    Best practice 'package-lock.json' for modules
    18 Posts 5 Posters 12.0k Views 5 Watching
    • mumblebajM
      mumblebaj Module Developer @Jalibu
      My 2 cents worth.
      @Jalibu I agree with your view.
      It is highly recommended you commit the generated package lock to source control: this will allow anyone else on your team, your deployments, your CI/continuous integration, and anyone else who runs npm install in your package source to get the exact same dependency tree that you were developing on.
      See npm documentation
      @KristjanESPERANTO Personally I always add it to .gitignore along with node_modules folder.
        sdetweil @mumblebaj
        @mumblebaj right it’s good for teams and automated test. but not here.
        os at different levels, architectures, node levels.
        I test on Jetson nano, odroid the entire pi family, amd64, arm64, lots of different Linux OS es, virtual machines on amd and arm
        package-lock is useless and an inhibitor.
        modules should NEVER ship it.
        KristjanESPERANTOK 1 Reply Last reply
        • KristjanESPERANTOK
          Wouldn’t that also be a good idea for the core? It would probably make sense to use the same strategy for the core as for the modules.
          @rejas @karsten13
          S 2 Replies Last reply
            sdetweil @KristjanESPERANTO
            @KristjanESPERANTO well we use it to control the test platforms. but you can’t delete it for clone
              @KristjanESPERANTO i just did an npm ci in a module folder with no package-lock.json and it complained that it required package-lock.json
              pi@raspberrypi5:~/Documents/MagicMirror/modules/MMM-Soliscloud $ npm ci
              npm ERR! code EUSAGE
              npm ERR!
              npm ERR! The `npm ci` command can only install with an existing package-lock.json or
              npm ERR! npm-shrinkwrap.json with lockfileVersion >= 1. Run an install with npm@5 or
              npm ERR! later to generate a package-lock.json file, then try again.
              npm ERR!
                That’s the point of npm ci it takes the package-lock.json to install and it don’t change it.
                  KristjanESPERANTO Module Developer @KristjanESPERANTO
                  Can you show me where?
                  S karsten13K 2 Replies Last reply
                    @KristjanESPERANTO in the npm install on the different test instances. I don’t build those
                    these are effectively docker images, build and execute, throw away
                    • karsten13K
                      karsten13 @KristjanESPERANTO
                      @KristjanESPERANTO said in Best practice 'package-lock.json' for modules:
                      we don’t use npm ci but I’m not sure what npm install does if package-lock.json is present.
                      I do the tests after building my docker images on my own and I always delete package-lock.json before running npm install to be sure getting the newest deps.
                        sdetweil @karsten13
                        @karsten13 package-lock is SUPPOSED to insure installing EXACTLY those versions every time
