    Best practice 'package-lock.json' for modules
    18 Posts 5 Posters 10.9k Views 5 Watching
      sdetweil @KristjanESPERANTO
      @KristjanESPERANTO but something else will over the months. and we have to retrain all our users.
      • KristjanESPERANTOK Offline
        “something else” will change the package-lock.json? How can that happen?
        This is certainly a considerable disadvantage compared to approach 1.
          @KristjanESPERANTO said in Best practice 'package-lock.json' for modules:
          someone will forget to be in the modules folder and poof it happens at the root…
          JalibuJ 1 Reply Last reply Reply Quote 0
          • JalibuJ Offline
            Jalibu Module Developer @sdetweil
            It is generally recommended best practice to check-in the package-lock.json for node modules.
            However, I in our case of MM-Modules the disadvantages clearly outweigh the expected advantages in my opinion.
            In my modules, it is therefore part of .gitignore
            KristjanESPERANTOK mumblebajM 2 Replies Last reply Reply Quote 1
              KristjanESPERANTO Module Developer @Jalibu
              @Jalibu I just wanted to point you to this conversation. Thanks for your feedback! :-)
              I’m thinking about adding a check for it to my project.
              • mumblebajM Offline
                mumblebaj Module Developer @Jalibu
                My 2 cents worth.
                @Jalibu I agree with your view.
                It is highly recommended you commit the generated package lock to source control: this will allow anyone else on your team, your deployments, your CI/continuous integration, and anyone else who runs npm install in your package source to get the exact same dependency tree that you were developing on.
                See npm documentation
                @KristjanESPERANTO Personally I always add it to .gitignore along with node_modules folder.
                  sdetweil @mumblebaj
                  @mumblebaj right it’s good for teams and automated test. but not here.
                  os at different levels, architectures, node levels.
                  I test on Jetson nano, odroid the entire pi family, amd64, arm64, lots of different Linux OS es, virtual machines on amd and arm
                  package-lock is useless and an inhibitor.
                  modules should NEVER ship it.
                    Wouldn’t that also be a good idea for the core? It would probably make sense to use the same strategy for the core as for the modules.
                    @rejas @karsten13
                      @KristjanESPERANTO well we use it to control the test platforms. but you can’t delete it for clone
                        @KristjanESPERANTO i just did an npm ci in a module folder with no package-lock.json and it complained that it required package-lock.json
                        pi@raspberrypi5:~/Documents/MagicMirror/modules/MMM-Soliscloud $ npm ci
                        npm ERR! code EUSAGE
                        npm ERR!
                        npm ERR! The `npm ci` command can only install with an existing package-lock.json or
                        npm ERR! npm-shrinkwrap.json with lockfileVersion >= 1. Run an install with npm@5 or
                        npm ERR! later to generate a package-lock.json file, then try again.
                        npm ERR!
                          That’s the point of npm ci it takes the package-lock.json to install and it don’t change it.
                            KristjanESPERANTO Module Developer @KristjanESPERANTO
                            Can you show me where?
                            S karsten13K 2 Replies Last reply Reply Quote 0
                              @KristjanESPERANTO in the npm install on the different test instances. I don’t build those
                              these are effectively docker images, build and execute, throw away
                              • karsten13K Offline
                                karsten13 @KristjanESPERANTO
                                we don’t use npm ci but I’m not sure what npm install does if package-lock.json is present.
                                I do the tests after building my docker images on my own and I always delete package-lock.json before running npm install to be sure getting the newest deps.
                                  sdetweil @karsten13
                                  @karsten13 package-lock is SUPPOSED to insure installing EXACTLY those versions every time
