    Remove I frame border
    11 Posts 4 Posters 2.8k Views 3 Watching
      sdetweil @stephanvdplas
      @stephanvdplas which module are you using for iframe?
        stephanvdplas @sdetweil
        @stephanvdplas said in Remove I frame border:
        @barnosch said in Remove I frame border:
        should ne something like this in your
        /css/custom.css file
        .MMM-iFrame {   //exact name of the module
        border: none;  //or border: 0px;
        I tried your suggestion, but still a border is shown. Is there any other option?
        MMM-Iframe:
        			module: 'MMM-iFrame',
        			header: 'Speelt nu',
        			position: 'bottom_left',	// This can be any of the regions.
        //					url: ["http://server.vdplas.net:9000/material/?player=dc:a6:32:18:b6:fd&layout=desktop&action=expandNowPlaying/true&css=msk--np-only&js=msk--np-only&single=true&theme=Black"],  // as many URLs you want or you can just ["ENTER IN URL"] if single URL.
        					updateInterval: 500 * 60 * 1000, // rotate URLs every 30 seconds
        					width: "700", // width of iframe
        					height: "260", // height of iframe
        					frameWidth: "100" // width of embedded iframe, height is beeing calculated by aspect ratio of iframe
          @stephanvdplas if the border is INSIDE the frame, then u cannot change it. that is the point of frame. inline embedded frame of original content
            @sdetweil said in Remove I frame border:
            There is certainly no border in the content. At least not what I see when using differen devices with this same URL
            Also the border appears directly, whereas the content is loaded in 5 seconds
              @stephanvdplas awesome. I’m not sure of the css, but I want to teach you how you can find and resolve it yourself for any content
              see
              https://forum.magicmirror.builders/post/90135
              using the browser developers window, you can examine AND set styles on the element content. once you know what you need, then you can copy/paste that into custom.css
              I ‘think’ the example css provided is too vague, and the actual element doesn’t inherit from the content selected
              in css, the stuff before the { is called the selector clause. it selects the content that the stuff AFTER the { will be applied to.
              I use thise cheat sheet to hemp me remember all the possibilities
              https://www.w3schools.com/cssref/css_selectors.php
              in MagicMirror the outer block is given the module name as a class
              so
              .MMM-iFrame
              is correct, but, that element is a div
              and there are a couple more div elements inside, so I don’t think border:none is inherited.
              I ‘think’ the selector clause needs the specific element iframe added
              .MMM-iFrame iframe {
              but if you use the developers window you will know for sure
                stephanvdplas
                <iframe src="https://server.vdplas.net:8999/material/?player=dc:a6:32:18:b6:fd&amp;layout=desktop&amp;action=expandNowPlaying/true&amp;css=msk--np-only&amp;js=msk--np-only&amp;single=true&amp;theme=Black" width="675" height="250" scrolling="no"></iframe>
                iframe[Attributes Style] {
                    width: 675px;
                    height: 250px;
                user agent stylesheet
                iframe {
                    overflow-clip-margin: content-box !important;
                    overflow: clip !important;
                    border-width: 2px;
                    border-style: inset;
                    border-color: initial;
                    border-image: initial;
                Here indeed I see a border. Still no clue where it comes from.
                  @sdetweil I found it!
                  In custom.css I place the following section:
                  iframe{
                  border:0 ;
                  /*transform: scale(0.5) ; */
                  /*margin-bottom: 200px;*/
                  (source: https://github.com/AgP42/MMM-iFrame-Ping/blob/master/MMM-iFrame-Ping.css)
                  Thanks for your support!
                    @stephanvdplas please be careful…
                    the selector clause WILL ALWAYS select ALL elements that match across the entire web page…
                    so, you should focus on THIS module
                    .MMM-iFrame iframe{
                    border:0 ;
                    that means ALL iframe tags <iframe
                    inside class .MMM-iFrame
                    but not any OTHER module
