    Unable to link Google calandar with calendar Module
    3 Posts 2 Posters 614 Views 2 Watching
      synint Project Sponsor
      I am trying to populate the Calendar Module with details from my google calendar. I have detailed below the Config file I am running and the Error message in the terminal:
      **Config file details**
      			header: "uk Holidays",
      			position: "top_center",
      						symbol: "calendar-check",
      						url: "https://calendar.google.com/calendar/embed?src=john%40totrain.co.uk&ctz=Europe%2FLondon"
      						//url: "https://ics.calendarlabs.com/76/mm3137/US_Holidays.ics"
      Terminal Error message:
      synint@raspberrypi:~/MagicMirror $ npm run start
      > magicmirror@2.27.0 start
      [2024-04-10 20:29:35.630] [LOG]   Starting MagicMirror: v2.27.0
      [2024-04-10 20:29:35.709] [LOG]   Loading config ...
      [2024-04-10 20:29:35.718] [LOG]   config template file not exists, no envsubst
      [2024-04-10 20:29:35.732] [LOG]   Loading module helpers ...
      [2024-04-10 20:29:35.739] [LOG]   No helper found for module: MMM-OpenmapWeather.
      [2024-04-10 20:29:35.743] [LOG]   No helper found for module: alert.
      [2024-04-10 20:29:36.453] [LOG]   Initializing new module helper ...
      [2024-04-10 20:29:36.455] [LOG]   Module helper loaded: updatenotification
      [2024-04-10 20:29:36.459] [LOG]   No helper found for module: clock.
      [2024-04-10 20:29:36.868] [LOG]   Initializing new module helper ...
      [2024-04-10 20:29:36.869] [LOG]   Module helper loaded: calendar
      [2024-04-10 20:29:37.168] [LOG]   Initializing new module helper ...
      [2024-04-10 20:29:37.169] [LOG]   Module helper loaded: newsfeed
      [2024-04-10 20:29:37.170] [LOG]   All module helpers loaded.
      [2024-04-10 20:29:37.199] [LOG]   Starting server on port 8080 ...
      [2024-04-10 20:29:40.028] [LOG]   Server started ...
      [2024-04-10 20:29:40.032] [LOG]   Connecting socket for: updatenotification
      [2024-04-10 20:29:40.036] [LOG]   Starting module helper: updatenotification
      [2024-04-10 20:29:40.038] [LOG]   Connecting socket for: calendar
      [2024-04-10 20:29:40.061] [LOG]   Starting node helper for: calendar
      [2024-04-10 20:29:40.062] [LOG]   Connecting socket for: newsfeed
      [2024-04-10 20:29:40.064] [LOG]   Starting node helper for: newsfeed
      [2024-04-10 20:29:40.066] [LOG]   Sockets connected & modules started ...
      [2024-04-10 20:29:41.284] [LOG]   Launching application.
      [2024-04-10 20:29:49.222] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/embed?src=john%40totrain.co.uk&ctz=Europe%2FLondon - Interval: 604800000
      [2024-04-10 20:29:49.775] [LOG]   Create new newsfetcher for url: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
      [2024-04-10 20:29:49.807] [INFO]  updatenotification: Updater Class Loaded!
      [2024-04-10 20:29:49.809] [INFO]  updatenotification: Checking PM2 using...
      [2024-04-10 20:29:49.827] [INFO]  Checking git for module: MMM-OpenmapWeather
      [2024-04-10 20:29:50.048] [INFO]  updatenotification: [PM2] You are not using pm2
      [2024-04-10 20:29:50.306] [INFO]  Checking git for module: MagicMirror
      [2024-04-10 20:29:50.982] [ERROR] Calendar Error. Could not fetch calendar:  https://calendar.google.com/calendar/embed?src=john%40totrain.co.uk&ctz=Europe%2FLondon Error: Unauthorized
          at NodeHelper.checkFetchStatus (/home/synint/MagicMirror/js/node_helper.js:110:9)
          at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
      [2024-04-10 20:29:52.010] [INFO]  Newsfeed-Fetcher: Broadcasting 28 items.
      [2024-04-10 20:29:53.432] [INFO]  System information:
      ### SYSTEM:   manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 3 Model B Plus Rev 1.3; raspberry: [object Object]; virtual: false
      ### OS:       platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 6.1.21-v7+
      ### VERSIONS: electron: 29.1.6; used node: 20.9.0; installed node: 21.7.1; npm: 10.5.0; pm2: 5.3.1
      ### OTHER:    timeZone: Europe/London; ELECTRON_ENABLE_GPU: undefined
      [4483:0410/203006.520013:ERROR:atom_cache.cc(229)] Add WM_CHANGE_STATE to kAtomsToCache
      Any help or guidance would be appreciated.
      Kind regards,
      John
        sdetweil @synint
        @synint said in Unable to link Google calandar with calendar Module:
        you do not use the embed link, you use the shared or secret ical link
          synint Project Sponsor @sdetweil
          Hi Sam just got back off holiday and applied you suggestion and it works.
          Thank you for your response.
          Kind reagards,
          John
