    Calendar / CalendarExt3 Font-Color and Symbol
    13 Posts 3 Posters 12.4k Views 3 Watching
      sdetweil @svenpisa
      @svenpisa the eventTransformer goes in the Ext3 config.js, not in css. it is code.
      effectively the same code as in the default calendar. check the subject and set the color and symbol if you want different than what calendar sends
      calendar sends the hard coded values from config.js.
        svenpisa
        Do you mean that what I have entered in the standard calendar module can simply be entered in the Ext3 module in Config.js? That simple?
        						customEvents: [{keyword: "Gelber Sack", symbol: "arrow-spin", color: "yellow"},
        						{keyword: "Hausmüll", symbol: "trash-can", color: "green"}],
          sdetweil @svenpisa
          @svenpisa no… similar but different
          in Ext3 is a function instead of a black of values
          eventTransformer: (ev) => {
            if (ev.title.search("Gelber Sack") > -1) ev.color = 'yellow'  // you would need a line like this for each color thing u want to change
          // and symbol
            return ev
            svenpisa
            Good morning,
            I worked on it again last night and the colors are now partially working… ;-).
            But I still can’t see any symbols.
            My Config.js now looks like this
            				if (ev.title.search("Gelber Sack") > -1) ev.symbol = ['trash-can']
            				if (ev.title.search("Blaue Tonne") > -1) ev.color = 'blue'
            				if (ev.title.search("Fitness") > -1) ev.color = 'pink'
            				return ev
            But now I get the following result
            The following problems occur.
            1. all-day event such as “Gelber Sack” is well colored yellow. Everything is fine.
            2. if I use ev.sybol = ‘trash-can’ my calendar module is no longer displayed, but if I use ev.symbol = [‘trash-can’] the entry is displayed without a symbol.
            3. for “Fitness” I have selected the color “pink”. However, the “Fitness” entry is not colored pink, only the symbol. How do I make the font pink?
            And finally, one more question:
            If I abbreviate a birthday with “Geb.” and want to see the “birthday-cake” symbol instead of “Geb.”, how would I have to execute the “Replace” entry?
              MMRIZE @svenpisa
              @svenpisa
              	module: "MMM-CalendarExt3",
              	position: "bottom_bar",
              		... // other configs...
              			const customEvents = [
              				{ keyword: "Gelber Sack", symbol: "fas fa-arrows-spin", color: "yellow" },
              				{ keyword: "Hausmüll", symbol: "fas fa-trash-can", color: "green" },
              			const found = customEvents.find((condition) => {
              				return ev.title.search(condition.keyword) !== -1
              			if (found) {
              				ev.icon = [ found.symbol ]
              				ev.color = found.color
              			return ev
              PS. It was a somewhat late answer. For your new questions, I’ll reply again.
                MMRIZE @svenpisa
                @svenpisa
                Broadcasted events information from default calendar module is not so well-formed. You should use like this.
                ["fa-solid fa-trash-can"]
                I’m not sure somebody fix this issue, I reported long days ago. Anyway, until fix, use that way.
                That was my intention. (I hate colored text. :D)
                If you really want colored text, append belows into your css/custom.css
                /* custom.css */
                .CX3 .event.singleday .headline .title {
                  color: var(--calendarColor);
                Maybe this… (not tested)
                if (ev.title.search('Geb.') !== -1) {
                  ev.title = ev.title.replace('Geb.', '')
                  ev.symbol = ["fas fa-birthday-cake"]
                  svenpisa @MMRIZE
                  @MMRIZE Many thanks for the quick reply, but unfortunately that didn’t work either.
                  This is how I stored it in Config.js
                  			title: "Kalender",
                  				mode: "week",
                  				useSymbol: true,
                  							{ keyword: "Gelber Sack", symbol: ["fa-solid fa-arrows-spin"], color: "yellow" },
                  							{ keyword: "Hausmüll", symbol: ["fa-regular fa-trash-can"], color: "green" },
                  							{ keyword: "Fitness", symbol: ["fa-solid fa-dumbbell"], color: "pink" },
                  						if (found) {
                  						return ev
                  result
                  The all-day events are yellow and green.
                  I can understand the colorful font, but then I’ll see how I can get it into the .CX3. Can you do it there only for the keywords or only completely? I just want Fitness to be pink but everything else to stay black or white.
                  Unfortunately, the desired symbols are still not displayed.
                  They still remain at "arrow-right as I set it in the module: “Calendar”.
                  I have tried it in the config with [] and also without. Both here the same result.
                  I’ll try the “replace” later. Thank you! :-)
                    MMRIZE @svenpisa
                    @svenpisa
                    Original. (All these test events are from the same calendar)
                    	if (ev.title.search('Fitness') !== -1) {
                    		ev.symbol = [ 'fa-solid fa-dumbbell' ]
                    		if (!ev.isFullday) ev.title = ev.title.replace('Fitness', '<font color="pink">Fitness</font>')
                    	return ev
                    After.
                      svenpisa @MMRIZE
                      @MMRIZE Awesome!!!
                      It’s awesome!!! Thank you very very much. It works perfectly.
                      Since I use both CalendarExt3 and CalendarExt3 Agenda, I have stored the key lines and if lines in both modules in the config.
                      For all-day events, the symbols are displayed in the calendar, but not in the agenda. And only for all-day events. But I don’t care. I’m happy.
                      Just in case you want to make an improvement here or I have made a mistake!!!
                      So thank you very much. I will post my project soon in the forum under “Show my Mirror” incl. all information from the config and custom.
                      Maybe someone will be interested… :-)
                      • J justme2024 referenced this topic on
