    Remove I frame border
    11 Posts 4 Posters 2.8k Views 3 Watching
    • N Offline
      noelandrews
      Does anyone know how I can remove the white border from iframe module?
      Many thanks
      Noel
        barnosch
        should ne something like this in your
        /css/custom.css file
        .MMM-iFrame {   //exact name of the module
        border: none;  //or border: 0px;
          stephanvdplas @barnosch
          @barnosch said in Remove I frame border:
          I tried your suggestion, but still a border is shown. Is there any other option?
            sdetweil @stephanvdplas
            @stephanvdplas which module are you using for iframe?
              stephanvdplas @sdetweil
              @stephanvdplas said in Remove I frame border:
              MMM-Iframe:
              			module: 'MMM-iFrame',
              			header: 'Speelt nu',
              			position: 'bottom_left',	// This can be any of the regions.
              //					url: ["http://server.vdplas.net:9000/material/?player=dc:a6:32:18:b6:fd&layout=desktop&action=expandNowPlaying/true&css=msk--np-only&js=msk--np-only&single=true&theme=Black"],  // as many URLs you want or you can just ["ENTER IN URL"] if single URL.
              					updateInterval: 500 * 60 * 1000, // rotate URLs every 30 seconds
              					width: "700", // width of iframe
              					height: "260", // height of iframe
              					frameWidth: "100" // width of embedded iframe, height is beeing calculated by aspect ratio of iframe
                @stephanvdplas if the border is INSIDE the frame, then u cannot change it. that is the point of frame. inline embedded frame of original content
                  @sdetweil said in Remove I frame border:
                  There is certainly no border in the content. At least not what I see when using differen devices with this same URL
                  Also the border appears directly, whereas the content is loaded in 5 seconds
                    @stephanvdplas awesome. I’m not sure of the css, but I want to teach you how you can find and resolve it yourself for any content
                    see
                    https://forum.magicmirror.builders/post/90135
                    using the browser developers window, you can examine AND set styles on the element content. once you know what you need, then you can copy/paste that into custom.css
                    I ‘think’ the example css provided is too vague, and the actual element doesn’t inherit from the content selected
                    in css, the stuff before the { is called the selector clause. it selects the content that the stuff AFTER the { will be applied to.
                    I use thise cheat sheet to hemp me remember all the possibilities
                    https://www.w3schools.com/cssref/css_selectors.php
                    in MagicMirror the outer block is given the module name as a class
                    so
                    .MMM-iFrame
                    is correct, but, that element is a div
                    and there are a couple more div elements inside, so I don’t think border:none is inherited.
                    I ‘think’ the selector clause needs the specific element iframe added
                    .MMM-iFrame iframe {
                    but if you use the developers window you will know for sure
                      stephanvdplas
                      <iframe src="https://server.vdplas.net:8999/material/?player=dc:a6:32:18:b6:fd&amp;layout=desktop&amp;action=expandNowPlaying/true&amp;css=msk--np-only&amp;js=msk--np-only&amp;single=true&amp;theme=Black" width="675" height="250" scrolling="no"></iframe>
                      iframe[Attributes Style] {
                          width: 675px;
                          height: 250px;
                      user agent stylesheet
                      iframe {
                          overflow-clip-margin: content-box !important;
                          overflow: clip !important;
                          border-width: 2px;
                          border-style: inset;
                          border-color: initial;
                          border-image: initial;
                      Here indeed I see a border. Still no clue where it comes from.
                        @sdetweil I found it!
                        In custom.css I place the following section:
                        iframe{
                        border:0 ;
                        /*transform: scale(0.5) ; */
                        /*margin-bottom: 200px;*/
                        (source: https://github.com/AgP42/MMM-iFrame-Ping/blob/master/MMM-iFrame-Ping.css)
                        Thanks for your support!
