    Error log full of this error - gdk_monitor_get_scale_factor
    16 Posts 3 Posters 2.0k Views 4 Watching
      sdetweil @Dotmatrix812
      @Dotmatrix812 what version of MagicMirror are you running?
      you can see it in the logs, but maybe for you easier to do
      grep version package.json
      edited: fixed typo
      Dotmatrix812D 1 Reply Last reply Reply Quote 0
        @Dotmatrix812 also can your show the config for backgroundslideshow
        do you use any transitions?
        • Dotmatrix812D Offline
          Dotmatrix812 @sdetweil
          The version is “version”: “2.27.0”,
          The config for the background is
            module: 'MMM-BackgroundSlideshow',
            position: 'fullscreen_below',
             imagePaths: ['modules/MMM-BackgroundSlideshow/fotos/'],
             randomizeImageOrder: true,
             slideshowSpeed: 60000,
             backgroundAnimationEnabled: false,
             gradient: [ "rgba(0, 0, 0, 0.5) 0%", "rgba(0, 0, 0, 0.15) 40%", "rgba(0, 0, 0, 0.15) 80%", "rgba(0, 0, 0, 0.5) 100%" ],
             horizontalGradient: [ "rgba(0, 0, 0, 0.5) 0%", "rgba(0, 0, 0, 0.15) 40%", "rgba(0, 0, 0, 0.15) 80%", "rgba(0, 0, 0, 0.5) 100%" ],
             gradientDirection: 'both',
          Thanks for your help
            @Dotmatrix812 ok, 2.27 turns off use of the gpu by default
            do this, open a terminal window
            pm2 stop all
            export ELECTRON_ENABLE_GPU=1
            npm start
            and see if that message continues
            you will have to minimize MagicMirror to get back to the terminal window
            ctrl-m
            should work
              @Dotmatrix812 here also is an interesting cause
              no monitor attached, Is this your case?
                Seems so.
                [2024-04-28 20:08:21.486] [INFO]  BACKGROUNDSLIDESHOW: reading path "modules/MMM-BackgroundSlideshow/fotos//1.jpg"
                [7029:0428/200827.311004:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion 'GDK_IS_MONITOR (monitor)' failed
                [7029:0428/200827.343752:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion 'GDK_IS_MONITOR (monitor)' failed
                [7029:0428/200827.350960:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion 'GDK_IS_MONITOR (monitor)' failed
                [2024-04-28 20:09:21.614] [INFO]  BACKGROUNDSLIDESHOW: reading path "modules/MMM-BackgroundSlideshow/fotos//10.jpg"
                [2024-04-28 20:10:21.688] [INFO]  BACKGROUNDSLIDESHOW: reading path "modules/MMM-BackgroundSlideshow/fotos//8.jpg"
                [2024-04-28 20:11:21.762] [INFO]  BACKGROUNDSLIDESHOW: reading path "modules/MMM-BackgroundSlideshow/fotos//12.jpg"
                Strange that the time stamp is so different …
                  No. Monitor is connected to the raspberry. Or could this happen when the monitor gets switched off via the MMM-PIR module ?
                  Sorry that my answers take so long. But I still need 3 reputations as new user.
                    @Dotmatrix812 could be because turned off… altho I have not seen this before
                      @Dotmatrix812 also, I am the one that approves posts
                      they may be delayed as I am spending time w grandson
                        Time with the grandson is very important 👍
                        I will check if I can find out if the errors appear after the monitor gets switched off.
