    Blank screen after a couple of hours
    19 Posts 2 Posters 4.6k Views 3 Watching
      bradley1982 @sdetweil
      @sdetweil HI sam,
      it auto lauches when the pi reset.
      it seems to work for a couple of hours/day and then i get the blank screen with the cursor. I can see it on the remote control app and look ok but the screen is blank.
      When i reset the pi it works ok for the same period… and the blank screen?
      is there a log that i can run to figure out what is causing it?
      again really new to all this and need an idiot guide lol
        sdetweil @bradley1982
        @bradley1982 i assume you use pm2 to autostart.
        if so, then
        pm2 logs --lines=xxxx
        where xxxx is a number of lines to display from the latest part of the logs.
        xxxx defaults to 15
        there are only 500 places where one needs a guide. lol.
          @sdetweil lol!
          cool i have ran that, presume that i check this later and see if i get an error message form one of the modules?
          sorry for the stupid questions
            @bradley1982 yes, you can empty the current (old) collection of log messages by
            pm2 flush
              @sdetweil got this initially when i ran it … (pm2 log)
              /home/bradley/.pm2/logs/MagicMirror-error.log last 15 lines:
              0|MagicMir | [12.04.2024 18:49.13.303] [ERROR] Moment Timezone has no data for GMT+0100. See http://momentjs.com/timezone/docs/#/data-loading/.
              0|MagicMir | [12.04.2024 18:49.18.690] [ERROR] Moment Timezone has no data for GMT+0100. See http://momentjs.com/timezone/docs/#/data-loading/.
              0|MagicMir | [12.04.2024 18:49.18.691] [ERROR] Moment Timezone has no data for GMT+0100. See http://momentjs.com/timezone/docs/#/data-loading/.
              0|MagicMir | [12.04.2024 18:49.18.692] [ERROR] Moment Timezone has no data for GMT+0100. See http://momentjs.com/timezone/docs/#/data-loading/.
              0|MagicMir | [12.04.2024 18:49.18.843] [ERROR] Moment Timezone has no data for GMT-0400. See http://momentjs.com/timezone/docs/#/data-loading/.
              0|MagicMir | [12.04.2024 18:49.18.868] [ERROR] Moment Timezone has no data for GMT-0400. See http://momentjs.com/timezone/docs/#/data-loading/.
              0|MagicMir | [12.04.2024 18:49.18.890] [ERROR] Moment Timezone has no data for GMT-0400. See http://momentjs.com/timezone/docs/#/data-loading/.
              0|MagicMir | Warning: vkCreateInstance: Found no drivers!
              0|MagicMir | Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
              0|MagicMir | at CheckVkSuccessImpl (…/…/third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
              0|MagicMir | at CreateVkInstance (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
              0|MagicMir | at Initialize (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
              0|MagicMir | at Create (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
              0|MagicMir | at operator() (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
              0|MagicMir |
              many thanks
              paul
                @bradley1982 those are garbage error messages from electron. which we cant suppress. ignore them
                  @sdetweil Hi Sam,
                  got the following after running the log on the blank screen?
                  bradley@raspberrypi:~/MagicMirror $ pm2 logs --lines=xxxx
                  /home/bradley/.pm2/pm2.log last 15 lines:
                  PM2 | 2024-04-13T13:59:13: PM2 log: pid=917 msg=failed to kill - retrying in 100ms
                  PM2 | 2024-04-13T13:59:14: PM2 log: pid=917 msg=failed to kill - retrying in 100ms
                  PM2 | 2024-04-13T13:59:14: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                  PM2 | 2024-04-13T13:59:14: PM2 log: Process with pid 917 still alive after 1600ms, sending it SIGKILL now…
                  PM2 | 2024-04-13T13:59:15: PM2 log: pid=917 msg=process killed
                  PM2 | 2024-04-13T13:59:15: PM2 log: App [MagicMirror:0] starting in -fork mode-
                  PM2 | 2024-04-13T13:59:15: PM2 log: App [MagicMirror:0] online
                  0|MagicMir | [13.04.2024 23:04.55.592] [ERROR] Moment Timezone has no data for GMT+0100. See http://momentjs.com/timezone/docs/#/data-loading/.
                  0|MagicMir | [13.04.2024 23:04.55.593] [ERROR] Moment Timezone has no data for GMT+0100. See http://momentjs.com/timezone/docs/#/data-loading/.
                  0|MagicMir | [13.04.2024 23:04.55.594] [ERROR] Moment Timezone has no data for GMT+0100. See http://momentjs.com/timezone/docs/#/data-loading/.
                  0|MagicMir | [13.04.2024 23:04.55.653] [ERROR] Moment Timezone has no data for GMT+0100. See http://momentjs.com/timezone/docs/#/data-loading/.
                  0|MagicMir | [13.04.2024 23:04.55.654] [ERROR] Moment Timezone has no data for GMT+0100. See http://momentjs.com/timezone/docs/#/data-loading/.
                  0|MagicMir | [13.04.2024 23:04.55.656] [ERROR] Moment Timezone has no data for GMT+0100. See http://momentjs.com/timezone/docs/#/data-loading/.
                  0|MagicMir | [13.04.2024 23:04.56.595] [ERROR] Moment Timezone has no data for GMT+0100. See http://momentjs.com/timezone/docs/#/data-loading/.
                  0|MagicMir | [13.04.2024 23:04.56.596] [ERROR] Moment Timezone has no data for GMT+0100. See http://momentjs.com/timezone/docs/#/data-loading/.
                  0|MagicMir | [13.04.2024 23:04.56.597] [ERROR] Moment Timezone has no data for GMT+0100. See http://momentjs.com/timezone/docs/#/data-loading/.
                  0|MagicMir | [13.04.2024 23:04.57.548] [ERROR] Moment Timezone has no data for GMT+0100. See http://momentjs.com/timezone/docs/#/data-loading/.
                  0|MagicMir | [13.04.2024 23:04.57.549] [ERROR] Moment Timezone has no data for GMT+0100. See http://momentjs.com/timezone/docs/#/data-loading/.
                  0|MagicMir | [13.04.2024 23:04.57.577] [ERROR] Moment Timezone has no data for GMT-0400. See http://momentjs.com/timezone/docs/#/data-loading/.
                  0|MagicMir | [13.04.2024 23:04.57.579] [ERROR] Moment Timezone has no data for GMT-0400. See http://momentjs.com/timezone/docs/#/data-loading/.
                  /home/bradley/.pm2/logs/MagicMirror-out.log last 15 lines:
                  0|MagicMir | [13.04.2024 23:04.47.569] [LOG]
                  no idea what this means? can still see it working ok on remote control but the screen is blank?
                  many thanks in advance
                    @bradley1982 can you do it another way
                    pm2 stop all
                    npm start >somfile.txt 2>&1
                    when the black screen happens, ctrl-c on the command window with the npm start in it
                    ctrl-q might work on the MM black screen but maybe not
                      @sdetweil Hi Sam
                      Nothing seems to happen when i do the control c however when i do the control q on the blank screen on the MM it bring me back to the config file and the terminal window.
                      bradley@raspberrypi:~ $ pm2 stop all
                      [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
                      [PM2] MagicMirror ✓
                      │ id │ name │ mode │ ↺ │ status │ cpu │ memory │
                      │ 0 │ MagicMirror │ fork │ 1 │ stopped │ 0% │ 0b │
                      bradley@raspberrypi:~/MagicMirror $ ^C
                      not really sure what i am looking at here or what to do next?
                        @bradley1982 and look inside somfile.txt
                        nano somfile.txt
