    Google Calendars not loading
    28 Posts 7 Posters 16.9k Views 7 Watching
    • V Offline
      valentindey
      Is there any update on this?
      I seem to have the same (or similar) issue on a Raspberry Pi 3. For me it’s just one out of a few calendars that isn’t working and I also get the vulkan error message.
      The calendar has been working before but I can’t seem to trace it back to a recent change.
      I already started MM with node option --dns-result-order=ipv4first as the calendars come from a Nextcloud instance which does not support ipv6.
        sdetweil @valentindey
        @valentindey we haven’t got a clear indication where the trouble is. is it in electron, ? or …
        did you try electron 28.1.1?
        npm install electron@28.1.1
        • V Offline
          valentindey @sdetweil
          @sdetweil yes, I tried an older version and the newer version of electron. So far to no avail.
          Checking the logs I see that events are fetched from the calendar in question, so it’s something about displaying them.
          Also, running the exact same setup on another machine works perfectly fine.
            @valentindey yeh, its weird for sure…
            lets go back to the prior parser
            npm install node-ical@0.16.1
            and restart MagcMirror
            eniacE V 2 Replies Last reply Reply Quote 0
            • eniacE Offline
              eniac @sdetweil
              @sdetweil said in Google Calendars not loading:
              let`s go back to the prior parser
              Does the Job. Thank you …
                sdetweil @eniac
                @eniac thanks for the feedback
                  shizzlesticks
                  I updated my MagicMirror this week and have been struggling to figure out why my Google calendars weren’t loading. It was the parser for sure… Thank you!
                  • V Offline
                    @sdetweil this works for me as well. Thanks a lot for the help, very much appreciated!
                      machine4500
                      helped for me too, thanks
                      • BKeyportB Offline
                        BKeyport Module Developer @machine4500
                        to everyone - Google Calendars and everything else Google has been struggling with outside tools across the board. They upgraded their login experience, and with that, broke all sorts of things - So much so, I had to go to Microsoft for my business.
                        Fixes may or may not actually be fixes.
