    MP3 Player
    59 Posts 5 Posters 32.9k Views 4 Watching
      sdetweil @bachoo786
      @bachoo786 can you please make a git repo of this.
      B 1 Reply Last reply
        sdetweil @bachoo786
        @bachoo786 what shows in the developers window?
          bachoo786 @sdetweil
          @sdetweil I will .
          Nothing says everything is loaded including the mp3 player module.
            sdetweil @bachoo786
            @bachoo786 well, code and data don’t match
            config.js
                    musicPath: "modules/MMM-MP3Player/music",
            defaults
            getDom()
                if (MP3.config.musicData) { (and other places)
            if you use the developers window you can step thru the code
              bachoo786 @sdetweil
              @sdetweil here is the repo:
              https://github.com/bachoo786/MMM-MP3Player
                sdetweil @bachoo786
                @bachoo786 you don’t set
                if (MP3.config.musicData) {  anywhere..  so getDom() returns an empty div
                I ‘assume’ you meant for the node_helper to send this back
                but yours socketNotifcationReceived does this
                    if(notification === "RETURNED_MUSIC")
                      MP3.config.songs = payload.songs;  <---  songs is undefined, but musicData is there
                B B 2 Replies Last reply
                  bachoo786 @sdetweil
                  @sdetweil so I made a mistake, i wanted my code to look for the mp3 files automatically in the folders within the music directory.
                  currently I am getting an error in the developer console:
                  Uncaught SyntaxError: Unexpected token ',' (at MMM-MP3Player.js:184:2)
                  its the “,” at the end of
                  return wrapper
                  I am trying to have one ‘music’ folder with subfolders for each artist containing their songs. This way, the module would display artists on the frontend, and clicking an artist’s name would show the songs in their folder, and click on the song would then play the mp3 file.
                  feel like giving up really even though I think I am close
                  S B 3 Replies Last reply
                    sdetweil @bachoo786
                    @bachoo786 what did you change?
                    this is a missing } probably
                      sdetweil @bachoo786
                      @bachoo786 well, coding is a challenge sometimes
                      you changed the data coming back from the node helper
                      the code is looking for songs
                      but its a nested struct in musicData
                      so, fix the first thing (the socketNotificationReceived)
                      and then the code crashes later cause you are expecting the data in songs…
                      computers do things fast… they don’t know WHY they are doing it, so can’t ‘fix’ themselves
                        bachoo786 @bachoo786
                        @bachoo786
                        I changed from this:
                                const musicList = MP3.createElement("ul", "musicList", "musicList");
                                MP3.config.musicData.forEach(folderData => {
                                    // Folder item
                                    const folderItem = MP3.createElement("li", "folderItem", `folderItem-${folderData.folderName}`);
                                    folderItem.innerHTML = `
                                        <span class="folderName">${folderData.folderName}</span>
                                        <i class="fa fa-chevron-down"></i>
                                    // Songs list within the folder
                                    const songsList = MP3.createElement("ul", "songsList", `songsList-${folderData.folderName}`);
                                    songsList.style.display = 'none'; // Initially hide the songs list
                                    folderData.songs.forEach(song => {
                                        const songItem = MP3.createElement("li", "songItem", `songItem-${song}`);
                                        songItem.innerHTML = song.substr(0, song.length - 4);
                                        songsList.appendChild(songItem);
                                    // Click event listeners
                                    folderItem.addEventListener('click', () => {
                                        songsList.style.display = songsList.style.display === 'none' ? 'block' : 'none'; // Toggle display
                                        folderItem.querySelector('.fa').classList.toggle('fa-chevron-down');
                                        folderItem.querySelector('.fa').classList.toggle('fa-chevron-up');
                                    songsList.addEventListener('click', (event) => {
                                        const clickedSongItem = event.target;
                                        if (clickedSongItem.classList.contains('songItem')) {
                                            const songName = clickedSongItem.innerText;
                                            const folderName = folderData.folderName;
                                            MP3.playSong(folderName, songName);
                                    folderItem.appendChild(songsList);
                                    musicList.appendChild(folderItem);
                        to this:
                           const fs = require('fs');
                           const path = require('path');
                           const musicFolder = path.resolve(MP3.config.musicData.musicPath);
                           const supportedExtensions = this.defaults.extensions; // Use module's default extensions
                           fs.readdir(musicFolder, (err, files) => {
                            if (err) {
                             console.error("Error reading music directory:", err);
                             // Handle the error - display message to user, etc.
                            } else {
                             const musicFiles = files.filter(file => supportedExtensions.includes(path.extname(file).toLowerCase()));
                             if (musicFiles.length > 0) {
                              const musicList = MP3.createElement("ul", "musicList");
                              musicFiles.forEach(musicFile => {
                               const songItem = MP3.createElement('li', 'songItem');
                               songItem.innerHTML = musicFile.substr(0, musicFile.length - 4);
                               songItem.addEventListener('click', () => {
                                MP3.playSong(musicFile); // Assuming you want to play the song directly
                               musicList.appendChild(songItem);
                        S 2 Replies Last reply
                          sdetweil @bachoo786
                          @bachoo786 you could say, I have updated the repo, git pull to get the changes…
                          you need to
                          git add,
                          git commit -m and
                          git push
                          to update the repo
                            sdetweil @bachoo786
                            @bachoo786 said in MP3 Player:
                            the modulename.js that runs in the browser cannot read files directly, due to security restrictions ( any script could read ALL your files without you knowing)
                            this is why the node_helper exists…
                              bachoo786 @sdetweil
                              @sdetweil said in MP3 Player:
                              so whats the alternative? I had this MMM-QuranPlayer module that was able to read mp3 files from the folders in the “public” directory which was located in the root folder of the module.
                                sdetweil @bachoo786
                                @bachoo786 I’m pretty sure the module used a node_helper
                                now if you make it a url, then you can fetch it thru the browser… but the server side is actually reading the file
                                but you could make it a file url
                                file:///server/path to file
                                in MagicMirror the server home folder is the MagicMirror folder
                                  BiaGen @sdetweil
                                  Hey @bachoo786, I’ve been following your progress with the folder nesting—it’s a tricky bit of logic to get right in the node_helper, but it’ll be worth it for the cleaner UI!
                                  One thing I noticed while setting up my own music module is that the player looks a lot better if the MP3 metadata (ID3 tags) is actually clean. If the tags are messy, the ‘Artist’ and ‘Title’ fields on the mirror usually end up looking like a jumble of underscores and file extensions.
                                  Since you’re organizing a big library right now, I’ve been using https://editmp3tags.com/ to quickly fix the tags in the browser before dropping them into the music folder. It’s way faster than using a heavy desktop app and helps the module display everything correctly once you get that ‘better method’ logic sorted out.
                                  • 3 / 3
