    Error log full of this error - gdk_monitor_get_scale_factor
    16 Posts 3 Posters 1.9k Views 4 Watching
    • Dotmatrix812D Offline
      Dotmatrix812 @sdetweil
      It is a raspberry pi3 with raspian 11
      I use MMM-BackgroundSlideshow
      https://github.com/darickc/MMM-BackgroundSlideshow
      I used the standard install from the magic mirror website.
      What other information do you need ?
      Thanks a lot.
        sdetweil @Dotmatrix812
        @Dotmatrix812 what version of MagicMirror are you running?
        you can see it in the logs, but maybe for you easier to do
        grep version package.json
        edited: fixed typo
        Dotmatrix812D 1 Reply Last reply Reply Quote 0
          @Dotmatrix812 also can your show the config for backgroundslideshow
          do you use any transitions?
            The version is “version”: “2.27.0”,
            The config for the background is
              module: 'MMM-BackgroundSlideshow',
              position: 'fullscreen_below',
               imagePaths: ['modules/MMM-BackgroundSlideshow/fotos/'],
               randomizeImageOrder: true,
               slideshowSpeed: 60000,
               backgroundAnimationEnabled: false,
               gradient: [ "rgba(0, 0, 0, 0.5) 0%", "rgba(0, 0, 0, 0.15) 40%", "rgba(0, 0, 0, 0.15) 80%", "rgba(0, 0, 0, 0.5) 100%" ],
               horizontalGradient: [ "rgba(0, 0, 0, 0.5) 0%", "rgba(0, 0, 0, 0.15) 40%", "rgba(0, 0, 0, 0.15) 80%", "rgba(0, 0, 0, 0.5) 100%" ],
               gradientDirection: 'both',
            Thanks for your help
              @Dotmatrix812 ok, 2.27 turns off use of the gpu by default
              do this, open a terminal window
              pm2 stop all
              export ELECTRON_ENABLE_GPU=1
              npm start
              and see if that message continues
              you will have to minimize MagicMirror to get back to the terminal window
              ctrl-m
              should work
                @Dotmatrix812 here also is an interesting cause
                no monitor attached, Is this your case?
                  Seems so.
                  [2024-04-28 20:08:21.486] [INFO]  BACKGROUNDSLIDESHOW: reading path "modules/MMM-BackgroundSlideshow/fotos//1.jpg"
                  [7029:0428/200827.311004:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion 'GDK_IS_MONITOR (monitor)' failed
                  [7029:0428/200827.343752:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion 'GDK_IS_MONITOR (monitor)' failed
                  [7029:0428/200827.350960:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion 'GDK_IS_MONITOR (monitor)' failed
                  [2024-04-28 20:09:21.614] [INFO]  BACKGROUNDSLIDESHOW: reading path "modules/MMM-BackgroundSlideshow/fotos//10.jpg"
                  [2024-04-28 20:10:21.688] [INFO]  BACKGROUNDSLIDESHOW: reading path "modules/MMM-BackgroundSlideshow/fotos//8.jpg"
                  [2024-04-28 20:11:21.762] [INFO]  BACKGROUNDSLIDESHOW: reading path "modules/MMM-BackgroundSlideshow/fotos//12.jpg"
                  Strange that the time stamp is so different …
                    No. Monitor is connected to the raspberry. Or could this happen when the monitor gets switched off via the MMM-PIR module ?
                    Sorry that my answers take so long. But I still need 3 reputations as new user.
                      @Dotmatrix812 could be because turned off… altho I have not seen this before
                        @Dotmatrix812 also, I am the one that approves posts
                        they may be delayed as I am spending time w grandson
