    MMM-CalendarWeek doesn't display
    22 Posts 2 Posters 4.4k Views 2 Watching
      DarrenO 0 @sdetweil
      appears to be the same result :
      /home/serveradmin/.pm2/logs/MagicMirror-error.log last 50 lines:
      0|MagicMir | - /home/serveradmin/MagicMirror/js/electron.js
      0|MagicMir | at Module._resolveFilename (node:internal/modules/cjs/loader:1055:15)
      0|MagicMir | at s._resolveFilename (node:electron/js2c/browser_init:2:115476)
      0|MagicMir | at Module._resolveFilename (/home/serveradmin/MagicMirror/node_modules/module-alias/index.js:49:29)
      0|MagicMir | at Module._load (node:internal/modules/cjs/loader:908:27)
      0|MagicMir | at c._load (node:electron/js2c/node_init:2:13672)
      0|MagicMir | at Module.require (node:internal/modules/cjs/loader:1122:19)
      0|MagicMir | at require (node:internal/modules/helpers:130:18)
      0|MagicMir | at Object. (/home/serveradmin/MagicMirror/modules/MMM-CalendarWeek/vendor/ical.js/node-ical.js:2:15)
      0|MagicMir | at Module._compile (node:internal/modules/cjs/loader:1256:14)
      0|MagicMir | at Module._extensions…js (node:internal/modules/cjs/loader:1311:10)
      0|MagicMir | at Module.load (node:internal/modules/cjs/loader:1098:32)
      0|MagicMir | at Module._load (node:internal/modules/cjs/loader:945:12)
      0|MagicMir | at Object. (/home/serveradmin/MagicMirror/modules/MMM-CalendarWeek/vendor/ical.js/index.js:3:12)
      0|MagicMir | (Use electron --trace-warnings ... to show where the warning was created)
      0|MagicMir | [2024-04-30 12:40:46.687] [ERROR] (node:71403) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
      0|MagicMir | MESA-INTEL: warning: Bay Trail Vulkan support is incomplete
      0|MagicMir | libva error: /usr/lib/x86_64-linux-gnu/dri/iHD_drv_video.so init failed
      0|MagicMir | /home/serveradmin/MagicMirror/node_modules/electron/dist/electron exited with signal SIGINT
      0|MagicMir | [2024-04-30 12:56:17.257] [ERROR] (node:71685) UnhandledPromiseRejectionWarning: Error: Cannot find module ‘request’
      0|MagicMir | Require stack:
      0|MagicMir | - /home/serveradmin/MagicMirror/modules/MMM-CalendarWeek/vendor/ical.js/node-ical.js
      0|MagicMir | - /home/serveradmin/MagicMirror/modules/MMM-CalendarWeek/vendor/ical.js/index.js
      0|MagicMir | - /home/serveradmin/MagicMirror/modules/MMM-CalendarWeek/calendarfetcher.js
      0|MagicMir | - /home/serveradmin/MagicMirror/modules/MMM-CalendarWeek/node_helper.js
      0|MagicMir | - /home/serveradmin/MagicMirror/js/app.js
      0|MagicMir | [2024-04-30 12:56:17.258] [ERROR] (node:71685) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag --unhandled-rejections=strict (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 1)
        sdetweil @DarrenO 0
        @DarrenO-0 said in MMM-CalendarWeek doesn't display:
        now
        npm install request
        In the folder of the module complaining
        and continue to repeat this process until the cannot find errors are gone
        this is not a MagicMirror problem. it is a module problem.
          DarrenO 0 @sdetweil
          run how many times?
          have run “npm install valid-url” ~20 times… no change in the error-log
          even run “sudo npm install valid-url” and was prompted to update version of npm from 10.2.5 to 10.6.0, so updated accordingly, then re-ran “npm install valid-url” several more times and no change.
            sdetweil @DarrenO 0
            @DarrenO-0 what folder where you in when you ran the command npm install
            and if you followed the instructions correctly, then only once for each missing library
              DarrenO 0 @sdetweil
              in the MMM-CalendarWeek folder
                sdetweil @DarrenO 0
                @DarrenO-0 show me the contents of the package.json file
                  DarrenO 0 @sdetweil
                  ahhh!!! Got it!
                  Had to run the following and restart MM each time until MM came up :
                  npm install request
                  npm install rrule-alt
                  npm install rrule (as rrule-alt is deprecated)
                  The error log still reports that module rrule-alt cannot be found, but the calendar now displays.
                  thank you!
                    DarrenO 0 @sdetweil
                    cat package.json
                      "name": "mmm-calendarweek",
                      "version": "1.0.0",
                      "description": "This calendar module for [Magic Mirror²](https://github.com/MichMich/MagicMirror) is functionally the same as the default calendar app, however its presentation is different as it uses week view. This module displays events from a public .ical calendar. It can combine multiple calendars. Note that calendars may not contain any entry before 1st January 1970, otherwise the calendar won't be displayed and the module will crash.",
                      "main": "MMM-CalendarWeek.js",
                      "scripts": {
                        "test": "echo \"Error: no test specified\" && exit 1"
                      "keywords": [],
                      "author": "",
                      "license": "ISC",
                      "dependencies": {
                        "request": "^2.88.2",
                        "rrule": "^2.8.1",
                        "rrule-alt": "^2.2.8",
                        "valid-url": "^1.0.9"
                      sdetweil @DarrenO 0
                      @DarrenO-0 yes and request is deprecated, and valid-url…
                      that’s why we removed them, cause the base node and electron support fetch, which does all that and more…
                      but the module could have supplied a package.json file and told you to run npm install to satisfy those code requirements
                        sdetweil @DarrenO 0
                        @DarrenO-0 yes now package.json lists the dependencies
                          @DarrenO-0
                          please use code blocks around
                          config , css, json, or error listing’s
