    MP3 Player
    59 Posts 5 Posters 32.3k Views 4 Watching
      sdetweil @bachoo786
      @bachoo786 you don’t set
      if (MP3.config.musicData) {  anywhere..  so getDom() returns an empty div
      I ‘assume’ you meant for the node_helper to send this back
      but yours socketNotifcationReceived does this
          if(notification === "RETURNED_MUSIC")
            MP3.config.songs = payload.songs;  <---  songs is undefined, but musicData is there
      B B 2 Replies Last reply Reply Quote 0
        bachoo786 @sdetweil
        @sdetweil so I made a mistake, i wanted my code to look for the mp3 files automatically in the folders within the music directory.
        currently I am getting an error in the developer console:
        Uncaught SyntaxError: Unexpected token ',' (at MMM-MP3Player.js:184:2)
        its the “,” at the end of
        return wrapper
        I am trying to have one ‘music’ folder with subfolders for each artist containing their songs. This way, the module would display artists on the frontend, and clicking an artist’s name would show the songs in their folder, and click on the song would then play the mp3 file.
        feel like giving up really even though I think I am close
        S B 3 Replies Last reply Reply Quote 0
          sdetweil @bachoo786
          @bachoo786 what did you change?
          this is a missing } probably
            sdetweil @bachoo786
            @bachoo786 well, coding is a challenge sometimes
            you changed the data coming back from the node helper
            the code is looking for songs
            but its a nested struct in musicData
            so, fix the first thing (the socketNotificationReceived)
            and then the code crashes later cause you are expecting the data in songs…
            computers do things fast… they don’t know WHY they are doing it, so can’t ‘fix’ themselves
              bachoo786 @bachoo786
              @bachoo786
              I changed from this:
                      const musicList = MP3.createElement("ul", "musicList", "musicList");
                      MP3.config.musicData.forEach(folderData => {
                          // Folder item
                          const folderItem = MP3.createElement("li", "folderItem", `folderItem-${folderData.folderName}`);
                          folderItem.innerHTML = `
                              <span class="folderName">${folderData.folderName}</span>
                              <i class="fa fa-chevron-down"></i>
                          // Songs list within the folder
                          const songsList = MP3.createElement("ul", "songsList", `songsList-${folderData.folderName}`);
                          songsList.style.display = 'none'; // Initially hide the songs list
                          folderData.songs.forEach(song => {
                              const songItem = MP3.createElement("li", "songItem", `songItem-${song}`);
                              songItem.innerHTML = song.substr(0, song.length - 4);
                              songsList.appendChild(songItem);
                          // Click event listeners
                          folderItem.addEventListener('click', () => {
                              songsList.style.display = songsList.style.display === 'none' ? 'block' : 'none'; // Toggle display
                              folderItem.querySelector('.fa').classList.toggle('fa-chevron-down');
                              folderItem.querySelector('.fa').classList.toggle('fa-chevron-up');
                          songsList.addEventListener('click', (event) => {
                              const clickedSongItem = event.target;
                              if (clickedSongItem.classList.contains('songItem')) {
                                  const songName = clickedSongItem.innerText;
                                  const folderName = folderData.folderName;
                                  MP3.playSong(folderName, songName);
                          folderItem.appendChild(songsList);
                          musicList.appendChild(folderItem);
              to this:
                 const fs = require('fs');
                 const path = require('path');
                 const musicFolder = path.resolve(MP3.config.musicData.musicPath);
                 const supportedExtensions = this.defaults.extensions; // Use module's default extensions
                 fs.readdir(musicFolder, (err, files) => {
                  if (err) {
                   console.error("Error reading music directory:", err);
                   // Handle the error - display message to user, etc.
                  } else {
                   const musicFiles = files.filter(file => supportedExtensions.includes(path.extname(file).toLowerCase()));
                   if (musicFiles.length > 0) {
                    const musicList = MP3.createElement("ul", "musicList");
                    musicFiles.forEach(musicFile => {
                     const songItem = MP3.createElement('li', 'songItem');
                     songItem.innerHTML = musicFile.substr(0, musicFile.length - 4);
                     songItem.addEventListener('click', () => {
                      MP3.playSong(musicFile); // Assuming you want to play the song directly
                     musicList.appendChild(songItem);
                sdetweil @bachoo786
                @bachoo786 you could say, I have updated the repo, git pull to get the changes…
                you need to
                git add,
                git commit -m and
                git push
                to update the repo
                  sdetweil @bachoo786
                  @bachoo786 said in MP3 Player:
                  the modulename.js that runs in the browser cannot read files directly, due to security restrictions ( any script could read ALL your files without you knowing)
                  this is why the node_helper exists…
                    bachoo786 @sdetweil
                    @sdetweil said in MP3 Player:
                    so whats the alternative? I had this MMM-QuranPlayer module that was able to read mp3 files from the folders in the “public” directory which was located in the root folder of the module.
                      sdetweil @bachoo786
                      @bachoo786 I’m pretty sure the module used a node_helper
                      now if you make it a url, then you can fetch it thru the browser… but the server side is actually reading the file
                      but you could make it a file url
                      file:///server/path to file
                      in MagicMirror the server home folder is the MagicMirror folder
                        BiaGen @sdetweil
                        Hey @bachoo786, I’ve been following your progress with the folder nesting—it’s a tricky bit of logic to get right in the node_helper, but it’ll be worth it for the cleaner UI!
                        One thing I noticed while setting up my own music module is that the player looks a lot better if the MP3 metadata (ID3 tags) is actually clean. If the tags are messy, the ‘Artist’ and ‘Title’ fields on the mirror usually end up looking like a jumble of underscores and file extensions.
                        Since you’re organizing a big library right now, I’ve been using https://editmp3tags.com/ to quickly fix the tags in the browser before dropping them into the music folder. It’s way faster than using a heavy desktop app and helps the module display everything correctly once you get that ‘better method’ logic sorted out.
                        • 3 / 3
