    Installation issues - pm2
    18 Posts 2 Posters 6.1k Views 2 Watching
      joebowers
      I’m trying to get my pi3 a+ setup to run the Magic Mirror software.
      I am new to raspberry pi in general, so I’m not very flexible when I run into problems.
      In following this tutorial: https://www.raspberrypi.com/tutorials/how-to-build-a-super-slim-smart-mirror/
      Everything is going well until I need to type pm2 start mm.sh
      The tutorial says Magic Mirror software should start running, but all I see is this:
      I have no idea what to do next. I search the forum for similar issues, but the solutions were given back in 2017 and don’t seem to apply now.
      Any help is appreciated, and you’ll have to give me the dummy version.
      Thank you!
      -Joe
        sdetweil @joebowers
        @joebowers
        so let’s try without pm2 and see what happens.
        npm start
          joebowers @sdetweil
          @sdetweil Hey thanks for the reply. I tried that and the Magic Mirror software does load.
            sdetweil @joebowers
            @joebowers ok, can u show the mm.sh you created?
            and compare to the one we ship in
            ~/MagicMirror/installers, that I use when setting up pm2 in my install script…
              joebowers @sdetweil
              @sdetweil This was mine:
              cd ./MagicMirror
              DISPLAY=:0 npm start
              And this was the one on git hub:
              I was using a . instead of ~
              I switched it to ~ and tried again. Now I see this, the mirror software doesn’t load though.
                sdetweil @joebowers
                @joebowers ok, now lets look at the pm2 log…
                pm2 logs --lines=50
                50 may need to be bigger… defaults to 15
                there are two different outputs… the normal messages (stdout) and the error (stderr)
                the files for the saved logs are in the .pm2/logs folder (note the . in front of pm2)
                did you install MM under root?? the permissions thing is concerning…
                  joebowers @sdetweil
                  @sdetweil I tried to follow the tutorial step by step. I’m not sure if that has be installing as root.
                  This is what I see when I look at the log.
                  This was the most I could screen shot, this log was very long.
                    sdetweil @joebowers
                    @joebowers /home/joe/MagicMirror/mm.sh no such file
                    is that where the file is?
                    does it have permission to execute?
                    ls -laF mm.sh
                    so,
                    chmod +x mm.sh
                      joebowers @sdetweil
                      @sdetweil I was fooling around before coming to this forum for help. I believe I copied the mm.sh file into that folder, then later removed it. I put it back and saw this in the log:
                      Then I realized I have a space after DISPLAY =, and there is no space between the two in the tutorials.
                      So I fix that and tried running again, I see this:
                      But no mirror software on the screen…
                        sdetweil @joebowers
                        @joebowers ok
                        pm2 stop all
                        pm2 flush
                        then execute mm.sh
                        cd ~
                        MagicMirror/mm.sh
                          joebowers @sdetweil
                          @sdetweil Okay I did all that and the Magic Mirror software starts.
                          Should I try:
                          pm2 start mm.sh
                          pm2 save
                          As stated in the tutorial?
                            sdetweil @joebowers
                            @joebowers we should clean up the other entries
                            I think it
                            pm2 delete row_number
                            (you could use name if the names were unique)
                            pm2 --help
                            will tell you the command syntax
                            pm2 start mm.sh
                            if you are in the folder w the mm.sh
                              joebowers @sdetweil
                              @sdetweil Okay I deleted all the rows, there were 4 of them.
                              Then I run
                              pm2 start mm.sh
                              No mirror software but I see this
                                joebowers @sdetweil
                                @sdetweil In case it helps, I’m seeing this in the pm2 logs
                                  sdetweil @joebowers
                                  @joebowers why are you running at root?
                                    joebowers @sdetweil
                                    @sdetweil I have no idea. This is where I end up when following this tutorial step by step.
                                    Sometimes I I get this message: pm2 root.jpg
                                    So I type in what is suggested to continue, I assume that makes me root??
                                    I assume the tutorial, if followed exactly, should work.
                                    Either it’s not fool proof, or I missing an important step.
                                    Everything I’ve done is on a new raspberry pi.
                                      sdetweil @joebowers
                                      @joebowers I don’t know anything about the tutorial you are following.
                                      my recommendation is to start with a fresh sd card flash of the appropriate os. boot, skip updates. open a terminal window or use ssh
                                      and then use my script to to install MagicMirror and setup pm2
                                      see
                                      I have never seen a tutorial document maintained, and things change constantly.
                                      once MagicMirror is running and starting on boot, then you can go back to configuring MagicMirror
                                        joebowers @sdetweil
                                        @sdetweil Sounds like a good plan.
                                        It does feel like these tutorials are not maintained, there’s always a step that doesn’t work. I’ve tried two now.
                                        Thanks for all your help. I’ll let you know if all goes well.
