    Blank screen after a couple of hours
    19 Posts 2 Posters 5.7k Views 3 Watching
      sdetweil @bradley1982
      @bradley1982 how does magicmirror get started? pm2 at boot?
      if so , pm2 can do lots of things, from a terminal window do
      pm2 status
      pm2 stop all
      and then
      pm2 --help
      for a list of all the options available
        bradley1982 @sdetweil
        @sdetweil HI sam,
        it auto lauches when the pi reset.
        it seems to work for a couple of hours/day and then i get the blank screen with the cursor. I can see it on the remote control app and look ok but the screen is blank.
        When i reset the pi it works ok for the same period… and the blank screen?
        is there a log that i can run to figure out what is causing it?
        again really new to all this and need an idiot guide lol
          @bradley1982 i assume you use pm2 to autostart.
          if so, then
          pm2 logs --lines=xxxx
          where xxxx is a number of lines to display from the latest part of the logs.
          xxxx defaults to 15
          there are only 500 places where one needs a guide. lol.
            @sdetweil lol!
            cool i have ran that, presume that i check this later and see if i get an error message form one of the modules?
            sorry for the stupid questions
              @bradley1982 yes, you can empty the current (old) collection of log messages by
              pm2 flush
                @sdetweil got this initially when i ran it … (pm2 log)
                /home/bradley/.pm2/logs/MagicMirror-error.log last 15 lines:
                0|MagicMir | [12.04.2024 18:49.13.303] [ERROR] Moment Timezone has no data for GMT+0100. See http://momentjs.com/timezone/docs/#/data-loading/.
                0|MagicMir | [12.04.2024 18:49.18.690] [ERROR] Moment Timezone has no data for GMT+0100. See http://momentjs.com/timezone/docs/#/data-loading/.
                0|MagicMir | [12.04.2024 18:49.18.691] [ERROR] Moment Timezone has no data for GMT+0100. See http://momentjs.com/timezone/docs/#/data-loading/.
                0|MagicMir | [12.04.2024 18:49.18.692] [ERROR] Moment Timezone has no data for GMT+0100. See http://momentjs.com/timezone/docs/#/data-loading/.
                0|MagicMir | [12.04.2024 18:49.18.843] [ERROR] Moment Timezone has no data for GMT-0400. See http://momentjs.com/timezone/docs/#/data-loading/.
                0|MagicMir | [12.04.2024 18:49.18.868] [ERROR] Moment Timezone has no data for GMT-0400. See http://momentjs.com/timezone/docs/#/data-loading/.
                0|MagicMir | [12.04.2024 18:49.18.890] [ERROR] Moment Timezone has no data for GMT-0400. See http://momentjs.com/timezone/docs/#/data-loading/.
                0|MagicMir | Warning: vkCreateInstance: Found no drivers!
                0|MagicMir | Warning: vkCreateInstance failed with VK_ERROR_INCOMPATIBLE_DRIVER
                0|MagicMir | at CheckVkSuccessImpl (…/…/third_party/dawn/src/dawn/native/vulkan/VulkanError.cpp:88)
                0|MagicMir | at CreateVkInstance (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:458)
                0|MagicMir | at Initialize (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:344)
                0|MagicMir | at Create (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:266)
                0|MagicMir | at operator() (…/…/third_party/dawn/src/dawn/native/vulkan/BackendVk.cpp:521)
                0|MagicMir |
                many thanks
                paul
                  @bradley1982 those are garbage error messages from electron. which we cant suppress. ignore them
                    @sdetweil Hi Sam,
                    got the following after running the log on the blank screen?
                    bradley@raspberrypi:~/MagicMirror $ pm2 logs --lines=xxxx
                    /home/bradley/.pm2/pm2.log last 15 lines:
                    PM2 | 2024-04-13T13:59:13: PM2 log: pid=917 msg=failed to kill - retrying in 100ms
                    PM2 | 2024-04-13T13:59:14: PM2 log: pid=917 msg=failed to kill - retrying in 100ms
                    PM2 | 2024-04-13T13:59:14: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
                    PM2 | 2024-04-13T13:59:14: PM2 log: Process with pid 917 still alive after 1600ms, sending it SIGKILL now…
                    PM2 | 2024-04-13T13:59:15: PM2 log: pid=917 msg=process killed
                    PM2 | 2024-04-13T13:59:15: PM2 log: App [MagicMirror:0] starting in -fork mode-
                    PM2 | 2024-04-13T13:59:15: PM2 log: App [MagicMirror:0] online
                    0|MagicMir | [13.04.2024 23:04.55.592] [ERROR] Moment Timezone has no data for GMT+0100. See http://momentjs.com/timezone/docs/#/data-loading/.
                    0|MagicMir | [13.04.2024 23:04.55.593] [ERROR] Moment Timezone has no data for GMT+0100. See http://momentjs.com/timezone/docs/#/data-loading/.
                    0|MagicMir | [13.04.2024 23:04.55.594] [ERROR] Moment Timezone has no data for GMT+0100. See http://momentjs.com/timezone/docs/#/data-loading/.
                    0|MagicMir | [13.04.2024 23:04.55.653] [ERROR] Moment Timezone has no data for GMT+0100. See http://momentjs.com/timezone/docs/#/data-loading/.
                    0|MagicMir | [13.04.2024 23:04.55.654] [ERROR] Moment Timezone has no data for GMT+0100. See http://momentjs.com/timezone/docs/#/data-loading/.
                    0|MagicMir | [13.04.2024 23:04.55.656] [ERROR] Moment Timezone has no data for GMT+0100. See http://momentjs.com/timezone/docs/#/data-loading/.
                    0|MagicMir | [13.04.2024 23:04.56.595] [ERROR] Moment Timezone has no data for GMT+0100. See http://momentjs.com/timezone/docs/#/data-loading/.
                    0|MagicMir | [13.04.2024 23:04.56.596] [ERROR] Moment Timezone has no data for GMT+0100. See http://momentjs.com/timezone/docs/#/data-loading/.
                    0|MagicMir | [13.04.2024 23:04.56.597] [ERROR] Moment Timezone has no data for GMT+0100. See http://momentjs.com/timezone/docs/#/data-loading/.
                    0|MagicMir | [13.04.2024 23:04.57.548] [ERROR] Moment Timezone has no data for GMT+0100. See http://momentjs.com/timezone/docs/#/data-loading/.
                    0|MagicMir | [13.04.2024 23:04.57.549] [ERROR] Moment Timezone has no data for GMT+0100. See http://momentjs.com/timezone/docs/#/data-loading/.
                    0|MagicMir | [13.04.2024 23:04.57.577] [ERROR] Moment Timezone has no data for GMT-0400. See http://momentjs.com/timezone/docs/#/data-loading/.
                    0|MagicMir | [13.04.2024 23:04.57.579] [ERROR] Moment Timezone has no data for GMT-0400. See http://momentjs.com/timezone/docs/#/data-loading/.
                    /home/bradley/.pm2/logs/MagicMirror-out.log last 15 lines:
                    0|MagicMir | [13.04.2024 23:04.47.569] [LOG]
                    no idea what this means? can still see it working ok on remote control but the screen is blank?
                    many thanks in advance
                      @bradley1982 can you do it another way
                      pm2 stop all
                      npm start >somfile.txt 2>&1
                      when the black screen happens, ctrl-c on the command window with the npm start in it
                      ctrl-q might work on the MM black screen but maybe not
                        @sdetweil Hi Sam
                        Nothing seems to happen when i do the control c however when i do the control q on the blank screen on the MM it bring me back to the config file and the terminal window.
                        bradley@raspberrypi:~ $ pm2 stop all
                        [PM2] Applying action stopProcessId on app [all](ids: [ 0 ])
                        [PM2] MagicMirror ✓
                        │ id │ name │ mode │ ↺ │ status │ cpu │ memory │
                        │ 0 │ MagicMirror │ fork │ 1 │ stopped │ 0% │ 0b │
                        bradley@raspberrypi:~/MagicMirror $ ^C
                        not really sure what i am looking at here or what to do next?
                          @bradley1982 and look inside somfile.txt
                          nano somfile.txt
                            hi Sam,
                            had a look an looked for errors?
                            15.04.2024 12:15.14.424] [INFO] Newsfeed-Fetcher: Broadcasting 26 items.
                            [15.04.2024 12:20.19.728] [ERROR] Newsfeed Error. Could not fetch newsfeed: https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml >
                            at NodeHelper.checkFetchStatus (/home/bradley/MagicMirror/js/node_helper.js:116:9)
                            at processTicksAndRejections (node:internal/process/task_queues:95:5)
                            THEN FURTHER DOWN -
                            [16.04.2024 07:02.24.761] [INFO] Newsfeed-Fetcher: Broadcasting 26 items.
                            [16.04.2024 07:04.26.190] [ERROR] ERROR! Could not validate main module js file.
                            [16.04.2024 07:04.26.205] [ERROR] ReferenceError: defaults is not defined
                            at Object. (/home/bradley/MagicMirror/modules/MMM-OpenWeatherMapForecast/MMM-OpenWeatherMapForecast.js:80:22)
                            at Module._compile (node:internal/modules/cjs/loader:1271:14)
                            at Object…js (node:internal/modules/cjs/loader:1326:10)
                            at Module.load (/home/bradley/MagicMirror/modules/MMM-MyScoreboard/node_modules/coffee-script/lib/coffee-script/register.js:45:36)
                            at node:internal/modules/cjs/loader:967:12
                            at Function._load (node:electron/js2c/node_init:2:13357)
                            at Module.require (node:internal/modules/cjs/loader:1150:19)
                            at require (node:internal/modules/cjs/helpers:121:18)
                            at Class.loadModuleDefaultConfig (/home/bradley/MagicMirror/modules/MMM-Remote-Control/node_helper.js:314:30)
                            at /home/bradley/MagicMirror/modules/MMM-Remote-Control/node_helper.js:268:26
                            at FSReqCallback.oncomplete (node:fs:211:5)
                            [16.04.2024 07:07.25.459] [INFO] Newsfeed-Fetcher: Broadcasting 26 items.
                            [16.04.2024 07:10.18.538] [INFO] Update found for module: MMM-NewsFeedTicker
                            [16.04.2024 07:12.26.448] [INFO] Newsfeed-Fetcher: Broadcasting 26 items.
                            [16.04.2024 07:17.27.421] [INFO] Newsfeed-Fetcher: Broadcasting 26 items.
                            [16.04.2024 07:20.27.894] [INFO] Update found for module: MMM-NewsFeedTicker
                            [16.04.2024 07:22.28.492] [INFO] Newsfeed-Fetcher: Broadcasting 26 items.
                            [16.04.2024 07:27.29.185] [INFO] Newsfeed-Fetcher: Broadcasting 26 items.
                            [16.04.2024 07:30.37.179] [INFO] Update found for module: MMM-NewsFeedTicker
                            [16.04.2024 07:32.30.111] [INFO] Newsfeed-Fetcher: Broadcasting 26 items.
                            [16.04.2024 07:37.31.062] [INFO] Newsfeed-Fetcher: Broadcasting 26 items.
                            [16.04.2024 07:40.46.440] [INFO] Update found for module: MMM-NewsFeedTicker
                            [16.04.2024 07:42.32.012] [INFO] Newsfeed-Fetcher: Broadcasting 26 items.
                            [16.04.2024 07:47.32.954] [INFO] Newsfeed-Fetcher: Broadcasting 26 items.
                            [16.04.2024 07:50.55.991] [INFO] Update found for module: MMM-NewsFeedTicker
                            [16.04.2024 07:52.33.895] [INFO] Newsfeed-Fetcher: Broadcasting 27 items.
                            [16.04.2024 07:57.34.610] [INFO] Newsfeed-Fetcher: Broadcasting 27 items.
                            [16.04.2024 08:01.05.664] [INFO] Update found for module: MMM-NewsFeedTicker
                            [16.04.2024 08:02.35.562] [INFO] Newsfeed-Fetcher: Broadcasting 27 items.
                            [16.04.2024 08:07.36.271] [INFO] Newsfeed-Fetcher: Broadcasting 27 items.
                            [16.04.2024 08:11.14.999] [INFO] Update found for module: MMM-NewsFeedTicker
                            [16.04.2024 08:12.37.239] [INFO] Newsfeed-Fetcher: Broadcasting 27 items.
                            [16.04.2024 08:17.38.199] [INFO] Newsfeed-Fetcher: Broadcasting 27 items.
                            [16.04.2024 08:19.26.192] [LOG] Shutting down server…
                            [16.04.2024 08:19.26.196] [LOG] Stopping module helper: updatenotification
                            [16.04.2024 08:19.26.197] [LOG] Stopping module helper: calendar
                            [16.04.2024 08:19.26.199] [LOG] Stopping module helper: MMM-OpenWeatherMapForecast
                            [16.04.2024 08:19.26.199] [LOG] Stopping module helper: MMM-MyScoreboard
                            [16.04.2024 08:19.26.201] [LOG] Stopping module helper: MMM-Todoist
                            IF EASIER CAN SENT THE FULL REPORT.
                            thanks so much for your help
                              @bradley1982 said in Blank screen after a couple of hours:
                              this is probably the killer… network error, and not enough error recovery
                              sadly there is no fix for this
                              this one is a module problem that should be reported on the module.
                              B S 2 Replies Last reply Reply Quote 0
                                @sdetweil oh ok. thanks for your help.
                                any recommendation what to do?
                                  @sdetweil on the second look at the module github page, issues and see if anyone has posted a fix
                                    bradley1982 @bradley1982
                                    @bradley1982 ok thanks very much for all you help!
