Library is not loaded. The popup on top on starting up shows it is onoff. I tried rebuilding MMM-Pir and also manually installing onoff with the global flag but no with no avail.
      So the main two changes between WAI and not working at all are
      • Uninstall of pm2
      • changing the address in the config from localhost to 0.0.0.0
      Config for Pir Module:
      	module: 'MMM-Pir',
      	position: 'top_right',
      	  debug: false,
      	  delay: 2 * 60 * 1000,
      	  turnOffDisplay: true,
      	  mode: 9,
      	  ecoMode: true,
      	  displayCounter: true,
      	  displayBar: true,
      	  displayStyle: "Text",
      	  displayLastPresence: tru
      	  lastPresenceTimeFormat:
      	  mode6_gpio: 20,
      	  mode6_clearGpioValue: tr
      	  pir_gpio: 18,
      	  pir_reverseValue: false,
      	  xrandrForceRotation: "no
      	  //wrandrForceRotation: "
      Can anyone help how I can get the Pir Module woring again? Happy to provide logs and config if needed. Thanks!
      kayakbabeK 1 Reply Last reply Reply Quote 0
      • kayakbabeK Offline
        kayakbabe @Feedy88
        @Feedy88 said in MMM-Pir Issue:
        localhost is normally the same as 127.0.0.1 for most computers. Why are you wanting it to be 0.0.0.0?
        • bugsounetB Offline
          bugsounet Banned
          Hi, npm run rebuild command inside MMM-Pir folder will help
          Feedy88F 1 Reply Last reply Reply Quote 0
          • Feedy88F Offline
            Feedy88 @bugsounet
