    SmartMirror Reinstalled, worked, then failed...
    2 Posts 2 Posters 249 Views 2 Watching
      rutgerm
      So, my SmartMirror was setup once again and then it started working and will no longer start up. This is what happens when I try and force it to start.
      rutger@smartmirror:~/MagicMirror $ npm start dev
      magicmirror@2.27.0 start
      DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js dev
      [2024-04-14 10:45:29.422] [LOG] Starting MagicMirror: v2.27.0
      [2024-04-14 10:45:29.481] [LOG] Loading config …
      [2024-04-14 10:45:29.488] [LOG] config template file not exists, no envsubst
      [2024-04-14 10:45:29.495] [LOG] Loading module helpers …
      [2024-04-14 10:45:29.497] [LOG] No helper found for module: alert.
      [2024-04-14 10:45:29.976] [LOG] Initializing new module helper …
      [2024-04-14 10:45:29.977] [LOG] Module helper loaded: updatenotification
      [2024-04-14 10:45:29.979] [LOG] No helper found for module: clock.
      [2024-04-14 10:45:29.981] [LOG] No helper found for module: MMM-NsInfo.
      [2024-04-14 10:45:29.983] [LOG] No helper found for module: compliments.
      [2024-04-14 10:45:29.984] [LOG] No helper found for module: weather.
      [2024-04-14 10:45:31.036] [ERROR] (node:1578) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘core-js/modules/es.string.replace.js’
      Require stack:
      • /home/rutger/MagicMirror/modules/MMM-GoogleTrafficTimes/node_modules/@googlemaps/url-signature/dist/index.umd.js
      • /home/rutger/MagicMirror/modules/MMM-GoogleTrafficTimes/node_modules/@googlemaps/google-maps-services-js/dist/serialize.js
      • /home/rutger/MagicMirror/modules/MMM-GoogleTrafficTimes/node_modules/@googlemaps/google-maps-services-js/dist/directions.js
      • /home/rutger/MagicMirror/modules/MMM-GoogleTrafficTimes/node_modules/@googlemaps/google-maps-services-js/dist/client.js
      • /home/rutger/MagicMirror/modules/MMM-GoogleTrafficTimes/node_modules/@googlemaps/google-maps-services-js/dist/geolocate.js
      • /home/rutger/MagicMirror/modules/MMM-GoogleTrafficTimes/node_modules/@googlemaps/google-maps-services-js/dist/index.js
      • /home/rutger/MagicMirror/modules/MMM-GoogleTrafficTimes/node_helper.js
      • /home/rutger/MagicMirror/js/app.js
      • /home/rutger/MagicMirror/js/electron.js
        at Module._resolveFilename (node:internal/modules/cjs/loader:1055:15)
        at s._resolveFilename (node:electron/js2c/browser_init:2:115690)
        at Module._resolveFilename (/home/rutger/MagicMirror/node_modules/module-alias/index.js:49:29)
        at Module._load (node:internal/modules/cjs/loader:908:27)
        at c._load (node:electron/js2c/node_init:2:13672)
        at Module.require (node:internal/modules/cjs/loader:1122:19)
        at require (node:internal/modules/helpers:130:18)
        at /home/rutger/MagicMirror/modules/MMM-GoogleTrafficTimes/node_modules/@googlemaps/url-signature/dist/index.umd.js:1:79
        at Object. (/home/rutger/MagicMirror/modules/MMM-GoogleTrafficTimes/node_modules/@googlemaps/url-signature/dist/index.umd.js:1:807)
        at Module._compile (node:internal/modules/cjs/loader:1256:14)
        at Module._extensions…js (node:internal/modules/cjs/loader:1311:10)
        at Module.load (node:internal/modules/cjs/loader:1098:32)
        at Module._load (node:internal/modules/cjs/loader:945:12)
        (Use electron --trace-warnings ... to show where the warning was created)
        [2024-04-14 10:45:31.059] [ERROR] (node:1578) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
        [2024-04-14 10:45:40.165] [INFO] System information:
      SYSTEM: manufacturer: Raspberry Pi Foundation; model: Raspberry Pi 3 Model B Rev 1.2; raspberry: [object Object]; virtual: false
      OS: platform: linux; distro: Raspbian GNU/Linux; release: 11; arch: arm; kernel: 6.1.21-v7+
      VERSIONS: electron: 29.3.0; used node: 20.9.0; installed node: 20.8.0; npm: 10.1.0; pm2: 5.3.1
      OTHER: timeZone: Europe/Amsterdam; ELECTRON_ENABLE_GPU: undefined
        sdetweil @rutgerm
        @rutgerm .MMM-GoogleTrafficTimes
        did you update your system?
        please go to that module folder and do
        npm install
