    MP3 Player
    59 Posts 5 Posters 32.9k Views 4 Watching
      bachoo786 @sdetweil
      @sdetweil ah thanks will look into it no need to apologise mate.
      Did you have a chance to look into my 2 sets of codes ?
        sdetweil @bachoo786
        @bachoo786 yes,
        your function
        setCurrentSong: function(folderName, songName){
        takes two parms
        on line 264 you called it with one
              MP3.setCurrentSong(0);
        B 1 Reply Last reply
          bachoo786 @sdetweil
          @sdetweil ah right so I need to change it to something like this:
          MP3.setCurrentSong(0, 'songName');
          Also did you manage to look into my later code which I described as the “better way”
            sdetweil @bachoo786
            @bachoo786 I did not look at the better method… cause I don’t know what that means.
            I wasn’t looking at design, only syntax
              bachoo786 @sdetweil
              @sdetweil ok I will try and explain the “better” method:
              I’m basically trying to add a playlist feature to the MP3 player module I’m working on. My initial setup involved adding a songList to MP3Player.js, which lists all the songs—.mp3 files—in the ‘music’ folder of the module. I’ve also added a second folder, ‘music2’, to categorize songs by artist. Each artist’s name is tagged with an ‘h2’ in the CSS, for both songList and songList2.
              However, this setup becomes cumbersome because it requires repeating the process for multiple artists, creating many folders and modifying the code each time for songList3, songList4, etc.
              I thought a better approach would be to have one ‘music’ folder with subfolders for each artist containing their songs. This way, the module would display artists on the frontend, and clicking an artist’s name would show the songs in their folder.
              I did start on this more streamlined method, but it proved challenging, so I reverted to the simpler, original method which we’ve been discussing since yesterday, as that uses a “single” songList displaying songs from the ‘music’ folder and has been working for me. So I have been trying to add another “songList2” to add more artists and their respective music.
              I hope that makes sense?
                sdetweil @bachoo786
                @bachoo786 ok. I saw the song list 2 and 3, and said
                these should be arrays of songlist[][]
                but now that u add by artist it would be a hash of hashes
                songlist{artist{album}{song}}
                so you could access it with
                songlist[“artistname”][“album1”][song1"]
                or
                songlist[song_info]
                where song_info is a structure
                { artist_name:“…”, albums[{name:“…”, songs:[{…}]]}
                  bachoo786 @sdetweil
                  @sdetweil sorry to mess with your head but I have been working on this for the last 3 hours and have come up with the following that should show the folders on the front end and when any folder is clicked it should reveal the mp3 files. the issue I am facing is that I am having no errors whatsoever but the module will just not show on the front end. I am pulling my hair out now !
                  these are my files:
                  node_helper.js:
                  var NodeHelper = require('node_helper');
                  const Fs = require('fs');
                      start: function() {
                          console.log("Loaded MP3Player node_helper");
                          var self = this;
                          if (notification === 'SOURCE_MUSIC') {
                              const musicPath = payload.musicPath;
                              const extensions = payload.extensions;
                              Fs.readdir(musicPath, (err, folders) => {
                                  if (err) {
                                      console.error("Error reading music directory:", err);
                                      self.sendSocketNotification('ERROR', {message: "Error reading music directory"});
                                  } else {
                                      const musicData = folders.map(folder => ({
                                          folderName: folder,
                                          songs: Fs.readdirSync(`${musicPath}/${folder}`).filter(file => self.checkExt(file, extensions))
                                      self.sendSocketNotification("RETURNED_MUSIC", { musicData: musicData });
                      checkExt: function(file, ext) {
                          return ext.some(extension => file.toLowerCase().endsWith(extension));
                  MMM-MP3Player.js:
                  var MP3;
                  var substr;
                  Module.register("MMM-MP3Player", {
                    defaults: {
                      songs: [],
                      musicPath: "modules/MMM-MP3Player/music",
                      extensions: ["mp3", "wma", "acc", "ogg"],
                      songs: null,
                      autoPlay: false,
                      random: false,
                    audio: null,
                    songTitle: null,
                    mediaPlayer: null,
                    dataAvailable: true,
                    curSong :0,
                    curLength : 0,
                    time: null,
                    play: null,
                    firstTime: true,
                    substr: null,
                    getStyles: function(){
                      return ["MMM-MP3Player.css", "font-awesome.css"];
                    start: function(){
                      MP3 = this;
                      console.log("autoPlay configuration:", MP3.config.autoPlay);
                      Log.info("Starting module: " + MP3.name);
                  getDom: function() {
                      if (MP3.config.musicData) {
                          const musicList = MP3.createElement("ul", "musicList", "musicList");
                          MP3.config.musicData.forEach(folderData => {
                              // Folder item
                              const folderItem = MP3.createElement("li", "folderItem", `folderItem-${folderData.folderName}`);
                              folderItem.innerHTML = `
                                  <span class="folderName">${folderData.folderName}</span>
                                  <i class="fa fa-chevron-down"></i>
                              // Songs list within the folder
                              const songsList = MP3.createElement("ul", "songsList", `songsList-${folderData.folderName}`);
                              songsList.style.display = 'none'; // Initially hide the songs list
                              folderData.songs.forEach(song => {
                                  const songItem = MP3.createElement("li", "songItem", `songItem-${song}`);
                                  songItem.innerHTML = song.substr(0, song.length - 4);
                                  songsList.appendChild(songItem);
                              // Click event listeners
                              folderItem.addEventListener('click', () => {
                                  songsList.style.display = songsList.style.display === 'none' ? 'block' : 'none'; // Toggle display
                                  folderItem.querySelector('.fa').classList.toggle('fa-chevron-down');
                                  folderItem.querySelector('.fa').classList.toggle('fa-chevron-up');
                              songsList.addEventListener('click', (event) => {
                                  const clickedSongItem = event.target;
                                  if (clickedSongItem.classList.contains('songItem')) {
                                      const songName = clickedSongItem.innerText;
                                      const folderName = folderData.folderName;
                                      MP3.playSong(folderName, songName);
                              folderItem.appendChild(songsList);
                              musicList.appendChild(folderItem);
                          wrapper.appendChild(musicList);
                          // Add the rest of the existing code...
                          MP3.mediaPlayer = MP3.createElement("div", "mediaPlayer", "mediaPlayer");
                          MP3.audio = MP3.createElement("audio", "audioPlayer", "audioPlayer");
                          MP3.audio.addEventListener("loadeddata", () => {
                              MP3.dataAvailable = true;
                              MP3.curLength = MP3.audio.duration;
                              MP3.updateDurationLabel();
                          MP3.audio.addEventListener("ended", () => {
                              Log.log(" play ended")
                              MP3.audio.currentTime = 0;
                              if(MP3.config.autoPlay)
                                  MP3.loadNext(MP3.config.random)
                              else
                                  MP3.mediaPlayer.classList.toggle("play");
                  MP3.audio.addEventListener("timeupdate", () => {
                          MP3.mediaPlayer.appendChild(MP3.audio);
                          // Add the rest of the controls to MP3.mediaPlayer
                          var controls = MP3.createElement("div", "controls", false);
                          MP3.songTitle = MP3.createElement("span", "title", "songTitle");
                          MP3.setCurrentSong(MP3.curSong);
                          controls.appendChild(MP3.songTitle);
                          var discArea = MP3.createElement("div", "discarea", false);
                          discArea.appendChild(MP3.createElement("div", "disc", false));
                          var stylus = MP3.createElement("div", "stylus", false);
                          stylus.appendChild(MP3.createElement("div", "pivot", false));
                          stylus.appendChild(MP3.createElement("div", "arm", false));
                          stylus.appendChild(MP3.createElement("div", "head", false));
                          discArea.appendChild(stylus);
                          MP3.mediaPlayer.appendChild(discArea);
                        var buttons = MP3.createElement("div", "buttons", false);
                        //  Previous Button
                        var prev = MP3.createButton("back", "prevButton", "fa fa-backward");
                        prev.addEventListener("click", () => {
                          MP3.dataAvailable = false;
                          MP3.loadNext(MP3.config.random);
                          MP3.audio.play();
                          MP3.play.getElementsByTagName('i')[0].className = "fa fa-pause";
                        }, false),
                        buttons.appendChild(prev);
                        //  Play Button
                        MP3.play = MP3.createButton("play", "playButton", "fa fa-play");
                        MP3.play.addEventListener("click", () => {
                          if (MP3.audio.paused) {
                            setTimeout(() => {
                              MP3.audio.play();
                            }, 300);
                            MP3.timer = setInterval(MP3.updateDurationLabel, 100);
                          } else {
                            //MP3.loadNext(MP3.config.random);
                            MP3.play.getElementsByTagName('i')[0].className = "fa fa-play";
                            clearInterval(MP3.timer);
                            MP3.audio.pause();
                        }, false);
                        buttons.appendChild(MP3.play);
                        //  Stop Button
                        var stop = MP3.createButton("stop", "stopButton", "fa fa-stop");
                        stop.addEventListener("click", () => {
                          MP3.mediaPlayer.classList.remove("play");
                          MP3.audio.pause();
                        }, false);
                        buttons.appendChild(stop);
                        //  Next Button
                        var next = MP3.createButton("next", "nextButton", "fa fa-forward");
                        next.addEventListener("click", () => {
                        }, false);
                        buttons.appendChild(next);
                          controls.appendChild(buttons);
                          var subControls = MP3.createElement("div", "subControls", false);
                          var duration = MP3.createElement("span", "duration", "currentDuration");
                          duration.innerHTML = "00:00" + "&nbsp&nbsp&nbsp";
                          subControls.appendChild(duration);
                          var volumeSlider = MP3.createElement("input", "volumeSlider", "volumeSlider");
                          volumeSlider.type = "range";
                          volumeSlider.min = "0";
                          volumeSlider.max = "1";
                          volumeSlider.step = "0.01";
                          volumeSlider.addEventListener("input", () => {
                              MP3.audio.volume = parseFloat(volumeSlider.value);
                          }, false);
                          subControls.appendChild(volumeSlider);
                          controls.appendChild(subControls);
                          MP3.mediaPlayer.appendChild(controls);
                          wrapper.appendChild(MP3.mediaPlayer);
                      if(MP3.firstTime && MP3.config.autoPlay){
                          console.log("First time and autoPlay are true. Setting firstTime to false.");
                          MP3.firstTime=false;
                      return wrapper;
                  playSong: function(folderName, songName) {
                      const songPath = MP3.config.musicPath + '/' + folderName + '/' + songName;
                      MP3.audio.src = songPath;
                      MP3.songTitle.innerHTML = songName;
                      MP3.audio.play();
                    createElement: function(type, className, id){
                      var elem = document.createElement(type);
                      if(className) elem.className = className;
                      if(id)  elem.id = id;
                      return elem;
                    createButton: function(className, id, icon){
                      var button = document.createElement('button');
                      button.className = className;
                      button.id = id;
                      var ico = document.createElement("i");
                      ico.className = icon;
                      button.appendChild(ico);
                      return button;
                  updateDurationLabel: function() {
                    var duration = document.getElementById('currentDuration');
                    if (MP3.dataAvailable && MP3.audio.duration > 0) {
                      duration.innerText = MP3.parseTime(MP3.audio.currentTime) + " / " + MP3.parseTime(MP3.audio.duration);
                    } else {
                      duration.innerText = "00:00 / 00:00";
                    parseTime: function(time){
                      const minutes = Math.floor(time / 60)
                      const seconds = Math.floor(time - minutes * 60)
                      const secondsZero = seconds < 10 ? "0" : ""
                      const minutesZero = minutes < 10 ? "0" : ""
                      return minutesZero + minutes.toString() + ":" + secondsZero + seconds.toString()
                    setCurrentSong: function(index){
                        if(MP3.audio!= undefined){
                          MP3.audio.src = MP3.config.musicPath + '/' + MP3.config.songs[index];
                          MP3.songTitle.innerHTML = MP3.config.songs[index].substr(0, MP3.config.songs[index].length - 4);
                          MP3.curSong = index;
                    loadNext: function(next){
                     let index=0;
                        console.log("loadNext: Autoplay:", MP3.config.autoPlay); // Add this line for logging
                        MP3.audio.pause();
                        if(next)  index= (MP3.curSong + 1) % MP3.config.songs.length;
                        else      index = (MP3.curSong - 1) < 0 ? MP3.config.songs.length - 1 : MP3.curSong - 1;
                        MP3.setCurrentSong(index);
                        MP3.audio.play();
                    notificationReceived: function (notification, payload) {
                      if(notification === "ALL_MODULES_STARTED")
                  		  MP3.sendSocketNotification('SOURCE_MUSIC', MP3.config);
                    socketNotificationReceived: function(notification, payload){
                      if(notification === "RETURNED_MUSIC")
                        MP3.config.songs = payload.songs;
                        // set the initial song index
                        // paint the player
                        MP3.updateDom(2);
                  MMM-MP3Player.css:
                  @import url("https://fonts.googleapis.com/css?family=Roboto"); /* Simpler, modern font */
                  .MMM-MP3Player .songInfo {
                      flex: 1; /* Fill half of the available space */
                      padding: 20px;
                      font-family: 'Roboto', sans-serif;
                  .MMM-MP3Player .songTitle {
                      font-size: 4em;
                      font-weight: bold;
                      color: #333; /* Darker text */
                      overflow: hidden;
                      text-overflow: ellipsis;
                      white-space: nowrap;
                  .MMM-MP3Player .container {
                      position: relative; /* Add this if not present */
                      /* ...other styles... */
                  .MMM-MP3Player .songsList {
                      position: absolute;
                      left: 10px; /* Adjust to align correctly, can be in px or % */
                      top: -360px;  /* Adjust to align correctly, can be in px or % */
                      width: 50%; /* Adjust to not exceed the container width */
                      max-width: calc(100% - 40px); /* Subtract total horizontal padding */
                      align-items: center;
                      padding: 20px;
                      box-sizing: border-box;
                      font-size: 2em;
                      font-weight: bold;
                      color: #FFF;
                      overflow: hidden;
                      z-index: 1000;
                      background-image:
                          linear-gradient(
                              to bottom,
                              rgba(255, 255, 255, 0.8) 0%,
                              rgba(255, 255, 255, 0.75) 25%,
                              rgba(255, 255, 255, 0.6) 50%,
                              rgba(255, 255, 255, 0.4) 75%,
                              rgba(255, 255, 255, 0.3) 100%
                          url('images/qsonglist.png');
                      background-size: cover;
                      background-position: center;    border-radius: 20px;
                      border: 1px solid rgba(255, 255, 255, 0.3);
                      backdrop-filter: blur(15px);
                      -webkit-backdrop-filter: blur(15px);
                      box-shadow: 0 8px 24px rgba(0, 0, 0, 0.2);
                  .MMM-MP3Player .mediaPlayer {
                      position: absolute;
                      right: 0;  /* Adjust as needed to align to the right */
                      top: -130px;       /* Aligns to the top of the container */
                      width: 50%;   /* Or whatever width you require */
                      padding: 20px;
                      justify-content: center;
                      z-index: 1000;
                  .MMM-MP3Player .controls {
                      width: 80%;
                      margin-top: 20px;
                  .MMM-MP3Player .buttons button {
                      background-color: #4CAF50; /* Example: Green for modern feel */
                      color: white;
                      border: none;
                      border-radius: 50%;
                      margin-right: 10px;
                      font-size: 1.2em;
                      width: 50px;
                      height: 50px;
                      box-shadow: 0 2px 5px rgba(0,0,0,0.3); /* Adds depth */
                  .MMM-MP3Player .buttons button:hover {
                      background-color: #3e8e41; /* Darker green on hover */
                      cursor: pointer;
                  in my config.js:
                  I have added it this way:
                      module: "MMM-MP3Player",
                      position: "bottom_center",
                      "pages": {"Audio": "bottom_center"},
                  				autoPlay: false,
                  				random: false,
                  				loopList: false,
                  Can you tell me what am I doing wrong? thanks
                  S 2 Replies Last reply
                    sdetweil @bachoo786
                    @bachoo786 can you please make a git repo of this.
                      sdetweil @bachoo786
                      @bachoo786 what shows in the developers window?
                        bachoo786 @sdetweil
                        @sdetweil I will .
                        Nothing says everything is loaded including the mp3 player module.
                          sdetweil @bachoo786
                          @bachoo786 well, code and data don’t match
                          config.js
                          defaults
                          getDom()
                              if (MP3.config.musicData) { (and other places)
                          if you use the developers window you can step thru the code
                            bachoo786 @sdetweil
                            @sdetweil here is the repo:
                            https://github.com/bachoo786/MMM-MP3Player
                              sdetweil @bachoo786
                              @bachoo786 you don’t set
                              if (MP3.config.musicData) {  anywhere..  so getDom() returns an empty div
                              I ‘assume’ you meant for the node_helper to send this back
                              but yours socketNotifcationReceived does this
                                    MP3.config.songs = payload.songs;  <---  songs is undefined, but musicData is there
                              B B 2 Replies Last reply
                                bachoo786 @sdetweil
                                @sdetweil so I made a mistake, i wanted my code to look for the mp3 files automatically in the folders within the music directory.
                                currently I am getting an error in the developer console:
                                Uncaught SyntaxError: Unexpected token ',' (at MMM-MP3Player.js:184:2)
                                its the “,” at the end of
                                return wrapper
                                I am trying to have one ‘music’ folder with subfolders for each artist containing their songs. This way, the module would display artists on the frontend, and clicking an artist’s name would show the songs in their folder, and click on the song would then play the mp3 file.
                                feel like giving up really even though I think I am close
                                S B 3 Replies Last reply
                                  sdetweil @bachoo786
                                  @bachoo786 what did you change?
                                  this is a missing } probably
                                    sdetweil @bachoo786
                                    @bachoo786 well, coding is a challenge sometimes
                                    you changed the data coming back from the node helper
                                    the code is looking for songs
                                    but its a nested struct in musicData
                                    so, fix the first thing (the socketNotificationReceived)
                                    and then the code crashes later cause you are expecting the data in songs…
                                    computers do things fast… they don’t know WHY they are doing it, so can’t ‘fix’ themselves
                                      bachoo786 @bachoo786
                                      @bachoo786
                                      I changed from this:
                                                  // Folder item
                                      to this:
                                         const fs = require('fs');
                                         const path = require('path');
                                         const musicFolder = path.resolve(MP3.config.musicData.musicPath);
                                         const supportedExtensions = this.defaults.extensions; // Use module's default extensions
                                         fs.readdir(musicFolder, (err, files) => {
                                          if (err) {
                                           // Handle the error - display message to user, etc.
                                          } else {
                                           const musicFiles = files.filter(file => supportedExtensions.includes(path.extname(file).toLowerCase()));
                                           if (musicFiles.length > 0) {
                                            const musicList = MP3.createElement("ul", "musicList");
                                            musicFiles.forEach(musicFile => {
                                             const songItem = MP3.createElement('li', 'songItem');
                                             songItem.innerHTML = musicFile.substr(0, musicFile.length - 4);
                                             songItem.addEventListener('click', () => {
                                              MP3.playSong(musicFile); // Assuming you want to play the song directly
                                             musicList.appendChild(songItem);
                                        sdetweil @bachoo786
                                        @bachoo786 you could say, I have updated the repo, git pull to get the changes…
                                        you need to
                                        git add,
                                        git commit -m and
                                        git push
                                        to update the repo
                                          sdetweil @bachoo786
                                          @bachoo786 said in MP3 Player:
                                          the modulename.js that runs in the browser cannot read files directly, due to security restrictions ( any script could read ALL your files without you knowing)
                                          this is why the node_helper exists…
                                            bachoo786 @sdetweil
                                            @sdetweil said in MP3 Player:
                                            so whats the alternative? I had this MMM-QuranPlayer module that was able to read mp3 files from the folders in the “public” directory which was located in the root folder of the module.
                                            • 3 / 3
