    MMM-Navigate, Issues with KY-040 rotary encoder
    15 Posts 2 Posters 1.9k Views 2 Watching
      stinkycol @sdetweil
      Hi, yes I tried that but when editing boot/config there was an entry inside saying it had moved to boot/firmware/config so I added it there.
      S S 2 Replies Last reply Reply Quote 0
        sdetweil @stinkycol
        @stinkycol the dependency for onoff is in the package.json, and would be loaded in the module node_modules folder during npm install
        the fact that you don’t have a black screen error indicates it is installed and I see the module has the updated postinstall step to make sure it has the correct binary level matching the electron version
        did you look at the output of npm start to verify the module loaded correctly?
          stinkycol @stinkycol
          @stinkycol This is the message i see when i try to edit boot/config:
            @sdetweil said in MMM-Navigate, Issues with KY-040 rotary encoder:
            this is what I am looking for
            when you do npm start. MagicMirror puts out message
            if you use pm2 to autolaunch MM during boot
            then the command
            pm2 logs --lines=nn
            where nn is some number of lines to display, default 15
            will display the collected logs…
            generally I recommend NOT using pm2 during module adds and reconfigures to be able to review these messages more easily.
              stinkycol @sdetweil
              Hi, firstly I would like to thank you for helping me out especially as i am so new to this. There are messages on the npm report but I was starting the MM from my terminal on the screen and i didn’t see the messages since the mirror started up and covered them but I have started using Putty and now i can see them. I see that there is an exception that has onoff in the message so perhaps it hasnt been loaded correctly?
                stinkycol @sdetweil
                @sdetweil I am using PM2 in my other build but i haven’t implemented it in this one as i just wanted to confirm the KY040 code worked before moving on to autostarting
                  sdetweil @stinkycol
                  @stinkycol pm2 has lots of commands
                  in linux the convention is commands provide help two ways
                  1. using the --help param
                  2. providing a manual page, seen with man program_name
                  pm2 status will show you what is defined and what its state is
                  you can control individual apps (I have 10 defined on one system)
                  with the number of the row that matches their name or the actual name (oops I have 3 MagicMirror apps defined in different locations, so I have to use the row number
                  pm2 stop xx
                  or if you know what they are you can stop them all
                  pm2 stop all
                  you can restart an app too
                  etc…
                    sdetweil @stinkycol
                    @stinkycol i have seen that error on other posts, and it sounds like there are some new tests on setting up the gpio pins.
                    the code wants 3 pins,
                    the node_helper code
                    		console.log('MMM-Navigate, listen on GPIO PINs (BCM): '+self.config.GPIOPins[0]+','+self.config.GPIOPins[1]+','+self.config.GPIOPins[2]);
                    		const CLK = new Gpio(self.config.GPIOPins[1], 'in', 'both',{debounceTimeout : 0 }); //BCM Pin 20
                    		const DT = new Gpio(self.config.GPIOPins[0], 'in', 'both',{debounceTimeout : 0 }); //BCM Pin 26
                    line 38		const SW = new Gpio(self.config.GPIOPins[2], 'in', 'both',{debounceTimeout : 20 }); //BCM Pin 19
                    the error is on the last, which is the one you added to the boot time config.
                    I think ‘both’ incorrect for this.
                    when you used profileswitcher, what module did you use for connecting the encoder? as that module doesn’t have a hardware component
                      stinkycol @sdetweil
                      @sdetweil I used MMM-GPIO-Notifications as i was using this on my other build to use simple buttons to swap pages.
                      On the latest run I still get the errors:
                      These are the entries in the config.js:
                      This is the npm output as i move the KY040:
                        stinkycol @sdetweil
                        @sdetweil sorry I don’t write understand how you figured that the last one was causing the issue and is this an issue with boot/firmware/config? Did this mean that I should replace the gpio in the MMM-Navigate module on config.js to the sudonyms?
                        GPIOPins:[DT, CLK, SW]
