    Error log full of this error - gdk_monitor_get_scale_factor
    16 Posts 3 Posters 1.8k Views 4 Watching
    • Dotmatrix812D Offline
      Dotmatrix812
      Hi
      My error log is full of this error. And it is still coming. My background slideshow is sometimes. It working as well. Could be in relation to the error. But I am not sure. I have no glue where this error is coming from.
      Anyone any idea what could help to solve this error ?
      [21525:0421/123934.640033:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion 'GDK_IS_MONITOR (monitor)' failed
      [21525:0421/123934.668565:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion 'GDK_IS_MONITOR (monitor)' failed
      [21525:0421/123934.672953:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion 'GDK_IS_MONITOR (monitor)' failed
      Thanks a lot
        sdetweil @Dotmatrix812
        @Dotmatrix812 can you tell us a our your system?
        I have never seen that error before
        what module are you using for background?
        Dotmatrix812D 1 Reply Last reply Reply Quote 0
          Dotmatrix812 @sdetweil
          It is a raspberry pi3 with raspian 11
          I use MMM-BackgroundSlideshow
          https://github.com/darickc/MMM-BackgroundSlideshow
          I used the standard install from the magic mirror website.
          What other information do you need ?
          Thanks a lot.
            @Dotmatrix812 what version of MagicMirror are you running?
            you can see it in the logs, but maybe for you easier to do
            grep version package.json
            edited: fixed typo
              @Dotmatrix812 also can your show the config for backgroundslideshow
              do you use any transitions?
                The version is “version”: “2.27.0”,
                The config for the background is
                  module: 'MMM-BackgroundSlideshow',
                  position: 'fullscreen_below',
                   imagePaths: ['modules/MMM-BackgroundSlideshow/fotos/'],
                   randomizeImageOrder: true,
                   slideshowSpeed: 60000,
                   backgroundAnimationEnabled: false,
                   gradient: [ "rgba(0, 0, 0, 0.5) 0%", "rgba(0, 0, 0, 0.15) 40%", "rgba(0, 0, 0, 0.15) 80%", "rgba(0, 0, 0, 0.5) 100%" ],
                   horizontalGradient: [ "rgba(0, 0, 0, 0.5) 0%", "rgba(0, 0, 0, 0.15) 40%", "rgba(0, 0, 0, 0.15) 80%", "rgba(0, 0, 0, 0.5) 100%" ],
                   gradientDirection: 'both',
                Thanks for your help
                  @Dotmatrix812 ok, 2.27 turns off use of the gpu by default
                  do this, open a terminal window
                  pm2 stop all
                  export ELECTRON_ENABLE_GPU=1
                  npm start
                  and see if that message continues
                  you will have to minimize MagicMirror to get back to the terminal window
                  ctrl-m
                  should work
                    @Dotmatrix812 here also is an interesting cause
                    no monitor attached, Is this your case?
                      Seems so.
                      [2024-04-28 20:08:21.486] [INFO]  BACKGROUNDSLIDESHOW: reading path "modules/MMM-BackgroundSlideshow/fotos//1.jpg"
                      [7029:0428/200827.311004:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion 'GDK_IS_MONITOR (monitor)' failed
                      [7029:0428/200827.343752:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion 'GDK_IS_MONITOR (monitor)' failed
                      [7029:0428/200827.350960:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion 'GDK_IS_MONITOR (monitor)' failed
                      [2024-04-28 20:09:21.614] [INFO]  BACKGROUNDSLIDESHOW: reading path "modules/MMM-BackgroundSlideshow/fotos//10.jpg"
                      [2024-04-28 20:10:21.688] [INFO]  BACKGROUNDSLIDESHOW: reading path "modules/MMM-BackgroundSlideshow/fotos//8.jpg"
                      [2024-04-28 20:11:21.762] [INFO]  BACKGROUNDSLIDESHOW: reading path "modules/MMM-BackgroundSlideshow/fotos//12.jpg"
                      Strange that the time stamp is so different …
                        No. Monitor is connected to the raspberry. Or could this happen when the monitor gets switched off via the MMM-PIR module ?
                        Sorry that my answers take so long. But I still need 3 reputations as new user.
