    Error log full of this error - gdk_monitor_get_scale_factor
    16 Posts 3 Posters 2.9k Views 4 Watching
    • Dotmatrix812D
      Dotmatrix812 @sdetweil
      The version is “version”: “2.27.0”,
      The config for the background is
        module: 'MMM-BackgroundSlideshow',
        position: 'fullscreen_below',
         imagePaths: ['modules/MMM-BackgroundSlideshow/fotos/'],
         randomizeImageOrder: true,
         slideshowSpeed: 60000,
         backgroundAnimationEnabled: false,
         gradient: [ "rgba(0, 0, 0, 0.5) 0%", "rgba(0, 0, 0, 0.15) 40%", "rgba(0, 0, 0, 0.15) 80%", "rgba(0, 0, 0, 0.5) 100%" ],
         horizontalGradient: [ "rgba(0, 0, 0, 0.5) 0%", "rgba(0, 0, 0, 0.15) 40%", "rgba(0, 0, 0, 0.15) 80%", "rgba(0, 0, 0, 0.5) 100%" ],
         gradientDirection: 'both',
      Thanks for your help
      S 2 Replies Last reply
        sdetweil @Dotmatrix812
        @Dotmatrix812 ok, 2.27 turns off use of the gpu by default
        do this, open a terminal window
        pm2 stop all
        export ELECTRON_ENABLE_GPU=1
        npm start
        and see if that message continues
        you will have to minimize MagicMirror to get back to the terminal window
        ctrl-m
        should work
        Dotmatrix812D 1 Reply Last reply
          @Dotmatrix812 here also is an interesting cause
          no monitor attached, Is this your case?
          • Dotmatrix812D
            Seems so.
            [2024-04-28 20:08:21.486] [INFO]  BACKGROUNDSLIDESHOW: reading path "modules/MMM-BackgroundSlideshow/fotos//1.jpg"
            [7029:0428/200827.311004:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion 'GDK_IS_MONITOR (monitor)' failed
            [7029:0428/200827.343752:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion 'GDK_IS_MONITOR (monitor)' failed
            [7029:0428/200827.350960:ERROR:browser_main_loop.cc(278)] Gdk: gdk_monitor_get_scale_factor: assertion 'GDK_IS_MONITOR (monitor)' failed
            [2024-04-28 20:09:21.614] [INFO]  BACKGROUNDSLIDESHOW: reading path "modules/MMM-BackgroundSlideshow/fotos//10.jpg"
            [2024-04-28 20:10:21.688] [INFO]  BACKGROUNDSLIDESHOW: reading path "modules/MMM-BackgroundSlideshow/fotos//8.jpg"
            [2024-04-28 20:11:21.762] [INFO]  BACKGROUNDSLIDESHOW: reading path "modules/MMM-BackgroundSlideshow/fotos//12.jpg"
            Strange that the time stamp is so different …
            • Dotmatrix812D
              No. Monitor is connected to the raspberry. Or could this happen when the monitor gets switched off via the MMM-PIR module ?
              Sorry that my answers take so long. But I still need 3 reputations as new user.
                @Dotmatrix812 could be because turned off… altho I have not seen this before
                  @Dotmatrix812 also, I am the one that approves posts
                  they may be delayed as I am spending time w grandson
                  • Dotmatrix812D
                    Time with the grandson is very important 👍
                    I will check if I can find out if the errors appear after the monitor gets switched off.
                    • T
                      tinkertailorgeek
                      I have MM v2.27.0 on a Pi 3 running bookworm with a monitor attached and I get the same 3 lines in my npm logs.
                      The Pi is using a PIR to monitor presence and turn off the screen after a fixed period of inactivity from the PIR. The screen is turned off by calling a shell to execute xrandr.
                      I can reproduce the error by issuing the command:
                      DISPLAY=:0.0 xrandr --output HDMI-1 --off
                      while the screen is on. No errors occur if I use the same command and the screen is already off.
                      Hope this helps.
                        sdetweil @tinkertailorgeek
                        @tinkertailorgeek thanks… so the code managing the screen doesn’t like having the hdmi channel chopped out from under it…
                        I assume the errors go away when the hdmi port is turned back on
                        T 1 Reply Last reply
                        • T
                          tinkertailorgeek @sdetweil
                          @sdetweil The 3 error entries in the log file only appear at the point in time that the xrandr off is issued. They don’t appear again until the screen has been turned on again and another xrandr -off gets issued.
