    MMM-PGA Not Working
    13 Posts 4 Posters 2.1k Views 4 Watching
    • N Offline
      Notas1
      Re: MMM-PGA
      I am extremely new to MM and coding. I want to add this module but can’t get it to work. I got the API key and added to config.js. Does anyone have this running and share your module code in config.js to see what I am doing wrong?
      S mumblebajM 3 Replies Last reply Reply Quote 0
        sdetweil @Notas1
        @Notas1 see
        https://forum.magicmirror.builders/topic/13733/mmm-pga/41?page=5
          sdetweil @Notas1
          @Notas1 I rejected your second post.
          for users with reputation under 2, all posts are reviewed before appearing in the forums. this helps keep out the inappropriate content.
          I review every such post ( and sometimes am doing other things. sleeping… traveling… going to the grocery store). so, be patient
          • N Offline
            Notas1 @sdetweil
            @sdetweil OK. Thanks
            • mumblebajM Offline
              mumblebaj Module Developer @Notas1
              @Notas1 You can get a working fork of the module here. I have recently made loads of changes to bring it to the new age. :-)
              You can have a try with it.
              N D 2 Replies Last reply Reply Quote 1
              • N Offline
                Notas1 @mumblebaj
                @mumblebaj Thanks! I’ll reach out if I am having any issue. Appreciate the assist!
                  dathbe @mumblebaj
                  @mumblebaj i posted an issue with a fix in your repository. do you mind taking a look so we can merge the two lines?
                  https://github.com/mumblebaj/MMM-PGA/issues/2
                  mumblebajM 2 Replies Last reply Reply Quote 0
                    mumblebaj Module Developer @dathbe
                    @dathbe Hi. Unfortunately I did not get those notifications. You can submit a PR and I will review for you.
                      dathbe @mumblebaj
                      @mumblebaj No problem. I had the same problem on my repositories until I realized that I have to actively sign up for alerts. You can do that by clicking on the “Watch” icon at the top of the repository page, and then clicking either “All Activity” or “Custom” (and then selecting “Issues” and Pull Requests").
                      I’ve submitted a PR.
                      I will also submit a couple others to fix some console errors and get rid of the node-fetch dependency, though those issues are not breaking, so less important.
                        @dathbe I have updated and pushed update v1.3.2. Please test and advise.
