    Noob problem: updated config file not showing changes in the application
    3 Posts 2 Posters 871 Views 2 Watching
      jwin
      Hi Everyone,
      I am an excited new user of MagicMirror but I am also a beginner. I have been able to get MM installed on my Windows Machine and successfully launched!
      However, I am running into issue with editing the config file. I use a text editor to make edits, run the config check to make sure there are no syntax errors, but when I launch the application, it shows the outputs from the original config file rather than the edits I have made to that same file.
      What am I doing wrong?
      All help much appreciated.
      Jon
        jwin @sdetweil
        @sdetweil I was editing the sample. How embarrassing! I am away to the races now though :)
        Thanks so much for the rapid response.
          sdetweil @jwin
          @jwin can you show me an example of a change?
          and the messages from npm start
          you ARE editing config.js, right
          after you created it by copying the sample
            jwin @sdetweil
