    Notification customize
    10 Posts 2 Posters 1.8k Views 2 Watching
    • F Offline
      fischi87 @MMRIZE
      @MMRIZE
      The Problem is, when i send just the Alert without the notification Type, the alert Display in Center with a other Looks Like. So i think this Are 2 different things. I want the different between notification and the alert.
      I work with notification from other modules?
        MMRIZE @fischi87
        @fischi87
        So, what you want is this kind? Instead of top position than bottom position?
        You can override most of presentation with css.
        Append this into your custom.css
        /* css/custom.css */
        .ns-box {
          position: absolute;
          left: 0;
          right: 0;
          bottom: 10px;
        .ns-effect-slide-center.ns-show {
          animation: new-anim-slide-elastic-center 1s ease;
        @keyframes new-anim-slide-elastic-center {
          0% {
            opacity: 0;
            transform: translateY(100%);
          90% {
            opacity: 1;
            transform: translateY(-20px);
          100% {
            opacity: 1;
            transform: translateY(0);
        You may need hiding animation. guess it by yourself. :)
        • F Offline
          fischi87 @MMRIZE
          @MMRIZE
          thanks that looks fine and this is a alert or alert with type notification? because i need the type notification. if i get more than one notification the alert displayed just the last one and the notification more than just one. u know what i mean?
            MMRIZE @fischi87
            @fischi87
            It is for type: 'notification'.
            I used this;
            this.sendNotification('SHOW_ALERT', {
                    type: 'notification',
                    title: 'Test Module',
                    message: 'I am a test notification',
                    timer: 10000,
              MMRIZE @fischi87
              @fischi87
              But what you want is a stackable something; it needs another CSS modification. (I thought only single notification case.)
              • F Offline
                fischi87 @MMRIZE
                @MMRIZE
                i will give it a try later with ur css data and let u know if its work. thank man.
