    unexpected token error
    12 Posts 3 Posters 2.1k Views 3 Watching
    • G Offline
      Guku @sdetweil
      its there, i copied it wrong
      “name”: “mmm-openweathermapforecast”,
      “version”: “1.0.0”,
      “description”: “MagicMirror² module that gets weather forecast data from OpenWeatherMap”,
      “repository”: {
      “type”: “git”,
      “url”: “git+https://github.com/MarcLandis/MMM-OpenWeatherMapForecast”
      “keywords”: [
      “MagicMirror”,
      “MagicMirror²”,
      “Weather”,
      “OpenWeatherMap”,
      “Forecast”,
      “main”: “MMM-OpenWeatherMapForecast.js”,
      “scripts”: {
      “test”: “echo "Error: no test specified" && exit 1”
      “author”: “Jeff Clarke”,
      “license”: “MIT”,
      “dependencies”: {
      “moment”: “^2.28.0”,
      “needle”: “^2.5.2”
      • KristjanESPERANTOK Offline
        There is a comma to much at the end of the keywords array: "Forecast",
        S G 2 Replies Last reply Reply Quote 0
          sdetweil @KristjanESPERANTO
          @KristjanESPERANTO said in unexpected token error:
          There is a comma to much at the end of the keywords array: “Forecast”,
          javascript is very accepting of TOO MANY commas…
          and NOT accepting of not enough .
          but I don’t understand what MM is complaining about the package.json
          unless its the enhancement to updateNotification…
          [ERROR] SyntaxError: Error parsing /home/lolo/MagicMirror/modules/MMM-OpenWeatherMapForecast/package.json: Unexpected token ‘]’, …“ast”,
          • G Offline
            Guku @KristjanESPERANTO
            @KristjanESPERANTO
            that was it! thank you so much!
            it loads now.
              @sdetweil said in unexpected token error:
              That’s right about JavaScript. But trailing commas are a syntax error in JSON files.
                never mind… I didn’t catch that it was in json file…
                but the user shouldn’t be editing the file… so its the authors error…
                as the author just updated it I think
                but how did he npm install??
                unless he did a git pull and didn’t npm install
                I see this latest is the case, as you opened issue.
                I updated to point the way …
                KristjanESPERANTOK 1 Reply Last reply Reply Quote 1
                  My Pull Request has been merged :-)
                  Users have to update the module, then the problem should be solved.
