Push button (MMM-Buttons) does not send out notification to MMM-StopwatchTimer
11 Posts 2 Posters 1.3k Views 2 Watching
    changaud
    Hello all,
    I am working with the MMM-Buttons module to connect a push button to GPIO pin 25 (physical pin: 22) and have it start the stopwatch by notification. I tested my button using my terminal and found that it was connected fine, but when I set the configurations it does not do anything :(. Any help is much appreciated!
    Below is all I have modified.
    By the way, after major googling I found that the module uploaded by SmartMirror was buggy so I replaced it with this repository: https://github.com/sdetweil/MMM-Buttons.
    config.js file:
    			module: "MMM-StopwatchTimer",
    				animation: true,
    				sound: true,
    				soundFile: 'buzz.wav',
    				useNativeSound: true,
    				useAlertStyle: true,
    				//notification: ["START_STOPWATCH", "PAUSE_STOPWATCHTIMER"]
    		    	module: 'MMM-Buttons',
    			position: "middle_center",
    				buttons: [
    					pin: 25,
    					longPress: {
    					notification: "PAUSE_STOPWATCHTIMER",
    				    	payload: {action: "PAUSE_STOPWATCHTIMER"}
    					shortPress: {
    				    	notification: "START_STOPWATCH",
    				    	payload: {action: "START_STOPWATCH"}
    buttons.js file:
    Module.register("MMM-Buttons", {
        requiresVersion: "2.1.0",
        // Default module config.
        defaults: {
            buttons: [
    					pin: 25,
    					longPress: {
    					shortPress: {
            minShortPressTime: 0,
            maxShortPressTime: 500,
            minLongPressTime: 3000,
            bounceTimeout: 300
    S 1 Reply Last reply Apr 9, 2024, 12:30 PM Reply Quote 0
      sdetweil @changaud
      @changaud 1st, never edit a modules source file. all config goes in config.js
      did you use the right pin number
      C 1 Reply Last reply Apr 9, 2024, 8:10 PM Reply Quote 0
        changaud @sdetweil
        @sdetweil Thank you for your response! I will keep that in mind, but do I just leave the button configuration in the buttons module blank then? Also, I have it connected to the physical button 22 which translates to GPIO 25 so I wrote 25 down in the configuration file.
        S 2 Replies Last reply Apr 9, 2024, 8:24 PM Reply Quote 0
          sdetweil @changaud
          @changaud said in Push button (MMM-Buttons) does not send out notification to MMM-StopwatchTimer:
          you already put it in the config.js file
          				buttons: [
          					pin: 25,
          					longPress: {
          					shortPress: {
          config overrides whatever is defined in the source file defaults section
            sdetweil @changaud
            it was just a question… many starting users don’t know about the different numbering
            so, when u push the button, outside magic mirror it works…
            C 1 Reply Last reply Apr 9, 2024, 8:36 PM Reply Quote 0
              changaud @sdetweil
              @sdetweil Yes so weird and frustrating T^T… Here is a picture of my setup. In addition, sometimes I get the error (this image is also in the google drive) and sometimes I don’t. I think it goes away after I delete and reclone the buttons repository. https://drive.google.com/drive/folders/1y_QLDCuhfv9XELST0u2hwxTB4f3Fp4h9?usp=drive_link
              S 2 Replies Last reply Apr 9, 2024, 9:00 PM Reply Quote 0
                sdetweil @changaud
                is this a pi5?
                C 1 Reply Last reply Apr 9, 2024, 9:04 PM Reply Quote 0
                  changaud @sdetweil
                  @sdetweil This is a pi4 model b.
                    sdetweil @changaud
                    @changaud if you run your test script before launching mm does it work?
                    see this
                    https://github.com/Jopyth/MMM-Buttons/issues/20
                    C 1 Reply Last reply Apr 10, 2024, 2:17 AM Reply Quote 0
                      changaud @sdetweil
                      @sdetweil No it does not :( Do the errors possibly have something to do with it? I noticed the errors start to happen after the button is initialized. Also, do I have to have version 2.1.0 or is my current version (most updated) fine?
                      S 1 Reply Last reply Apr 10, 2024, 11:51 AM Reply Quote 0
