    MMM-CalendarExt3Agenda Only loading a few items.
    14 Posts 3 Posters 6.0k Views 3 Watching
      schwarem
      I am rebuilding my Magic Mirror with the new CalendarExt3Agenda control after having used the CalendarExt2 controls for years to manage my multiple family calendars and activities. I can’t get all the entries to show up on the CalendarExt3Agenda control. It sometimes loads one or two of the calendar events from the Soccer calendar, but none from the others. Below is a screenshot with the basic calendar control shown and the CalendarExt3Agenda section of my config file. What am I missing?
      			//hiddenOnStartup: true,
      			config:
      			broadcastPastEvents: false,
      			calendars:
      					url: "https://calendar.google.com/calendar/file.ics",
      					color: "Magenta",
      					maximumEntries: 100,
      					symbol: 'person-dress',
      					color: "Green",
      					symbol: 'futbol',
      			module: "MMM-CalendarExt3Agenda",
      			title: "Family Agenda",
      			config:
      				useWeather: false,
      				showMiniMonthCalendar: false,
      S M 2 Replies Last reply
        sdetweil @schwarem
        @schwarem bug in 2.26, maximumEntries not by calendar url… only overall, above the calendars list
          schwarem @sdetweil
          I switched it to only about the calendar list, but I still have the same issue.
          			config:
          			fade: false,
          			coloredText: true,
          			maximumEntries: 15,
          			showLocation: true,
          			calendars:
            sdetweil @schwarem
            @schwarem ok, try the prior parser
            npm install node-ical@0.16.1
            restart MagicMirror
              schwarem @sdetweil
              Thanks for the update. Still no luck.
                sdetweil @schwarem
                @schwarem can you show the messages from npm start where the deault calendar module says how many events it broadcast.
                like
                Calendar-Fetcher: Broadcasting 11 events from https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics.
                  schwarem @sdetweil
                  Below is the screenshot. It is loading everything, but not displaying in CalendarExt3. I also noticed in the debug console there was the message below. I don’t know what it means.
                    sdetweil @schwarem
                    @schwarem i erased your image, one line at top had full url, please fix and then edit post and add it back in
                    did you do
                    npm install
                    in the module folder after git clone??
                      schwarem @sdetweil
                      @sdetweil Yes. and I just ran it again.
                        sdetweil @schwarem
                        @schwarem it should have done the extension install too
                          MMRIZE @schwarem
                          @schwarem
                          Only events from some specific calendars seem being missed.
                          Usually, that case happens when CX3* will be displayed before all the calendars’ fetching is completed.
                          Give enough waitFetch of CX3*'s config. By default, it would be 5000ms(5 sec). I think 10_000 or something may be enough for you.
                          Generally, 5 seconds is enough for most of the environment, but in some low-powered devices, too many calendars or events, slow internet speed or many various other reasons could make the case.
                            MMRIZE @schwarem
                            @schwarem said in MMM-CalendarExt3Agenda Only loading a few items.:
                            Not error, just info. You can ignore it.
                              schwarem @MMRIZE
                              @MMRIZE
                              Increasing the WaitFetch worked. Thanks to everyone for the suggestions.
                              By the way, I have a Raspberry Pi 4 B with 1 gb of RAM which had enough power for CalendarExt2.
                              M 1 Reply Last reply
                                MMRIZE @schwarem
                                @schwarem
                                That’s not your or your RPI’s fault. :)
                                With your previous log image, at least 7 calendars had to be parsed. The first calendar (12 events) was fetched on 11:06:27, and the last calendar(93 events) was fetched on 11:06:40. These 7 calendars need almost 13 seconds to parse completely.
                                But CX3* would appear after 5 seconds(by default) from the first fetching. Nobody can’t foresee when the last calendar will finish the fetching (or even whether it is complete or not). So CX3* will wait a few seconds and then show only the events from the current aggregated regardless of whether some unfetched calendars remain.
                                CX2 parsed events of the calendar by itself so it could know whether all events were fetched or not.(At least I made so), but CX3 doesn’t parse the calendar, only using the feed from another module. That’s the difference.
                                No worry. Until the next cycle(defined by refreshInterval), the unfetched calendars would be fetched until then. In the following refreshInterval, your missing events will be shown adequately.
                                Or, increase waitFetch to wait more seconds for more calendars to fetch.
                                • C Como referenced this topic on
