    MMM-CalendarExt3Agenda no longer works after a certain time.
    7 Posts 3 Posters 1.1k Views 3 Watching
    • O
      Old_Death
      I have completely set up the MagicMirror, which means all modules are configured and display the data correctly.
      The modules likely to be affected by the problem are:
      Calendar module, shows all dates.
      MMM-CalendarExt3, gets the data and displays it correctly.
      MMM-CalendarExt3Agenda, gets the data and displays it correctly.
      What can be said about the MMM-CalendarExt3Agenda module is that it changes the data. See post here:
      https://forum.magicmirror.builders/topic/18707/modul-calendarext3agenda/12?page=2
      Now I put the MagicMirror in the right place and noticed the following error.
      After about 40 minutes of running time, no more data will be displayed in the MMM-CalendarExt3Agenda module.
      Only an empty mini calendar is displayed.
      The other modules (Calendar and MMM-CalendarExt3) display the data.
      Does anyone know the problem or can help me troubleshoot?
      S M 4 Replies Last reply
      • O
        Old_Death @MMRIZE
        @MMRIZE Hallo,
        now I tested the Module and it works fantasic.
        Thank you very much.
          sdetweil @Old_Death
          @Old_Death said in MMM-CalendarExt3Agenda no longer works after a certain time.:
          what is different about this place vs the other?
          were there any edits to any of the MM files in this move? config, css, …
          the fact that the data is good on other modules implies some error on EXT3
          can you use a browser on another system pointed at the MM system, does the same problem occur?
          if so, open the developers window, ctrl-shift-i, and select the console tab and add
          calendarext3 to the filter field
          are there any errors?
            MMRIZE @Old_Death
            @Old_Death
            Share with me your config (eouia0819@gmail.com)
              MMRIZE @Old_Death
              @Old_Death
              I found out what was wrong. I made some mistakes in my previous updates, and there is still a missing one. I’ll fix it and update it soon.
                MMRIZE @Old_Death
                @Old_Death I updated yesterday. Did you check it?
                O 2 Replies Last reply
                • O
                  Old_Death @MMRIZE
                  @MMRIZE Sorry, I was waiting for your replay. Now I has updated the Module and I will tell you soon, if it works korrekt.
                  Thank you.
                  • O
                    Old_Death @MMRIZE
                    @MMRIZE Hallo,
