MMM-SunnyPortal not reading data - more then one plants not showing any values on MM2
14 Posts 2 Posters 1.5k Views 2 Watching
  • F Offline
    frits.erasmus
    I have two PV systems on my account.
    The one is redundant as I have upgraded dramatically in the past (Feb 2020)
    The two are:-
    Frits Midlands Estate - redundant
    Frits Erasmus - active
    I can create a guest account for you if you need access to figure out how to resolve this.
    Regards
    Frits Erasmus
    email is My name . My Surname at gmail
    Any takers or suggestions on how to resolve this?
    S 1 Reply Last reply May 10, 2024, 11:32 AM Reply Quote 0
    • S Away
      sdetweil @frits.erasmus
      @frits-erasmus did you do the npm install
      • F Offline
        frits.erasmus
        Hi sdetwell,
        Yes, I did, but to play it safe I ran it again and paid close attention to feedback (blush) have not done that before.
        I got this feedback:
        up to date, audited 58 packages in 6s
        2 packages are looking for funding
          run `npm fund` for details
        2 moderate severity vulnerabilities
        Some issues need review, and may require choosing
        a different dependency
        Run `npm audit` for details.
        So I ran this:
        npm fund
        mmm-sunnyportal@1.4.0
        +-- https://github.com/sponsors/feross
        |   `-- safe-buffer@5.2.1
        `-- https://github.com/sponsors/epoberezkin
            `-- ajv@6.12.6](link url
        AND
        npm audit
        # npm audit report
        request  *
        Severity: moderate
        Server-Side Request Forgery in Request - https://github.com/advisories/GHSA-p8p7-x288-28g6
        Depends on vulnerable versions of tough-cookie
        No fix available
        node_modules/request
        tough-cookie  <4.1.3
        Severity: moderate
        tough-cookie Prototype Pollution vulnerability - https://github.com/advisories/GHSA-72xf-g2v4-qvf3
        No fix available
        node_modules/tough-cookie
        a different dependency.
        I have to admit - MOST of this went right over my head
        Can you please help me here?
        S 1 Reply Last reply May 10, 2024, 12:42 PM Reply Quote 0
        • S Away
          @frits-erasmus thx. those other commands do t help w info.
          now, show the output from starting MagicMirror, where you do npm start
          F 3 Replies Last reply May 10, 2024, 12:47 PM Reply Quote 0
          • F Offline
            frits.erasmus @sdetweil
            @sdetweil Not 100% sure what you meant:
            This:
            frits@raspberrypi:~/MagicMirror/modules/MMM-SunnyPortal $ npm install
            OR this:-
            • F Offline
              npm install
              frits@raspberrypi:~/MagicMirror/modules/MMM-SunnyPortal $ ^C
              frits@raspberrypi:~/MagicMirror/modules/MMM-SunnyPortal $ npm fund
                  `-- ajv@6.12.6
              frits@raspberrypi:~/MagicMirror/modules/MMM-SunnyPortal $ npm audit
              # npm audit report
              request  *
              Severity: moderate
              No fix available
              tough-cookie  <4.1.3
              Severity: moderate
              No fix available
              S 1 Reply Last reply May 10, 2024, 1:05 PM Reply Quote 0
              • F Offline
                frits@raspberrypi:~/MagicMirror/config $ pm2 start mm
                [PM2] Applying action restartProcessId on app [mm](ids: [ 0 ])
                [PM2] mm ✓
                [PM2] Process successfully started
                │ id │ name │ mode │ ↺ │ status │ cpu │ memory │
                │ 0 │ mm │ fork │ 3 │ online │ 0% │ 2.8mb │
                • S Away
                  @frits-erasmus no. how do you start MagicMirror?
                  if at boot w pm2, then do
                  pm2 stop all
                  then
                  npm start
                  see if there are any messages relative to this module
                  to stop MagicMirror
                  press ctrl-q
                  to restart as on boot
                  do
                  pm2 status
                  pm2 restart  xxx
                  where xxx is the number on the line or name on the line of the app you want to start (I have 10 apps on mine, with multiple copies of MagicMirror… so I have to use the number)
                  start and restart do the same when the app not running
                  F 1 Reply Last reply May 10, 2024, 2:07 PM Reply Quote 0
                  • F Offline
                    @sdetweil said in MMM-SunnyPortal not reading data - more then one plants not showing any values on MM2:
                    pm2 restart
                    [2024-05-10 15:27:39.078] [LOG] SocketNotification START_SUNNYPORTAL received for the first time…setting updateInterval to 900000ms
                    [2024-05-10 15:27:39.083] [LOG] [_login] Trying to login to https://www.sunnyportal.com/FixedPages/HoManLive.aspx/Templates/Start.aspx?ReturnUrl=%2F for accessing day data
                    [2024-05-10 15:27:39.260] [LOG] [_login] Trying to login to https://www.sunnyportal.com/FixedPages/HoManLive.aspx/Templates/Start.aspx?ReturnUrl=%2F for accessing month data
                    [2024-05-10 15:27:39.275] [LOG] [_login] Trying to login to https://www.sunnyportal.com/FixedPages/HoManLive.aspx/Templates/Start.aspx?ReturnUrl=%2F for accessing year data
                    [2024-05-10 15:27:39.293] [LOG] [_login] Trying to login to https://www.sunnyportal.com/FixedPages/HoManLive.aspx/Templates/Start.aspx?ReturnUrl=%2F for accessing total data
                    • F Offline
                      frits.erasmus
                      frits@raspberrypi:~/MagicMirror $ npm start
                      magicmirror@2.27.0 start
                      [2024-05-10 16:13:26.448] [LOG] Starting MagicMirror: v2.27.0
                      [2024-05-10 16:13:26.523] [LOG] Loading config …
                      [2024-05-10 16:13:26.533] [LOG] config template file not exists, no envsubst
                      [2024-05-10 16:13:26.543] [LOG] Loading module helpers …
                      [2024-05-10 16:13:26.545] [LOG] No helper found for module: alert.
                      [2024-05-10 16:13:27.288] [LOG] Initializing new module helper …
                      [2024-05-10 16:13:27.289] [LOG] Module helper loaded: updatenotification
                      [2024-05-10 16:13:28.046] [LOG] Initializing new module helper …
                      [2024-05-10 16:13:28.048] [LOG] Module helper loaded: MMM-ImagesPhotos
                      [2024-05-10 16:13:28.196] [LOG] Initializing new module helper …
                      [2024-05-10 16:13:28.197] [LOG] Module helper loaded: MMM-OpenWeatherMapForecast
                      [2024-05-10 16:13:28.198] [LOG] No helper found for module: MMM-FlipClock.
                      [2024-05-10 16:13:29.120] [LOG] Initializing new module helper …
                      [2024-05-10 16:13:29.121] [LOG] Module helper loaded: MMM-SunnyPortal
                      [2024-05-10 16:13:29.848] [LOG] Initializing new module helper …
                      [2024-05-10 16:13:29.849] [LOG] Module helper loaded: MMM-MQTT
                      [2024-05-10 16:13:29.850] [LOG] All module helpers loaded.
                      [2024-05-10 16:13:29.875] [LOG] Starting server on port 8080 …
                      [2024-05-10 16:13:32.692] [LOG] Server started …
                      [2024-05-10 16:13:32.695] [LOG] Connecting socket for: updatenotification
                      [2024-05-10 16:13:32.698] [LOG] Starting module helper: updatenotification
                      [2024-05-10 16:13:32.699] [LOG] Connecting socket for: MMM-ImagesPhotos
                      [2024-05-10 16:13:32.701] [LOG] Starting node helper for: MMM-ImagesPhotos
                      [2024-05-10 16:13:32.703] [LOG] Connecting socket for: MMM-OpenWeatherMapForecast
                      [2024-05-10 16:13:32.706] [LOG] ====================== Starting node_helper for module [MMM-OpenWeatherMapForecast]
                      [2024-05-10 16:13:32.710] [LOG] Connecting socket for: MMM-SunnyPortal
                      [2024-05-10 16:13:32.712] [LOG] Starting node helper for: MMM-SunnyPortal
                      [2024-05-10 16:13:32.714] [LOG] Connecting socket for: MMM-MQTT
                      [2024-05-10 16:13:32.717] [LOG] MMM-MQTT: Starting node helper
                      [2024-05-10 16:13:32.718] [LOG] Sockets connected & modules started …
                      [2024-05-10 16:13:33.281] [LOG] Launching application.
                      [2024-05-10 16:13:39.304] [INFO] System information:
                      SYSTEM: manufacturer: ; model: ; raspberry: undefined; virtual: false
                      OS: platform: linux; distro: Debian GNU/Linux; release: 12; arch: arm64; kernel: 6.6.28+rpt-rpi-v8
                      VERSIONS: electron: 29.1.6; used node: 20.9.0; installed node: 20.13.0; npm: 10.5.2; pm2: 5.3.1
                      OTHER: timeZone: Africa/Johannesburg; ELECTRON_ENABLE_GPU: undefined
                      [2024-05-10 16:13:40.158] [LOG] Config based debug=module_2_MMM-ImagesPhotos
                      [2024-05-10 16:13:40.166] [LOG] SocketNotification START_SUNNYPORTAL received for the first time…setting updateInterval to 900000ms
                      [2024-05-10 16:13:40.170] [LOG] [_login] Trying to login to https://www.sunnyportal.com/FixedPages/HoManLive.aspx/Templates/Start.aspx?ReturnUrl=%2F for accessing day data
                      [2024-05-10 16:13:40.329] [LOG] [_login] Trying to login to https://www.sunnyportal.com/FixedPages/HoManLive.aspx/Templates/Start.aspx?ReturnUrl=%2F for accessing month data
                      [2024-05-10 16:13:40.346] [LOG] [_login] Trying to login to https://www.sunnyportal.com/FixedPages/HoManLive.aspx/Templates/Start.aspx?ReturnUrl=%2F for accessing year data
                      [2024-05-10 16:13:40.360] [LOG] [_login] Trying to login to https://www.sunnyportal.com/FixedPages/HoManLive.aspx/Templates/Start.aspx?ReturnUrl=%2F for accessing total data
                      [2024-05-10 16:13:40.472] [INFO] updatenotification: Updater Class Loaded!
                      [2024-05-10 16:13:40.473] [INFO] updatenotification: Checking PM2 using…
                      [2024-05-10 16:13:40.478] [INFO] Checking git for module: MMM-ImagesPhotos
                      [2024-05-10 16:13:40.721] [INFO] updatenotification: [PM2] You are not using pm2
                      [2024-05-10 16:13:40.818] [INFO] Checking git for module: MMM-OpenWeatherMapForecast
                      [2024-05-10 16:13:40.881] [INFO] Checking git for module: MMM-FlipClock
                      [2024-05-10 16:13:40.950] [INFO] Checking git for module: MMM-SunnyPortal
                      [2024-05-10 16:13:41.071] [INFO] Checking git for module: MMM-MQTT
                      [2024-05-10 16:13:41.213] [INFO] Checking git for module: MagicMirror
                      [2024-05-10 16:13:41.406] [LOG] [MMM-OpenWeatherMapForecast] 10-May-24 16:13 ** ERROR ** null
                      [2024-05-10 16:13:41.643] [LOG] [_login] Cookie Value: BIGipServerPool_P_SunnyPortal=3053758656.20480.0000
                      [2024-05-10 16:13:41.647] [ERROR] Whoops! There was an uncaught exception…
                      [2024-05-10 16:13:41.656] [ERROR] TypeError: Cannot read properties of null (reading ‘1’)
                      at Request._callback (/home/frits/MagicMirror/modules/MMM-SunnyPortal/node_helper.js:86:103)
                      at self.callback (/home/frits/MagicMirror/modules/MMM-SunnyPortal/node_modules/request/request.js:185:22)
                      at Request.emit (node:events:514:28)
                      at Request. (/home/frits/MagicMirror/modules/MMM-SunnyPortal/node_modules/request/request.js:1154:10)
                      at IncomingMessage. (/home/frits/MagicMirror/modules/MMM-SunnyPortal/node_modules/request/request.js:1076:12)
                      at Object.onceWrapper (node:events:628:28)
                      at IncomingMessage.emit (node:events:526:35)
                      at endReadableNT (node:internal/streams/readable:1408:12)
                      at process.processTicksAndRejections (node:internal/process/task_queues:82:21)
                      [2024-05-10 16:13:41.657] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                      [2024-05-10 16:13:41.659] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
                      [2024-05-10 16:13:41.676] [LOG] [_login] Cookie Value: BIGipServerPool_P_SunnyPortal=3120867520.20480.0000
                      [2024-05-10 16:13:41.678] [ERROR] Whoops! There was an uncaught exception…
                      [2024-05-10 16:13:41.680] [ERROR] TypeError: Cannot read properties of null (reading ‘1’)
                      [2024-05-10 16:13:41.681] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                      [2024-05-10 16:13:41.682] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
                      [2024-05-10 16:13:41.696] [LOG] [_login] Cookie Value: BIGipServerPool_P_SunnyPortal=3120867520.20480.0000
                      [2024-05-10 16:13:41.698] [ERROR] Whoops! There was an uncaught exception…
                      [2024-05-10 16:13:41.700] [ERROR] TypeError: Cannot read properties of null (reading ‘1’)
                      [2024-05-10 16:13:41.701] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                      [2024-05-10 16:13:41.702] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
                      [2024-05-10 16:13:41.718] [LOG] [_login] Cookie Value: BIGipServerPool_P_SunnyPortal=3053758656.20480.0000
                      [2024-05-10 16:13:41.722] [ERROR] Whoops! There was an uncaught exception…
                      [2024-05-10 16:13:41.723] [ERROR] TypeError: Cannot read properties of null (reading ‘1’)
                      [2024-05-10 16:13:41.724] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                      [2024-05-10 16:13:41.724] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MagicMirrorOrg/MagicMirror/issues
                      [2024-05-10 16:13:42.376] [LOG] MMM-MQTT: Starting client for 192.168.1.23:1883 user erasmi
                      [2024-05-10 16:13:42.377] [LOG] MMM-MQTT: Connecting to mqtt://192.168.1.23:1883
                      [2024-05-10 16:13:42.598] [LOG] MMM-MQTT connected to mqtt://192.168.1.23:1883
                      [2024-05-10 16:13:42.600] [LOG] MMM-MQTT: subscribing to sbfspot/2130438237 Topic.PDC1
                      S 1 Reply Last reply May 10, 2024, 2:52 PM Reply Quote 0
