    unexpected token error
    12 Posts 3 Posters 2.2k Views 3 Watching
      sdetweil @Guku
      @Guku said in unexpected token error:
      /home/lolo/MagicMirror/modules/MMM-OpenWeatherMapForecast/package.json
      that file…
      not your config
      G 2 Replies Last reply Reply Quote 0
      • G Offline
        Guku @sdetweil
        "name": "mmm-openweathermapforecast",
        "version": "1.0.0",
        "description": "MagicMirror² module that gets weather forecast data from OpenWeatherMap",
        "repository": {
            "type": "git",
            "url": "git+https://github.com/MarcLandis/MMM-OpenWeatherMapForecast"
        "keywords": [
            "MagicMirror",
            "MagicMirror²",
            "Weather",
            "OpenWeatherMap",
            "Forecast",
        "main": "MMM-OpenWeatherMapForecast.js",
        "scripts": {
            "test": "echo \"Error: no test specified\" && exit 1"
        "author": "Jeff Clarke",
        "license": "MIT",
        "dependencies": {
            "moment": "^2.28.0",
            "needle": "^2.5.2"
        • G Offline
          Guku @sdetweil
          sorry,
          "version": "1.0.0",
          "repository": {
              "type": "git",
          "keywords": [
              "MagicMirror",
              "MagicMirror²",
              "Weather",
              "OpenWeatherMap",
              "Forecast",
          "scripts": {
          "license": "MIT",
          "dependencies": {
              "needle": "^2.5.2"
            sdetweil @Guku
            @Guku its missing the leading { as first line
            G KristjanESPERANTOK 2 Replies Last reply Reply Quote 0
            • G Offline
              Guku @sdetweil
              its there, i copied it wrong
              “name”: “mmm-openweathermapforecast”,
              “version”: “1.0.0”,
              “description”: “MagicMirror² module that gets weather forecast data from OpenWeatherMap”,
              “repository”: {
              “type”: “git”,
              “url”: “git+https://github.com/MarcLandis/MMM-OpenWeatherMapForecast”
              “keywords”: [
              “MagicMirror”,
              “MagicMirror²”,
              “Weather”,
              “OpenWeatherMap”,
              “Forecast”,
              “main”: “MMM-OpenWeatherMapForecast.js”,
              “scripts”: {
              “test”: “echo "Error: no test specified" && exit 1”
              “author”: “Jeff Clarke”,
              “license”: “MIT”,
              “dependencies”: {
              “moment”: “^2.28.0”,
              “needle”: “^2.5.2”
              • KristjanESPERANTOK Offline
                There is a comma to much at the end of the keywords array: "Forecast",
                S G 2 Replies Last reply Reply Quote 0
                  sdetweil @KristjanESPERANTO
                  @KristjanESPERANTO said in unexpected token error:
                  There is a comma to much at the end of the keywords array: “Forecast”,
                  javascript is very accepting of TOO MANY commas…
                  and NOT accepting of not enough .
                  but I don’t understand what MM is complaining about the package.json
                  unless its the enhancement to updateNotification…
                  [ERROR] SyntaxError: Error parsing /home/lolo/MagicMirror/modules/MMM-OpenWeatherMapForecast/package.json: Unexpected token ‘]’, …“ast”,
                  • G Offline
                    Guku @KristjanESPERANTO
                    @KristjanESPERANTO
                    that was it! thank you so much!
                    it loads now.
                      @sdetweil said in unexpected token error:
                      That’s right about JavaScript. But trailing commas are a syntax error in JSON files.
                        never mind… I didn’t catch that it was in json file…
                        but the user shouldn’t be editing the file… so its the authors error…
                        as the author just updated it I think
                        but how did he npm install??
                        unless he did a git pull and didn’t npm install
                        I see this latest is the case, as you opened issue.
                        I updated to point the way …
                        KristjanESPERANTOK 1 Reply Last reply Reply Quote 1
