    MagicMirror 2.27 Error - modules failing - not displaying output - 7May2024
    9 Posts 2 Posters 1.0k Views 2 Watching
      sdetweil @nkc
      @nkc so, how did u get here? is this after the same other weirdness problem?
      • N Offline
        nkc
        @sdetweil - I upgraded my MM to MM 2.27 and saw that some of the modules did not display So I debugged and saw this Error message on the debug console.
        some modules have stopped displaying which uses wrapper.AppendChild () calls So when I saw this error - I am thing its got to do with the error message.
        (PS: all modules were working perfectly fine until after the upgrade to MM 2.27.)
        I am just exhausted trying to find out what the hack is going on !
        Thanks,
        Regards,
        Neel.
          sdetweil @nkc
          @nkc how did you upgrade?
          N 2 Replies Last reply Reply Quote 0
          • N Offline
            nkc @sdetweil
            @sdetweil - Used the script : bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/raspberry.sh)”
            • N Offline
              nkc @sdetweil
              @sdetweil : Did a clean install on a new disk of MM 2.27.
                sdetweil @nkc
                @nkc and it ran ok after that?
                and then how did you get your modules installed?
                you didn’t try to upgrade w my upgrade script?
                • N Offline
                  nkc @sdetweil
                  @sdetweil - I have now install MM 2.27 (a clean install) the third time - And the modules seem to work…I will install other modules which I need and test them…Thank you.
                    sdetweil @nkc
                    @nkc thx. I deleted the duplicate post.
                    all posts from users with reputation below 2 are reviewed before being posted on the forum. I review every post, so patience
                    this stops all the spam, and porn posts
