    MMM-CalendarExt3 Search description of event to trigger event color change.
    8 Posts 2 Posters 1.3k Views 2 Watching
      MMRIZE @Hobbit
      @Hobbit
      Show me your parts of config. You probably miss ‘return’ statements.
      • H Offline
        Hobbit @MMRIZE
        @MMRIZE Very possible. Thanks again for your time. If I use the normal .title everything works, but I switch to .description and nothing shows up at all in the calendar.
        miniMonthWeekdayOptions:{ weekday: 'short' },
            eventTransformer: (ev) => {
          if (ev.description.search('HL') > -1) ev.color = 'green'
          return ev
          MMRIZE @Hobbit
          @Hobbit
          Hmmm… you are using CX3? or CX3A? minimonth... options are for CX3A, not CX3
          Anyway,
          /* In your config.js */
          	module: "MMM-CalendarExt3",
          	position: "bottom_bar",
          			console.log(ev)
          			if (ev.description && ev.description.search('foo') > -1) {
          				ev.color = 'green'
          				ev.title = '[FOO] ' + ev.title
          			return ev
          • H Offline
            Hobbit @MMRIZE
            @MMRIZE I’m using CX3A, just the agenda part, I’ve got calendar displayed with only the events as dots. The script you send worked. I just removed the changing of the title,
            			console.log(ev)
            			if (ev.description && ev.description.search('HL') > -1) {
            				ev.color = 'green'
            			return ev
            This is what I was looking for. I did not know how to do whatever you did using console.log and the if{ e.description && …}. I’ll do some reading to try and understand that function. I appreciate it.
            For everyone else reading this in the future:
            I’m using the default calendar module to handle symbols for events in a category. example: band practice. I’m then using the Ext3 agenda function to list out by day. But then by adding the above function I’m only changing the color of the icon not the text of the event. This gives a subtle color scheme to the agenda calendar. This allows me to create events in my google calendar and display colors to represent different family members based on terms in the description and the symbols to represent category. This way I don’t need different calendars for separate people, I can manage all simply by putting their name or keyword in the description. This may not be the best way but this is the path I took to achieve it.
              MMRIZE @Hobbit
              @Hobbit
              console.log() was used just to check event object has which properties. You can remove that line.
              Sometimes, .description has no value at all, as false or null. In that case .description.search() couldn’t be perform, so whether check .description is not false or null at first hand. that’s all.
              Some enhanced features of my module require JS or CSS skills. So sorry.
