    MagicMirror stutters and doesn't run smoothly
    25 Posts 3 Posters 12.6k Views 3 Watching
      sdetweil @drx1984
      @drx1984 swap lines 4 and 5. and you forgot the ‘export’ keyword on line 5
      in Linux, by default environment variable are not passed to children processes
      and yes the script was mine.
        drx1984 @sdetweil
        aha ok, you mean like this:
          sdetweil @drx1984
          @drx1984 yes…
          then
          pm2 status
          to see what apps pm2 controls
          then
          pm2 restart xxx
          where xxx is the number on the row, or the name on the row
          examples
          pm2 restart 0
          or
          pm2 restart MagicMirror
            drx1984 @sdetweil
            @sdetweil OK, thanks, I’ll test it.
            Question: Is it possible to switch on exactly the same parameters for the GPU with MagicMirror in Windows?
            export ELECTRON_ENABLE_GPU=1 ?
              sdetweil @drx1984
              @drx1984 yes, you just don’t use the ‘export’ keyword on Windows
              we don’t supply a .cmd file for Windows, and I don’t provide the install script or install pm2.
              but its all the same functionally…
                drx1984 @sdetweil
                @sdetweil aha ok then to line 4:
                  sdetweil @drx1984
                  @drx1984 if you are running under windows native… you don’t need to run in lsr
                  if you ARE running under lsr, then u need the ‘export’
                  just open cmd.exe and follow instructions in doc…
                  have to manually install nodejs on windows and git.
                  then a windows mm.cmd file
                  @echo off
                  cd %home%\MagicMirror
                  npm start
                  then execute
                  %home%\mm.cmd
                    drx1984 @sdetweil
                    @sdetweil what do you mean by LSR? what does that mean?
                    I have now done this:
                    Of course, with “npm run server” it runs in the browser.
                    but how do I do it natively on the computer itself? When I enter the command “npm run start” there is an error in the cmd, something with the display.
                    I wonder if I did everything correctly, as you described it.
                      @drx1984 DISPLAY… you didn’t follow all the instructions …
                      see https://docs.magicmirror.builders/getting-started/installation.html#other-operating-systems
                      LSR (you can install the linux system runtime under windows too) …
                        sdetweil @drx1984
                        @drx1984 said in MagicMirror stutters and doesn't run smoothly:
                        i don’t understand your question…
                        MM is a browser app.
                        it runs in Electron, (default), Chromium, Firefox, Edge, Safari, Midori, …
