    MM-GoogleAssistant Error: Unexpected end of JSON input
    6 Posts 2 Posters 897 Views 2 Watching
      dood
      I have followed the guide and get al lthe way to the end without any issues until I go to generate a token
      I have rebuilt the credentials in google cloud and redownloaded several times and still get this error
      Can anyone point me in th right direction please ?
      Thank you
      Welcome to MMM-GoogleAssistant Token generator!
      Note: The choice expects [Y or N] and does not need [Enter] to confirm
      Do you want to install/reinstall MMM-GoogleAssistant token? [Y/n]
      Your choice: Y
      [GA] SyntaxError: /home/magicmirror/MagicMirror/modules/MMM-GoogleAssistant/credentials.json: Unexpected end of JSON input
      code_text
        dood
        Please mark this topic as solved.
        The only thing I can figure is that it too some time to propagate maybe ?
        I haven’t changed anything yet this morning it was able to generate the token without any issues
        Thank you for the help :)
          sdetweil @dood
          @dood did you select the correct type on the cloud config? the credentials file has different formats depending on the type you select
            dood @sdetweil
            @sdetweil Yes, its set as Web Application in CLoud config.
            I followed the guids located here
            https://wiki.bugsounet.fr/en/MMM-GoogleAssistant
              sdetweil @dood
              @dood if you edit the credentials.json file, I think it should say web:{
              to start…
                dood @sdetweil
                @sdetweil It does.
                If it helps here is the full contents of the credentials.json file
                I have completely started from scratch 3 times now, those three times ere al lthe way from installing OS to this step. I have went back and reconfigured and redownloaded the json file at least 5 times and still exact same error, in exactly the same place
                my os is
                magicmirror@magicmirror:~$ uname -a
                Linux magicmirror 6.1.0-17-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.1.69-1 (2023-12-30) x86_64 GNU/Linux
                magicmirror@magicmirror:~$ lsb_release -a
                No LSB modules are available.
                Distributor ID: Debian
                Description:    Debian GNU/Linux 12 (bookworm)
                Release:        12
                Codename:       bookworm
                {"web":{"client_id":"457148194700-qvcm.apps.googleusercontent.com","project_id":"ace-beanbag-413106","auth_uri":"https://accounts.google.com/o/oauth2/auth","token_uri":"https://oauth2.googleapis.com/token","auth_provider_x509_cert_url":"https://www.googleapis.com/oauth2/v1/certs","client_secret":"**REMOVED","redirect_uris":["https://googleassistant.bugsounet.fr"]}}
                  dood
