    Font for non-latin characters
    Scheduled Pinned Locked Moved Solved Custom CSS
    6 Posts 3 Posters 940 Views 3 Watching
      jv2007
      Hi.
      I have Open Sans Condensed Thin for my primary font, which is fine for Latin characters. But I don’t like the font for Korean characters in the primary fontset. So want to create a custom.css which should use the primary font for Latin letters but a different font (Noto Sans KR) for Korean.
      Both are installed in the /usr/share/font directory of my RPI5.
      So I have tried several options of which none were working. Please correct me as I am not familiar with the font-face command.
      The 2 last options were suggestions from ChatGPT…
      Option 1:
      @font-face {
        font-family: 'korean';
        src: local('Noto Sans KR');
        unicode-range: U+110-11FF, U+3130-318F, AC00-FFFD;
      @font-face {
        src: local('Open Sans Condensed Light');
        unicode-range: U+0000-017F;
      body {
      Option 2:
      /* Define font face for Noto Sans KR */
      @font-face {
        font-family: 'Noto Sans KR';
        src: local('Noto Sans KR'), url('path/to/noto-sans-kr.woff2') format('woff2'); /* Adjust the path to your font file */
      /* Define font face for Open Sans Condensed */
      @font-face {
        font-family: 'Open Sans Condensed';
        src: local('Open Sans Condensed'), url('path/to/open-sans-condensed.woff2') format('woff2'); /* Adjust the path to your font file */
      /* Apply Noto Sans KR to Korean text */
      html[lang="ko-KR"] body {
        font-family: 'Noto Sans KR', sans-serif;
      /* Apply Open Sans Condensed to non-Korean text */
      body:not([lang="ko-KR"]) {
        font-family: 'Open Sans Condensed', sans-serif;
      Option 3:
      @font-face {
      @font-face {
      /* Apply Open Sans Condensed by default */
      body {
      /* Apply Noto Sans KR to Korean text within English content */
      body:lang(en-GB)::before,
      body:lang(en)::before,
      body:lang(en-US)::before {
        content: attr(data-korean);
      M karsten13K 4 Replies Last reply Reply Quote 0
        MMRIZE @jv2007
        @jv2007
        Option 1 is almost right, but each font-face needs to have a different name.
        Option 2 or 3 seems something related to lang attribute. If your content has explicit lang attribute on the element, it might be work, but, as far as I understand, that might not be your thing.
          MMRIZE @jv2007
          @jv2007
          But, more simple way is; just use this;
          body {
            font-family: 'Open Sans Condensed', 'Noto Sans KR';
          Open Sans Condensed font doesn’t have any Korean characters, so when the renderer meet Korean chars, the second fallback Noto Sans KR would be applied instead of Open Sans Condensed.
          • karsten13K Offline
            karsten13 @jv2007
            @jv2007
            you can take a look at <mm-folder>/fonts/roboto.css where the mm fonts are defined
              MMRIZE @jv2007
              @jv2007
              If you want to use @font-face, you can use like this;
              @font-face {
                src: url('./notosans.ttf') format('truetype');
                unicode-range: U+AC00-FFDD;
              @font-face {
                  font-family: 'english';
                  src: url('./opensanscondensed.ttf') format('truetype');
              div.test {
                  font-family: 'korean', 'english';
                jv2007
                Thanks @MMRIZE and @karsten13 !
                I have tried following your instructions but it didn’t help.
                I figured out it’s hidden in the modules css-file. I should have thought about that beforehand.
                When I change the font as suggested by @MMRIZE to set as
                It works now.
                Thanks guys!
                Case closed!
                • J jv2007 marked this topic as a question on
                • J jv2007 has marked this topic as solved on
